Hot Rods 40 Ford pickup
Discussion in 'The Hokey Ass Message Board' started by shamer, Apr 18, 2020.
  1. shamer
    shamer
    I need to see a picture of the front fender brace installed. I’ve scratched my head and stared at it long enough.
    Thanks.
  2. 41rodderz
    41rodderz
    from Oregon
    Should be able to google ‘40 Ford pick up body diagram.
  3. alchemy
    alchemy
    The yoke? It's probably the same as p***enger cars, and there is a spring between the yoke and the front crossmember. Then the ends bolt into the inner fender panels in the holes provided. And they always crack the inner fender panels.
    olscrounger likes this.
  4. Marty Strode
    Marty Strode
    This is what mine looks like, car / pickup same. Webbing pad under mount, spring below, castle nut and cotter key to set tension. IMG_4662.JPG IMG_4663.JPG
  5. alchemy
    alchemy
    Well there you go, I had the spring in the wrong spot. Marty, how come your yoke has a droopy crossbar? All the ones I have are straight.
  6. olscrounger
    olscrounger
    Same as car--use em on all builds -never an issue--cut out the cross brace for 327
    Hamtown Al and lothiandon1940 like this.
  7. Marty Strode
    Marty Strode
    Jeff, Maybe I better fix that, it may need to come out for balancer clearance, as Olscrounger posted !
    lothiandon1940 likes this.
  8. mj40's
    mj40's
    How is that pickup project going? Here is how I mounted my front sheet metal. You can shim it for alignment.
    Hamtown Al and 302GMC like this.
  9. Bandit Billy
    Bandit Billy
    They make a pill for that @Marty Strode
    Sandgroper likes this.
