Features "Snoopy" Model A Hot Rod Survivor
Discussion in 'Traditional Hot Rods' started by Denns1989, Sep 8, 2014.
  1. ROADSTER1927
    ROADSTER1927
    Great idea to bring up that picture and your memory! It is fantastic just the same. Enjoy, Gary:):cool::D
  2. My nephew helped me take Snoopy off his jack stands yesterday, the laneway is still a bit muddy to drive it out, but that didn't stop me from installing the battery, saved some crank time by filling up the fuel bowl via the vent & then letting him bark a little - not bad for sitting since end of October !
    WC145, dana barlow, Stogy and 11 others like this.
  3. v8flat44
    v8flat44
    Here Snewpee, here boy, come on, you can come and stay in my garage. Good boy !
    Stogy, Finn Jensen and Denns1989 like this.
  4. YJ4000
    YJ4000
    Sounds great! Very exciting, I did the same thing about a week ago. The roads around here were getting pretty clean as far as salt or what ever it is they put on the roads. Than Friday early morning they came around and spread some more. Hopefully for the last time.
    Ryan.
    Stogy and Denns1989 like this.
  5. Ah, such sweet music!!!:)
  6. I never educated myself on how much oil Snoopy should have, just filled to "full", I also noticed that first 1/2 to 1 litre would disappear pretty quick & then stay at "full operating" for the rest of the season... I went down the rabbit hole of flathead oil capacities, filter or no filter, early or late, late style truck pan, different tube lengths.. blah blah blah, ohh ya then there is the Imperial Quart, US Quart debate & then I have to convert those possibilities to Liters because that's what we get here in Canada... Long story short my 8BA with the normal truck pan (removable clean out) & the filter was deleted long ago, 4.5 Liters (4.8 US Quarts) brings it right on "full operating", seems to make sense as the remainder to "full" would be for a refill to include the filter capacity right after a oil change before start up. Hence why many claim 5 US quarts (with filter) all seems to make some sense now... 20200523_161644.jpg
  7. Robert Crosse
    Robert Crosse
    from WNY
    Hi Snoopy,
    Long time no see...
    Bob
  8. Just a fun clip I took yesterday before draining the oil & greasing etc.
  9. Runnin shine
    Runnin shine
  10. Recalling this post from 2014, I'm staying true to my claim that my daughter will be going for lots of cruises in the future - like yesterday, perfect time for a milkshake cruise ! 20200525_145419.jpg 20200525_145527.jpg
    WC145, Jet96, Surfcityrocker and 27 others like this.
  11. Fitnessguy
    Fitnessguy
    Nice! Have to beg my teenagers to go for a cruise in the coupe! Punk kids [emoji3]
    WC145, Stogy, impala4speed and 3 others like this.
  12. ROADSTER1927
    ROADSTER1927
    Super Cool, that is a proper treat for her! ( the ride in the coupe that is ) LOL Gary:p
  13. Wonderful.......wonderful
    Stogy, greaser and Denns1989 like this.
  14. Chevbucket
    Chevbucket
    Carl,sure hope the daughter doesn't see your Some days are rust video. She will be learning some new words!!! ;)
  15. greaser and Denns1989 like this.
  16. The "furry" daughter doesn't like to be left out either, she's a hot rodder as well :) 20200615_201056.jpg
    WC145, Ford52PU, dana barlow and 12 others like this.
  17. Finally !! Yeesh I was wondering how many more pictures it would take ! Ha ha ha ha lol
  18. [emoji41]
    Sent from my Pixel 3a XL using The H.A.M.B. mobile app
    chryslerfan55 and Denns1989 like this.
  19. 6 years ago today was the 1st time I got to actually see Snoopy - man where does the time go ??
  20. You were probably just having too much fun.
    Stogy, Woogeroo and Denns1989 like this.
  21. Talked to you a few years ago at St Ignace Car Show Good to see your posts!
  22. Of Course, I remember meeting you as well, always nice to make a connection !
    Stogy and 2bubbas like this.
  23. Last fall & certainly this spring I noticed a slight "click" almost like a belt to pully alignment sound... upon further investigation I noted the crank pully was "loose", I got a socket on it, seemed tight, checked pully, wasn't loose this time... weird, this weekend I tried to back the nut off & retighten, not a fun job working around the rad, rad hoses etc., anyways those activities made things much, much worse...
    So off came the rad shell, rad last night to discover this...
    And finally this...
    I'm going to call up the original builder & give him crap ! lol Obviously the wrong pully nut was used on that pully, how it held at all since the early 60's is beyond me... now to source a good 8BA truck pully, nut & I assume washer ?
    My Pully is toast !
  24. I have a 52 Merc motor, but of course it has narrow belts, I have a couple of people to check with for a truck pulley first, if not I guess the merc pulley is going on & I'll run narrow belts, I don't think the wide pulley's on the water pump, fan & genny will care much ? Is the belt alignment the same on both pulleys car or truck ?
  25. I'll ask my buddy, and see if he has one. He has an 8BA going in to his 29 Essex coupe.
  26. Thanks ! Much Appreciated
    Bowtie Coupe, Stogy and chryslerfan55 like this.
  27. dwollam
    dwollam
    Definitely get the correct pulley. Yes it really matters. The narrow belts will not work in the wide pulleys.
    Dave
    Bowtie Coupe and Stogy like this.
  28. If you haven't found one yet, Lyle dropped a hub/pulley off at my place tonight. Needs some cleanup.
