Technical '34 5w door hinge
Discussion in 'Traditional Hot Rods' started by terry k, Apr 19, 2020.
  1. terry k
    terry k
    from toledo oh
    I have a '34Ford 5w. The bottom hinge is bent. This is the one on the door it's self. Have to remove if so I can get it in the press. Thought I could drill the rivets out..... Well I did that and it ain't moving. Is it spot welded in place also ? If so what do I do ?What is next ? Need some help !! Thanks Terry
  2. threeimpalas
    threeimpalas
    Yep, it's spot welded.
  3. Dak Rat
    Dak Rat
    from NoDak
    Yes, they are also spot-welded. Sand the flat area and you will see the spot welds. Gotta drill those out as well--not a fun job.
  4. terry k
    terry k
    from toledo oh
    Will the rivets come out or are they going to be stuck to the door skin?
