Projects fixing a smashed 31 model A pickup cab.
Discussion in 'The Hokey Ass Message Board' started by tb33anda3rd, Mar 17, 2019.
  1. The37Kid
    The37Kid
    I like the welded wire to nut captive nut feature. My slantwindow header uses these four barb captive nuts, screws need to be trimmed. Don't know the fancy name for them, ACE has them in the pull out draw hardware section. Bob
    kiwijeff, Stogy, TFoch and 4 others like this.
  2. tb33anda3rd
    tb33anda3rd
    Bob I have a bunch of those but none with the correct size. I did not want to have to go to the hardware store.
    Stogy, The37Kid and loudbang like this.
  3. ct1932ford
    ct1932ford
    :eek:
    Stogy, kidcampbell71 and loudbang like this.
  4. tb33anda3rd
    tb33anda3rd
    put the wood all in. used gorilla glue on the joints and lock washers. I nailed down the rear of the cab. it came out fairly straight and solid IMG_9893.JPG IMG_9894.JPG IMG_9895.JPG IMG_9892.JPG
  5. tb33anda3rd
    tb33anda3rd
    I also blasted some of the tin so it can be epoxy primed before I install it. IMG_9896.JPG
    kiwijeff, nunattax, loudbang and 11 others like this.
  6. The37Kid
    The37Kid
    Ted, Looks like the original paint and lettering is going to stay, I like that. Bob
    Runnin shine, nunattax, Thor1 and 2 others like this.
  7. TFoch
    TFoch
    Wow it's come a long way! Looking great.
    nunattax, Thor1, loudbang and 2 others like this.
  8. tb33anda3rd
    tb33anda3rd
    the slacker wants to keep it so I need to preserve as much of the original paint/patina as possible. I am blasting the parts/ and sections that absolutely need it. I have a plan for when I do the outer patches.... hope it works.
    kiwijeff, Runnin shine, Thor1 and 4 others like this.
  9. tb33anda3rd
    tb33anda3rd
    Thanks Tom. just picking away at it. everything good in New Hampshire?
    Thor1 and loudbang like this.
  10. TFoch
    TFoch
    Good so far. Working from home so a little bored at times. Getting a lot of yard work done. How's things in Connecticut?
    kiwijeff, Thor1 and loudbang like this.
  11. tb33anda3rd
    tb33anda3rd
    been busy with the new job. need to get the body finalized so I can get the frame back to Charlie. he is ready to put it together.
    kiwijeff, Thor1, brEad and 2 others like this.
  12. What an awesome build keep the updates coming.
    tb33anda3rd and loudbang like this.
  13. tb33anda3rd
    tb33anda3rd
  14. tb33anda3rd
    tb33anda3rd
    a buddy of mine rescued this band saw from a dumpster and gave it to me last fall. I finally decided to clean it up, order new tires for the wheels and give it a paint job. all the bearings are good and the machine is really tight. it had a new motor put on at some point. IMG_9890.JPG IMG_9913.JPG
    cactus1, brEad, kiwijeff and 11 others like this.
  15. tb33anda3rd
    tb33anda3rd
    cactus1, brEad, kiwijeff and 7 others like this.
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
    You've got a good friend. I have/had a friend what ever knowing I was looking for a metal lathe and mill because I won't forever be working where there is one to use. What does he do? Tells me after the fact that his girlfriends Dad had both and dumped them per his witnessing and never opened his mouth to say hey I have a friend that will take them. They were perfect home garage size to boot.
  17. tb33anda3rd
    tb33anda3rd
    bummer
  18. Dick Stevens
    Dick Stevens
    loudbang and tb33anda3rd like this.
  19. kidcampbell71
    kidcampbell71
    Is that a 14 inch ? 16 ? Those are nice saws. There's info out there on them, too. Practical Machinist, Garage Journal, etc. Easy couple hundred bucks, better than today's sh*t, at that range.
  20. tb33anda3rd
    tb33anda3rd
    it is a 16". it really is a well made piece. both doors that cover the wheels had been broken off at one point. they were repaired and work fine. I would pay way more than a couple hundred bucks for a piece this well built.
  21. 31Apickup
    31Apickup
    Nice bandsaw. Does it use a common length blade? I have a 1950’s Shop Master that uses an odd size, usually just order the blades from Detroit Band saw usually cheaper than prepackaged blades.
    loudbang and kidcampbell71 like this.
  22. tb33anda3rd
    tb33anda3rd
    113" but my metal band saw has a welder. I make them for the home made/kit wood bandsaw I have.
    Stogy, loudbang, s55mercury66 and 3 others like this.
  23. 31Apickup
    31Apickup
    Stogy, loudbang and tb33anda3rd like this.
  24. hotrodA
    hotrodA
    I have the same saw. The stands are hard to find by themselves. Yours is nice!
    Where did you find the tire bands?
  25. ct1932ford
    ct1932ford
    Let me know when I can start using it!:rolleyes:
    nunattax, TFoch, loudbang and 3 others like this.
  26. tb33anda3rd
    tb33anda3rd
    amazon $54 for a pair of urethane tires
    kidcampbell71, Stogy and loudbang like this.
  27. tb33anda3rd
    tb33anda3rd
    didn't get much time to spend but I was able to get the tin nailed on. IMG_9927.JPG IMG_9928.JPG IMG_9929.JPG IMG_9930.JPG IMG_9931.JPG
    cactus1, brEad, kiwijeff and 9 others like this.
  28. hotrodA
    hotrodA
    Thanks!
    tb33anda3rd likes this.
  29. RMONTY
    RMONTY
    Those are called blind nuts, at least that is what they are called in the Radio Control Aircraft hobby. Used to use them all the time, but on a smaller scale of course.
  30. tb33anda3rd
    tb33anda3rd
    The slacker wanted the frame so he could start ***embling it. I took the body off the frame, cut the welds I had used to hold it to the cart. I will drop it off to him tomorrow.. he has everything ready to bolt in except the front spring pack which he is going to put together in the morning. IMG_9932.JPG IMG_9933.JPG IMG_9934.JPG IMG_9935.JPG
    cactus1, brEad, kiwijeff and 10 others like this.
