Hot Rods How...does a cam go flat ?
Discussion in 'The Hokey Ass Message Board' started by Mike VV, Apr 19, 2020.
  1. DDDenny
    I always like it when someone says "my cam went flat" in less than a hundred miles, sure it did but it started before you left the driveway.
    Generally, it's all about the initial startup and break-in procedure and the first half hour of running, letting a new engine idle before the cam is broken in is the kiss of death.
    26 T Ford RPU likes this.
  2. Montana1
    Montana1
    I don't know, I've had more than my share of Chebbies with flat cams.
    Heck, some people still think points are in and the earth is flat... I just don't know any more. :confused::D
  3. gimpyshotrods
    gimpyshotrods
    New oil is not like old oil.
    The steady movement to overhead cams have allowed for reduced valve spring pressure. Everything else has gained a roller.
    This allows for a few things. It reduces friction, freeing up power and mileage, and reduces the need for anti-friction additives in the oil. Those additives have a tendency to eat sensors, and catalytic converters, all of which are mandated on modern vehicles.
    So, while an issue with the cam itself cannot be ruled out, if you are not running an oil that has been specifically designed for flat-tappet cams, it is probably not helping the situation.
    I have seen several cams with lobe damage. Some were old, some were new ones. My wife's SOHC late-model, for two years of the model run, had a soft-cam issue. It has a billet steel cam in it now.
    26 T Ford RPU and egads like this.
  4. 427 sleeper
    427 sleeper
    You mean that points are out and the world is ROUND??? :confused::confused::confused:
    Montana1 likes this.
  5. lmao!!
    sevenhills1952 and chryslerfan55 like this.
  6. sevenhills1952
    sevenhills1952
    A fellow with a flat head asks how does a cam go flat. [​IMG]
    Sent from my SM-S320VL using Tapatalk
    deadbeat and Johnny Gee like this.
  7. chargin03
    chargin03
    Why do we pay on the freeway ?
  8. Exactly
    I’m surprise this **** even make sense to us let alone anybody else in the world
  9. RMONTY
    RMONTY
    Tires are only flat on one side.....And it always seems to be the bottom in most cases.
  10. Yes
    sevenhills1952 likes this.
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ In other words Blow it out your ***!" :D
  12. Sure, that works too
  13. Country Joe
    Country Joe
    A cam goes flat when you leave the oil cap off and it loses all it's carbonation.
  14. Budget36
    Budget36
    I thought they all started going flat when the box was opened, like when you open a beer.
    427 sleeper and Hnstray like this.
  15. J. A. Miller
    J. A. Miller
    from Central NY
    The OP never said if it was a 3/4 cam. How are we supposed to help?
  16. Hnstray
    Hnstray
    from Quincy, IL
    Does a 3/4 cam make an 8 cylinder run on only 6? :confused:
  17. goldmountain
    goldmountain
    Thank you for reminding me. I just changed oil and forgot to put the cap Back!
    Sent from my SM-T350 using The H.A.M.B. mobile app
    Country Joe likes this.
  18. lippy
    lippy
    from Ks
    Interesting wear patterns. 720D%20camshaft%20wear%20on%20fuel%20inj%20lobe 455.jpg cam7a.jpg
  19. Rickybop
    Rickybop
  20. Rickybop
    Rickybop
  21. Connecting rods hitting the cam lobes :oops:
  22. AndersF
    AndersF
    Problaby when you go trough the hardened surface on the lobe they got soft and go down rather quick.
    Then the soft material chips of over to the other side when the hardening start again.
    So the lobes get straight betvin the hardened edges.
    Hope this make any sense couse its hard to explain in english for me.
  23. Country Joe
    Country Joe
    Ever notice how sleepy you get right after your cam goes flat?
    31Vicky with a hemi and Budget36 like this.
  24. Budget36
    Budget36
    Damn, I've been sleepy for 5 years now...
  25. Heavy Old Steel
    Heavy Old Steel
    427 sleeper likes this.
  26. 427 sleeper
    427 sleeper
    I had a flat cam lobe once. They make you want to barf instead of burp. [emoji849]
  27. theHIGHLANDER
    theHIGHLANDER
    Too many RPM? Weak springs? Missed a shift? A late 70s SBC?
    Johnny Gee likes this.
  28. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Right!
    seb fontana likes this.
  29. Hnstray
    Hnstray
    from Quincy, IL
    SBC cams “going flat” started well before the late ‘70s....more like the late ‘50s.....you could say SBC with flat cams are “traditional”.....;)
  30. Mike VV
    Mike VV
    from SoCal
    This is REALLY...hard to believe. Are you guys freaking nuts..?
    Just how much more B.S. could I have put into the question to make it more obvious to you all that this was a total and complete B.S. joke made up from a bored guy sitting and not doing much out doors because of the cold and rain..!
    A "FLAT", (as in FLAT, like a window pane) lobe...again, just how does that happen without a grinder ???
    I'll tell you...it DOESN'T. I've never seen one, and I'm almost 70.
    Did you (most of you), actually READ that post..? As in all of the words ?
    It was total bull **** from beginning to end.
    Seems a couple may have picked up on it, though I haven't read all of the comments, most of you just musta ducked and let the actual information go right over your heads or in one eye and out the other..!
    Ok, I give...no more jokes on the HAMB.
    Mike
    Montana1 and Budget36 like this.
