Technical 1931 Ford victoria
Discussion in 'Traditional Hot Rods' started by luckylou, Apr 20, 2020.
  1. luckylou
    luckylou
    from canada
    rear splash apron on a 31 Ford Vickie who makes a repop or has one they want to sell?
  2. sloppy jalopies
    sloppy jalopies
    Maybe westcotts ?...
    check who makes 'gl*** '31 vickies… they may make that panel...
    there are some very clever guys here I bet with a good set of patterns one of them might be able to make one while sequestered for a month... maybe have it made with some custom beadwork, then you need not have to make it match anything ford made...
    henry ford was cheap... there were 4 body styles that experimented with slanted windshields...
    he may have used the same rear panel on one of the 3 other slant window bodies...
    a full blown restorer might know if it is so...
    Vicky, A-400, cabriolet and the slant windshield sedans...
  3. luckylou
    luckylou
    from canada
    Thank you sloppy I will try them out,, and if anybody on the Hamb can make one I am interested .thanks guys
