Projects '23 Ford Roadster build aka The Incredible Hulk
Discussion in 'The Hokey Ass Message Board' started by Paul, Feb 22, 2018.
  1. alchemy
    alchemy
    I duno the difference. I've never put a calipers to them so I haven't paid any attention. I mostly deal with F-1's. I do have a pile of early F-100 era boxes, but haven't installed any in cars.
    Stogy likes this.
  2. bchctybob
    bchctybob
    Maybe something along these lines.....
    J_J2, brEad, Stogy and 3 others like this.
  3. 64 DODGE 440
    64 DODGE 440
    from so cal
    Perhaps you could bore the hole out on that one and make it work?
    Stogy, Paul and loudbang like this.
  4. Paul
    Paul
    Editor
    I'm not equipped for that
    Bore, hone, broach...
    To have the work done would cost more than a replacement especially when factoring in lost value to original.
    I think I may have a line on one now.
    loudbang and Stogy like this.
  5. Paul
    Paul
    Editor
    Radiator came the other day. Inexpensive aluminum job, we'll see if that was money well spent.
    As planned the only way to get a mechanical fan in there is to cut the blades clean off.
    OFT, loudbang, Stogy and 1 other person like this.
  6. Paul
    Paul
    Editor
    Going to have to loose the bottom of this slightly modified original deuce shell..
    OFT, RICH B, loudbang and 3 others like this.
  7. Stogy
    Stogy
    Jet96, OFT, Shadow Creek and 3 others like this.
  8. gonzo
    gonzo
    I've used Champion aluminum radiators before and had good luck. If you scuff it up a little and shoot it in high temp bronze as a base before painting it black it gives it almost a br*** look.
    Jet96, OFT, Old-Soul and 6 others like this.
  9. Can't help you on that one, sorry. Possibly not Ford?
  10. Not that you asked but here are the headers on my roadster built in '58. My vote is to do them like Gene Chan's!
    neilswheels, Lil'Alb, Jet96 and 8 others like this.
  11. raven
    raven
    Would you be interested in an original T grill shell?
    r
    Stogy and loudbang like this.
  12. Paul
    Paul
    Editor
    Got a couple thanks
  13. Paul
    Paul
    Editor
    couple small (mundane) pieces of the puzzle.
    first was the steering arm, a plain hairpin style.
    Heat, bend and fill..
    no, I didn't modify the spindle, it is how it came to me.
    IMG_20200420_143942.jpg IMG_20200420_143950.jpg IMG_20200420_144838.jpg IMG_20200421_194058.jpg IMG_20200421_194331.jpg
    OFT, Stogy, RustyBullet and 8 others like this.
  14. Paul
    Paul
    Editor
    the other was a little more involved.
    the '57-'58 stock thermostat housing when polished looked nice but
    was pointing in the wrong direction.
    so 'took some 2" od .120 wall tubing and using the rose bud and body hammer I slowly m***aged the end to create a domed and almost closed end.
    cut a small filler piece out of the same pipe to close the hole.
    welded it in and started cleaning it up.
    Tim_with_a_T, OFT, J_J2 and 6 others like this.
  15. Paul
    Paul
    Editor
    cut a 2" hole in a piece of 3/8" plate
    used the cut off wheel in small grinder to cut the plate down a bit and used the saw to chop the domed end off the tube
    sanded the corners off the rough cut plate
    and back to the drill press
    check fit on dummy
    chopped a piece of 1-1/2" od .120 wall tube
    sorry no pictures, but I figured the location of tube to point in a better direction,
    ground the end to fit the contour of the dome
    traced around the tube..
    and cut the hole in the dome
    and checked fit again
    marked the pieces, tacked the pieces, checked the fit, broke the tack, repositioned the tube, mark, tack check...
    welded it all up
    and ground it roughly smooth and bolted it back on
    hacked up some junk radiator hose and taped a couple pieces together to use as a pattern
  16. Paul
    Paul
    Editor
    as expected there is no way to fit the mechanical fan, there is very little space to fit any fan for that matter
    I could fit a very thin electric fan behind or a small diameter one in front..
    edit:
    or a small one high in front and a small one behind low...
    Stogy, OFT and loudbang like this.
  17. Paul
    Paul
    Editor
    curious to work so hard on something just to make it disappear...
    OFT, Stogy, loudbang and 1 other person like this.
  18. Got ta do whatcha got ta do!
    Stogy, loudbang and Paul like this.
  19. El Hueso
    El Hueso
    You make it look so easy! I was wondering what the hell you were doing when you were closing up that 2" pipe. It all makes sense now! Do you think you'll need to add a lip to the thermostat housing (with a simple weld) to keep the hose from popping off/leaking while under pressure?
    Atwater Mike, Stogy, Old-Soul and 3 others like this.
  20. Paul
    Paul
    Editor
    It may not be totally necessary but I probably will put a lip on it
    Stogy, OFT, loudbang and 1 other person like this.
  21. vtwhead
    vtwhead
    Nice work as always Paul. When do you think you will be tackling that perch issue? :D
  22. Paul
    Paul
    Editor
    Thanks, you can see here a simple triangle wedge of 3/8" steel tacked to the axle hard up against the yoke? when straight ahead to keep it from rotating.
    It will get fully welded and dressed, maybe it will disappear too..
    OFT, Stogy, loudbang and 4 others like this.
  23. 31Apickup
    31Apickup
    Nice work, never tried to close up an end of pipe like that, I’ll have to try that sometime.
  24. butch27
    butch27
    Lookin good
  25. loudbang
  26. J_J2
    J_J2
  27. Paul
    Paul
    Editor
    still pecking away at it,
    more minor stuff,
    'was holding off posting till each little thing gets done,
    but what the hey, here's some stuff in progress..
    front shocks going in,
    rear spring mount going in..
    triumph 1, sko_ford, brEad and 5 others like this.
  28. Paul
    Paul
    Editor
    rebuilt the F100 box,
    drilled, tapped and cut down the mount flange while I was at it.
    IMG_20200429_100915.jpg IMG_20200429_101221.jpg IMG_20200429_103540.jpg IMG_20200429_103907.jpg IMG_20200429_110431.jpg IMG_20200429_113030.jpg IMG_20200429_114622.jpg IMG_20200429_115156.jpg IMG_20200429_122638.jpg IMG_20200429_122820.jpg IMG_20200429_131608.jpg
  29. Paul
    Paul
    Editor
    and started fitting it in place
    IMG_20200429_135457.jpg IMG_20200429_142912.jpg IMG_20200429_151951.jpg IMG_20200429_161417.jpg IMG_20200429_163009.jpg IMG_20200429_164255.jpg
