Technical What did you do today?
Discussion in 'The Hokey Ass Message Board' started by Daniels Auto Repair, Jul 9, 2016.
  1. DDDenny
    I stimulated myself:eek:
    I spent my stimulus check on a big "smart" tv, never owned a flat screen tv before so this geezer has finally entered the information age!
  2. 31Apickup
    31Apickup
    You should teach that kid what is and how to use proper PPE when welding.
    clem, lothiandon1940, X-cpe and 2 others like this.
  3. Mike Miller
    Mike Miller
    I have an eight mile air horn that I wake the neighborhood up with on special occasions.
    winduptoy and chryslerfan55 like this.
  4. guthriesmith
    guthriesmith
    Agreed and I have. He is that strong-willed kid that has to learn everything the hard way. Good kid overall with a big heart, but will defy every rule until he knows why it is there after he feels the pain of doing it wrong... Believe me...I wish that weren’t the case.
  5. David Gersic
    David Gersic
    from DeKalb, IL
    Got the cooling system put back together, with new correctly sized heater hoses and fittings. That should stop the leaks. Need to pick up a gallon of Preston to refill it, maybe tomorrow.
  6. stillrunners
    stillrunners
    from dallas
    Dropped off the 56 Imperial at a newer yard I visit and are buddies with - because I had no ***le to run it across the scales - but didn't give a darn about any money - gave a bill a sale to them so they didn't get in any trouble. These guys are in the CRUSHING business and have about three mobile crushers going out around Texas on a on-call basis - and crush what ever comes up out of the local wrecker services - the funny dang thing about it - I left the trunk A/C in it because I have a few and they just aren't worth selling due to shipment costs - BUT that was what all the guys were asking - YOU LEAVING THAT A/C in THERE ? Hell I was laughing they new what it was.........
  7. X-cpe
    X-cpe
    Raised one. He married well. Will listen to her. Biggest change was having a son of his own.
  8. rosstom
    rosstom
    I just changed the oil and cleaned the interior of your truck.
  9. LBCD
    LBCD
    Drove from Long Beach to Palos Verdes, nice to see Catalina Island
  10. harley jim
    harley jim
    Planted some more trees drank some more whiskey [​IMG]
    Sent from my SM-A102U using Tapatalk
    LAROKE, Lil32, The37Kid and 1 other person like this.
  11. Lloyd's paint & glass
  12. saltflats
    saltflats
    from Missouri
    How did you install the patch?
  13. 2deuces64
    2deuces64
    I cleaned up what I bought on Wednesday. I had a good day!!!!!! :):):) IMG_20200423_191218680.jpg IMG_20200423_191158177.jpg IMG_20200423_191207601.jpg
    Lepus, LAROKE, Old wolf and 7 others like this.
  14. Lil32
    Lil32
    enjoyed your photos
    so as we are laid up I did a Google Map drive LB to PV as we have never
    done that drive before on our annual trips to USA.nice drive..
    nearly got booked for speeding as I entered 35 zone but talked
    my way out of ticket.I said I am from Aussie and he let me off. ha ha
    amazing what you can do on google map
    LBCD, chevyfordman and lothiandon1940 like this.
  15. WTF really
    WTF really
    Got tail lights and a set of heads in the mail today. It was like Christmas. 20200424_122111.jpg 20200424_130853.jpg 20200424_130933.jpg
    LAROKE, harley jim, blowby and 5 others like this.
  16. BoogittyShoe
    BoogittyShoe
    Started D.A.ing dead paint from trunk lid yesterday. Found that what I thought was a 1" stress crack on the edge was a decades-old crack in 1/4" of body filler. Rust had migrated under it, so I used an ice pick to break off the loose part. Got nice little grinder from you-know-where yesterday. ($17+, forgot 20% coupon in pocket.) Ground off rust with 36 grit. Went to get Bondo gl***. Pulled off street IMG_20200424_143851.jpg to IMG_20200424_143907.jpg IMG_20200424_110532.jpg answer messages from my sweetie. :)
    Applied two low (minimal sanding) layers. Will finish with regular Bondo.
    Lil32 likes this.
  17. Lloyd's paint & glass
    I trimmed the patch to what i needed. Laid it on the original panel and traced around it. Ran 3/4" tape around the inside of my line, and cut on that line and ran the flanger around the bedside. Then i cut the outer wheelhouse out, replaced it with plug welds. Put the new outer panel on and clamped it, put some self tapping screws around the outside edge, started welding, removed the screws and welded those holes up. All panels are coated with weld thru coating. I've gotta put the other side together tmrw, I'll post a few pictures of that process.
    hammer-time and saltflats like this.
  18. 62rebel
    62rebel
    Put the Galaxie up for sale (yet again), waiting for the nit pickers to get rolling. It's times like this that I wish I had never stopped drinking.
  19. 34Larry
    34Larry
    What I did do Friday.
    I Posted this a week back or so:
    Well as you guys know I have and rebuilt a former 34 (3) window Ford from the 50's and have my issues with it since finally getting on the road in .'17. Well it has run just okay, having brake, transmission problems and after the trans was replaced it developed a miss higher at RPM that has gotten some better but not gone away. Just running around locally it is normal unless getting into it in 1st from a light. It idles great, starts great but damn it, it ain't right. So yesterday I decided it will be fixed and running right or else. So right now the tare down has started, suspecting a vacuum leak because last time my helper installed an intake gasket that had been torn in half. But what ever it is, I'll find it and get this thing on the road like it should be.
    So since then I'm into it as deep as I need to be. Intake w/carbs is removed. Valve covers are off, valley cover is removed, plugs are out, cap and wires are removed, grill and radiator are off, front end is raised making it easier to get to. New intake gaskets are in house.
    So far, as I did post, I discovered a oil soaked shop rag that was laying in the valley that I mistakenly left the last time I had it down this far, at least a year and a half ago. (no comment)!. Whether or not this would have implications in causing a high RPM miss because of the rag preventing oiling to those lifiters some what, I think would be debatable, but it could be possible(?).
    But because I had a real noisy lifter on #2 or #4 at times at start up, and like I said I'm after this *******ly, (: something that is spurious, irregular, inferior, or of questionable origin) miss, I decided to go through all of them checking the lash setting. Before doing so though, I went online to see if I had done it right before. Well being of Norwegian heritage, I'm just a tiny bit hmmmmmmm thick headed and did it my way last time which was ok, but found what I believe is a possible better way. So a so called leading expert on early 331 HEMI motors said: Start with #1 intake. Rotate the crank clockwise which is the natural rotation direction, (edit out mistake here) until #1 exhaust valve just starts to open. Loosen the lock nut, back off the lifter until the push rod is separated slightly, run the rod back in until there is zero lash and tighten 1/2 turn more and retighten the lock nut. Go through all intake valves and then repeat for the exhaust in the same matter, using the intake as your guide when it just begins to open. Well these old arthritic hands took two times as long as they used to just to do the left bank alone, and the back played out also, so that's what I did yesterday. Now to rest up for a day and go back out for the right bank and more punishment.
    I also determined that my electric fuel pump is producing to much pressure at over 7 lbs. according to the Edelebrock manual, and found on line an Offenhauser handy dandy decent pressure reg. and have that on order. That and hot tub'n my old ach'n back under my gazebo in the rain is what I did yesterday. To be continued...………………………….:rolleyes: and :eek:
    I'd post a pic or two but being not HAMB friendly I'll not do that.
  20. Marty Strode
    Marty Strode
    Built a steering bell crank for a buddy's Bonneville car, to his specs, 1/2" aluminum. IMG_4698.JPG IMG_4700.JPG IMG_4701.JPG
    bymanr, LAROKE, winduptoy and 8 others like this.
  21. X-cpe
    X-cpe
    I don't know Hemi's, but that is backward for Chevy.
    Lil32 likes this.
  22. 34Larry
    34Larry
    Corrected my senior moment error.
    harley jim and Lil32 like this.
  23. blowby
    blowby
    from Nicasio Ca
    Worked out on my stairmaster. Yes it was vertical, moved it off the ropes.
  24. BoogittyShoe
    BoogittyShoe
    Finished plastic trunk lid sculpture. IMG_20200424_143851.jpg IMG_20200425_170329.jpg
    LAROKE and harley jim like this.
  25. 1971BB427
    1971BB427
    from Oregon
    My what did I do today is repe***ious for the last couple weeks, and will continue to be for a couple more weeks. Just spreading filler, and blocking it out. Hate this monotonous work, but with quarantine I'm stuck doing it even if I wanted to pay somebody else to do it.
    Having replaced every piece of sheet metal from 4" down, there's a lot of **** welds I have to work to get perfect.
  26. David Gersic
    David Gersic
    from DeKalb, IL
    Drained the oil and dropped the oil pan. Ordered a new gasket, after finding cracks in the corners of this one. Trying to get to the point where nothing leaks.
  27. harley jim
    harley jim
    Started fixing the hood on my lawn mower. It cracked in half[​IMG][​IMG][​IMG][​IMG]
  28. Mike Miller
    Mike Miller
    Mixed a couple of partial cans of paint and slopped a coat of ODP,(over dirt paint) on the underside of the floor pan and started prepping the rust wagon to remove the body from the frame.
  29. BoogittyShoe
    BoogittyShoe
    Check it out~
    Chrome bullet lights on each side?
