Projects Timm builds a model A
Discussion in 'The Hokey Ass Message Board' started by Tim, Mar 8, 2016.
  1. Tim
    Tim
    from KCMO
    Went looking for photos of the green I had in mind when I say the ford green 626F579C-A447-45B1-8777-9A0ACA63B578.jpeg this one obviously looks a little different because that red firewall is a high contrast but 064A43A5-88C7-4B04-9C8F-F195E163A6BB.jpeg this one actually has a firewall that’s the color I’m painting the car or at least close enough. The firewall will be black as well as the fenders and grill so I guess the play between the dutches blue and sorta olive color of the block won’t be as strong as I was thinking it may be. 8584042C-1171-4A28-84E8-505D6790E7CA.jpeg and of course a red one with some cast goodies...
    drdave, loudbang, Stogy and 1 other person like this.
  2. Tim
    Tim
    from KCMO
    Picking away at it. D5A9D807-B817-41C8-87A9-F86041AD1364.jpeg im thinking I can slice right on this seem and push the firewall back the small amount I need a little filler strip and done deal. I might actually cut this spare one and push it around just to see if it it works or not. ADC46B93-2E89-4DC2-9C37-2E0821A2C024.jpeg 9CC2C852-724A-4EFD-B50F-3D4EC1C57E76.jpeg made a little template for a plate mount. Gonna try it in 1/16 thick plate and see if it works. If it seems like it’s going to flex to much I’ll do it again in 1/8 thick. A858B2CD-B06B-4DAB-BF7B-F1FF90623680.jpeg just a quick shot showing how close this hammer tone silver comes to a newly cast aluminum piece. Not bad!
    Thor1, drdave, loudbang and 2 others like this.
  3. Rocky
    Rocky
    Classified Editor
    Cool......hey, if I send you a short piece of video I made this afternoon, can you post it? I'm old and stupid when it comes to that ****.
    Tim and loudbang like this.
  4. I like that green, 1st choice.
    Second would be either Ford gold or Ford bronze (I can't decide):
    Thor1, loudbang and Tim like this.
  5. Six Ball
    Six Ball
    from Nevada
    I like the valve cover paint, Hammer Tone Silver? For the engine I like the green and I like machinery gray like old lathes and mills. Gray is nice because everything dress it up.
  6. Tim
    Tim
    from KCMO
    absolutely man! Hopefully you got the video I sent ya birthday boy :)
    Thor1 and loudbang like this.
  7. Tim
    Tim
    from KCMO
    @Six Ball ill take a photo of the can for ya later
    Thor1, Six Ball and loudbang like this.
  8. Tim
    Tim
    from KCMO
    Thor1, loudbang and brEad like this.
  9. Six Ball
    Six Ball
    from Nevada
    Thanks, There is some good rattle can stuff out there.
    Thor1, Stogy, loudbang and 1 other person like this.
  10. Tim
    Tim
    from KCMO
    There really is. I think I’m leaning towards a red block, cast aluminum or similar painted valve cover, side plate, intake, carb adapter, water neck/ thermostat housing, and a white headed
    for now any how lol
  11. redzula
    redzula
    I'm kinda partial to the red block and cast valve cover idea. IMG_20200308_142932.jpeg
    That's my vote.
    Sent from my rotary phone using The H.A.M.B. mobile app
    Thor1, Stogy, Six Ball and 4 others like this.
  12. Tim
    Tim
    from KCMO
    Thor1 likes this.
  13. Six Ball
    Six Ball
    from Nevada
    Early in my 153 build I planned to do the same thing I had done to the 270 GMC in my pickup. Which was to paint the head, block and pan dark cast iron gray and then buff the sheet metal parts with Scotchbrite to a semi-sheen. There are also some aluminum parts. I really liked the look but a couple of trips to Bonneville took their toll on the sheetmetal. The clear I used was not enough protection. Next time I'll powder coat it.
    For the 153 I even tried to cut down a GMC valve cover but it was too much for me. They are not as straight as they look and the metal is thin. Grinding the welds made holes. I think I know how to do it now, maybe someday. But the hand buffed sheet metal really looks good, I think. And it costs next nothing.
    Thor1, JOYFLEA, brEad and 4 others like this.
  14. Tim
    Tim
    from KCMO
    Does look slick! I’d contemplated polishing the cast iron intake but it sounded like up keep I knew I wasn’t going to want.
    CF7BBD0C-F9FE-4011-8ABD-BC0CBFED1B19.jpeg Knocked some more off with a flap disc and painted the intake, water neck and the o state housing.
    could have done better prep but it’s better than the last one so I guess it’ll work
    Thor1, drdave, brEad and 3 others like this.
  15. Tim
    Tim
    from KCMO
    Snapped this photo of a little detail I found in an 07 hopup magazine. 3E950ABE-411F-4F95-B07A-B68DB7C15D72.jpeg Check out the tabs on the intake/ exhaust bolts. The intake is bolted on top of the header flange and then bolted on. Kinda clever! Been playing with ideas of how I’ll bolt my stuff together.
    Thinking likely I’ll use thick header flanges and then weld a little shim/ washer to it to make up the thickness difference and use the stock hold downs
  16. Stogy
    Stogy
    :rolleyes:... @Tim, there are profiled cutouts in the flange to allow the intake p*** through to the flange to meet the Head/Block proper and the angle brackets hold the Header flange to the Head/Block utilizing the Studs provided
    If that's what your saying it doesn't read as such...and yes it's a banger masterpiece of course...
    That Header flage needs to be robust as with only 2 brackets holding that header Tight its easy to see the possibility of leakage outboard of those studs...It is what it is I suppose...and a design element of this engine.
  17. Tim
    Tim
    from KCMO
    Oh you are right, I thought it was stacked as ice seen others stacked before.
    I was mainly focused on the little angle brackets. My engine has more bolts to hold it all on but they still use a bolt in the middle between the intake and exhaust with a little rocker arm looking piece of hardware to clamp each side down
    Thor1, Stogy and loudbang like this.
  18. Tim
    Tim
    from KCMO
    Took a couple minutes and bolted everything together. Looks like the valve cover isn’t touching the fire wall it’s just close and it had shifted back a little when I was messing around with it when the bolts where out.
    still needs a little room but with the water neck off it went right on fine. I marked the firewall to make note of where I need to clearance it a little and I’ll do it when it’s easier to get to. Also need to take some more off the back side of the water neck/ thermostat. Maybe a 1/16 or 1/8 th
    anyhow I also got my template done for the block off plate. Cereal box, razor blade, hole punch and some transfer punches :) 68DA6F88-C06F-4D6E-A27E-DF6071E90DA7.jpeg 4575446F-D0AD-4CE4-A108-8E3F4D77AD49.jpeg A5CD46CC-3E05-4D8C-8BF6-B417A10AE524.jpeg 83CC5E83-B831-4CBA-9235-F1BCF5AF8BA7.jpeg looks pretty good all together :) though my crusty carb looks extra crusty now lol.
    thinking I’ll do the block red, the header matte black, the fan and pulleys black as well
    Stogy, Thor1, kidcampbell71 and 6 others like this.
  19. Tim
    Tim
    from KCMO
    Felt weird to do it but arranged a contactless pickup and got some more parts to move forward a little more on the A. I miss ********ting in driveways.
    anyhow scored this fantastic stromberg 48.seems to be NOS. If not I don’t know if it was ever run it’s very clean and dry. The ****erfly’s are dirty but it looks closer to shelf wear somewhere humid more than anything. 506611D9-382A-4F39-90F5-8AD2BBA7A753.jpeg i don’t really know anything about them outside of them looking like a 97 but flowing more with the larger venturis.
    Maybe @carbking can fill me in on these? From what I gather it takes the same kit/ parts as a 97. I’m also curious about the throttle arm on the choke linkage side on these. I see it labeled a hand throttle in places, the only thing I can thing of is maybe it doesn’t have a fast idle tied to the choke and so you do it manually? Either way I’m a throttle arm away from being g able to connect the pedal to the carb :)
    DBAA28BC-7D5A-4CCA-99D2-801CCD3FE262.jpeg also got another pair of 36 wires. I want to have the same wheels for the spares and figure if I have 6 I’ve got better odds of finding 4 good ones to run on the car full time. DB1E3871-8C3B-4C41-9138-28AAA14A2658.jpeg also got some reading material! Very excited after thumbing threw them quickly.
    I also got the parking brake lever ***embly but forgot to take a photo of it.
    havnt messed with the car much the last couple days but progress is creeping along
    kiwijeff, Thor1, drdave and 9 others like this.
  20. Tim
    Tim
    from KCMO
    9492CE19-C01C-4B04-8EE7-8022157AC5D8.jpeg Parking brake! No idea what it’s from. Old ford is as far as I’ve got so far. Got some old plating in it but it’s to far gone to bother trying to save.
    kiwijeff, Thor1, Stogy and 3 others like this.
  21. Tim
    Tim
    from KCMO
    Spent far to much time trying to make a jig to center mark the master cylinder holes only to find everything is so tight that I couldnt get a hammer in there anyways. Go figure.
    anyhow I stuck an old tracing on the firewall and measured a couple times and popped some holes in the firewall.
    They are a little off from dead center but I think they are close enough for a start. Not sure if I’ll try hole sawing it or using a jig saw to cut them
    Good enough for a quick mock up anyways you slice it.
    took a bunch of photos to kinda show how close everything is to the carb. I mocked up a 40’s ford master even though I’ve been talking about the wilwood unit because, well I have it. That and with their placement I might use them because they are shorter by almost two inches and will clear the hood easier.
    these photos have the master further forward than they would be because a 1/4 inch or more goes into the firewall and this one also has a couple fittings and a brake light switch attached to it where I would be more likely to run a quick 90 deg down or maybe a banjo bolt straight down. That shaves off at least an inch.
    still very tight when it comes to an air cleaner but there’s room 78E3A7DF-54A0-4048-A0C7-20698CD633FC.jpeg C93F7F2B-2A51-4E0D-B42A-5F9AC7918C31.jpeg 5DABAEB3-6013-42D6-AD84-F3AB55D0209D.jpeg 6D00FB1C-9C38-497F-9460-477EAAF39FAF.jpeg 35E5855A-7AEA-4EBD-8DB6-FE2F5BD1F85F.jpeg C502EAF2-E859-4154-9B61-B5D98D2BA924.jpeg
    kiwijeff, Thor1, Stogy and 5 others like this.
  22. Austin kays
    Austin kays
    Man them are fighting words.
  23. Austin kays
    Austin kays
    Hey I might want in on this.. 3 flatheads there man he’d be up against almost 300 hp [emoji23]
    Thor1, Stogy, loudbang and 2 others like this.
  24. Tim
    Tim
    from KCMO
    Haha good! I want to race model A’s
  25. Six Ball
    Six Ball
    from Nevada
    Once you get in the race mode there is no end to it. " It's pretty quick for a ......." is never enough. The fun mode is much more obtainable and affordable. "......and it's pretty quick too." :D
  26. Tim
    Tim
    from KCMO
    I can afford to race against a Flathead, that’s about it lol
    Thor1, brEad and loudbang like this.
  27. Six Ball
    Six Ball
    from Nevada
    You can't afford not to race against a flathead. The only thing they race against at Bonneville is each other. The other vintage engines are thrown together, other than the 4s.
    Thor1, Tim and loudbang like this.
  28. Tim
    Tim
    from KCMO
    Not a lot going on right now, just arm chair sending @Austin kays ideas and help on chopping his A.
    mostly making plans for when I can go buy metal in a few weeks and work on some more little projects. My “spare” times when the kids are asleep right now has been dedicated to getting ready to open our shop back up in a couple weeks and getting ready to go back to work.
    hopefully I’ll have some more progress in the coming weeks :)
    kiwijeff, Stogy, Thor1 and 2 others like this.
  29. Austin kays
    Austin kays
    Well you’ve been a hell of an arm chair hotrod builder. Any time I’ve been unsure or had a question it’s been nice to have you in my corner with a positive answer or help.
    Thor1, Six Ball, brEad and 1 other person like this.
  30. Tim
    Tim
    from KCMO
    @Austin kays just paying it forward :) in the last twenty plus years of being on the hamb I’ve bugged the **** out of a couple of these guys so much I’m surprised they haven’t “lost my number”
    Instead now my kids call them uncles :)
    you’re doin good glad to see that flame sparked again.
    A buddy sent me this about the hand idle on the carb
    “Reading online they say for field truck use, taking off on a hill, and idle high enough so the generator actually charges. So you can have the car sit longer and charge since generators don't charge at an idle.”
    Makes enough since. Might go ahead and hook it up?
    Went threw the garage and the immediate projects and made a list of hardware I’m needing with length, size, thread and how many I need. My wife got me a lanyard with a male and female end for probably 16 standard and metric sizes in both fine and co**** thread and it’s been so handy to not even have to take a part off the car to figure out the thread. Just screw it on like a nut or bolt! I’d never even seen one like this before. Mega handy. I’ll have to take a photo if I havnt shared one already.
    figure I want me trips to the store as fast as possible these days so I want to know exactly what I need.
    kiwijeff, Stogy, Thor1 and 3 others like this.
