Hot Rods Is It Worth It???? Model A Frame WITH Matching Title
Discussion in 'The Hokey Ass Message Board' started by GreaserJosh13, Apr 24, 2020.
  1. GreaserJosh13
    GreaserJosh13
    from Chino
    Hey guys I’m planning on buying this Model A Frame with a matching ***le to start my AV8 Roadster project. Should I try to find something better or is this a decent piece to start with??? I’m planning on using Vern Tardels K member. What do you guys think??? Adjustments.JPG Adjustments.JPG Adjustments.JPG
    osage orange, Tman, Gasser 57 and 2 others like this.
  2. Budget36
    Budget36
    Ya, price is right;)
  3. 56don
    56don
    Is a ***le worth the price? Probably worth more as a ***le than as a frame in Cali.
  4. fiftyv8
    fiftyv8
    from CO & WA
    Grab it and get out of there.
    That my friend is a score...
    dana barlow and GreaserJosh13 like this.
  5. RB35
    RB35
    If it measures out square on the diagonals and you plan on boxing the rest, no rust throughs, no cracks, yada, yada, looks good. Partial boxing puts stress on the frame right after the plate ends. But if your getting Vern's K-member, get his book too.
  6. Budget36
    Budget36
    Well. I have to ask...cause that's the kind of guy I am...is it 2K for it, or 200?
    Kinda makes difference ya think?
  7. GreaserJosh13
    GreaserJosh13
    from Chino
    $500.00
  8. kb cookout
    kb cookout
    Run and buy it quick,
    I get $300 -$500 just for bare frames with No paper work or vin numbers
    later kb
    clem, nunattax and gimpyshotrods like this.
  9. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    Jump NOW, or forever hold your peace! OR, kick back dreaming and hold your piece!
    LOL! I'de be calling/texting/driving right now!
  10. scrap metal 48
    scrap metal 48
    Throw the frame away.. Keep the ***le....
    JUSTIN PERSINGER and wvenfield like this.
  11. GreaserJosh13
    GreaserJosh13
    from Chino
    Already made the deal. I’m picking it up next week.
  12. woodiewagon46
    woodiewagon46
    from New York
    Good deal! In many states having a frame with a ***le is a gold mine as far as the DMV is concerned.
  13. gimpyshotrods
    gimpyshotrods
    Nope. Not in this state.
  14. gimpyshotrods
    gimpyshotrods
    And how do you suggest that he get the numbers from that frame, to some other frame, without violating California, or Federal law?
    Answer carefully, because bad advice here could cost him a vehicle, or worse.
  15. GreaserJosh13
    GreaserJosh13
    from Chino
    It’s not against the law to build the frame & put body on it is it??? I’ve already confirmed that the ***le & frame match??? I’m not looking to do anything dishonest. Just want to build a hot rod legally. That’s why I thought buying a frame with ***le would be a good starting point.
  16. gimpyshotrods
    gimpyshotrods
    No sir, it is not. Have at it! And make sure you have fun.
    If the issue date of the ***le is over 5-years ago, you will need a private verifier to sign off on a REG31 form.
    https://www.dmv.ca.gov/portal/wcm/c...9627-f89e7ce14828/reg31.pdf?MOD=AJPERES&CVID=
    I would do it, but you are a little far for me.
    INVISIBLEKID, warbird1 and loudbang like this.
  17. wvenfield
    wvenfield
    Very good starting point. You are lucky you found the frame with a ***le for what you did. It will save you a lot of headaches down the road.
    loudbang and gimpyshotrods like this.
  18. rusty rocket
    rusty rocket
    Get at it! I started with this pile-o-**** frame and ended up with this! image.jpg image.jpg image.jpg
  19. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    But Wait........There's More!......... Better get a lil enlightened very quickly. Not being insulting, but you'de better get with the program, like as quick as you can...
    winduptoy, nunattax and loudbang like this.
  20. 56don
    56don
    ?? I don't understand what you mean. You must have misunderstood what I said. I never said anything about transferring numbers. My meaning is that having the ***le with it is probably worth buying the frame.
    Take a chill pill, you may know what you are talking about but your at***ude is lacking.
    alanp561 likes this.
  21. Beanscoot
    Beanscoot
    Me being the cautious type, I suggest getting the thing safely transferred into your name immediately, just in case there's some nasty glitches.
    nunattax, loudbang, 62rebel and 2 others like this.
  22. gimpyshotrods
    gimpyshotrods
    Nope. Your words were taken at face value.
    I will put them back out there: "Is a ***le worth the price? Probably worth more as a ***le than as a frame in Cali."
    It is a violation of Federal law, and CA law to use a ***le for a vehicle, for which it was not issued. All 50 states, including yours.
    Your statement "Probably worth more as a ***le than as a frame in Cali." implies using it for a frame other than this one. Without a ***le, a frame has no iden***y. Without a frame, a ***le is a useless piece of paper.
    If I did not understand what you meant, it is because you said it wrong, and owe me an apology for YOUR at***ude.
    Cosmo50 and lonejacklarry like this.
  23. GreaserJosh13
    GreaserJosh13
    from Chino
    ????? Enlightened about what???
  24. 56don
    56don
    Don't hold your breath. My at***ude only reflects your curt responses.
  25. 62rebel
    62rebel
    We really have to get rid of some past practices that are now felony level crimes. Yeah, it's well known that we used to float ***les and data plates around to byp*** what we thought were idiotic and restrictive laws. Well, when the value of many cars runs well into the thousands, and unscrupulous people are going to take advantage of illegitimate paper, the situation is different. Turning a blind eye doesn't help. Giving out **** advice doesn't either. And, if I had access to that deal, I'd snap it up in a heartbeat.
    5window, BamaMav, loudbang and 2 others like this.
  26. GreaserJosh13
    GreaserJosh13
    from Chino
    Well guys. The wife put her foot down & said no can do on spending $500 right now so the frame is available. Call Dave from this link if your interested. UGGGGHHHHHH!!!!! Sometimes life just ****s. I think I may have just shed a tear.
    https://www.facebook.com/marketplace/item/1780591558764824/
    winduptoy and loudbang like this.
  27. Beanscoot
    Beanscoot
    Sounds like we need to start p***ing the hat around for Josh.
    winduptoy, 62rebel and GreaserJosh13 like this.
  28. 41rodderz
    41rodderz
    from Oregon
    Just tell the wife she can buy $500.00 worth on Amazon .:oops:
  29. GreaserJosh13
    GreaserJosh13
    from Chino
    Ha ha. I’m good. Just in the middle of selling a house, buying a house & moving.
    winduptoy and Bandit Billy like this.
  30. kadillackid
    kadillackid
    Look on the bright side, one less thing you have to move :(
