Hot Rods Holley 1850’s on a 6-71 help needed
Discussion in 'The Hokey Ass Message Board' started by Nocero, Sep 25, 2019.
  1. 41rodderz
    41rodderz
    from Oregon
  2. Deuces
    Deuces
    I bought this for my tunnel ram setup and also 2 sets of secondary springs to tune the 600s....
    swade41 likes this.
  3. Nocero
    Nocero
    Thanks exactly what I was looking for.!
    Straight line it is. Thanks guys.
    swade41 likes this.
  4. Deuces
    Deuces
    Make sure you hook up a vacuum line on those 2 ******s...... That's one of Ford's better ideas that worked!..... ;)
  5. 2OLD2FAST
    2OLD2FAST
    from illinois
    Drill the lid , tap 1/8" pipe , threaded hose ******s , piece of vacuum hose ..your good to go..
  6. Nocero
    Nocero
    F3680A10-6856-405A-BAE0-86A32B9CDD62.jpeg So now I have a whole nother dilemma
    I open my box with the linkage to start setting it up and this is what I have.
    It was supposed to be inline style.
    This guy I bought everything from really isn’t doing me any favors here.
    Deuces likes this.
  7. gimpyshotrods
    gimpyshotrods
    FTR: You can boost reference Carters and Edelbrocks.
  8. 427 sleeper
    427 sleeper
    The good news is... inline linkage is CHEAP! [emoji6]
    Sell the side by side linkage and you could probably buy 10 inline kits!
    kadillackid, Deuces and swade41 like this.
  9. swade41
    swade41
    from Buffalo,NY
    Or get a hex shaft that's long enough to go between the carbs, use the heims out of the kit to go onto each carb and buy a throttle cable which you needed to buy anyhow.
    427 sleeper likes this.
  10. Nocero
    Nocero
    Ok looks like I just need to make or buy a couple hex shafts
    Seems like the rest of the kit is the same.
    That sure makes me feel better.
    Seems like this has been spiraling out of control $$$ wise
    I was told when I bought it it was a complete setup ready to bolt on.
    Not so much! But I’ll get it on there come hell or high water
    swade41 likes this.
  11. swade41
    swade41
    from Buffalo,NY
    Anytime you add a blower into the mix the pocketbook gets lighter.
    Deuces and 427 sleeper like this.
  12. kadillackid
    kadillackid
    But worth ever penny :rolleyes:
  13. Nocero
    Nocero
    Ok so I know this is an older thread but I thought I’d update now that I finally got everything together and fired it up.
    The engine starts right up with a tap of the throttle.
    I need to do some tuning the carbs are straight out of the box 1850 tunnel ram carbs
    I believe it has a vacuum leak or lean idle
    I can’t seem to get the idle down without it stalling.
    I haven’t had time to get back to it since I fired it up/broke it in.
    Any ballpark tuning advice such as jets, powervalves, springs.
    It’s a pretty mild small block Chevy
    I have a video I’m trying to figure out how to upload.
  14. Nocero
    Nocero
  15. squirrel
    Stock jetting on Holleys tends to be a tad rich, so you can usually use it as is.
    What is your ignition timing? both initial, and total.
    What is the lowest speed it will idle at?
  16. Nocero
    Nocero
    The distributor is locked @ 28* total right now
    Was considering bumping it to 30*
    If I put it in gear with the brake on and stab it I get about 5 lb of boost it’s 20% underdriven
    Motor has 8.6-1 compression
    I can’t get it to idle less than 1600rpm
    Do you think the PCV could be causing a vacuum leak sufficient enough to cause this?
  17. squirrel
    First thing I would do is have functioning mechanical advance in the distributor, start with 15 to 20 degrees initial, and have it start advancing about 1200 RPM, to 32 total, all in by 2500 rpm.
    Then see how it runs.
    427 sleeper and Deuces like this.
  18. Nocero
    Nocero
    Well I don’t disagree with that advice at all, but I’m going to try and get it to run locked I know there are quite a few people doing it
    For 2 reasons just because it’s welded to lock it and I don’t have another one and I’d have to pull the blower to swap distributors it’s a tight fit with the way I built the recess in the firewall.
  19. squirrel
    Hmmm.....might try retarding the timing a bunch, and see if it helps the idle. If not, then no loss. If it does, then you know what your next move will have to be, expensive and unpleasant as it may be.
  20. Nocero
    Nocero
    Great idea I’ll try it
    I’m not opposed to doing it I was just leaving it as a last resort. That should give me a direction anyway
  21. toxic waste
    toxic waste
    from Iowa
    Hi
    I had problems with idle. To get the ****erfly's closed so it was on the idle circuit I had to drill hole in secondary ****erfly's.
    squirrel likes this.
  22. Nocero
    Nocero
    I had to do that with a tunnel ram once
    I totally forgot I had done it then sold the carbs
    The guy wasn’t very happy I bought and sent him new throttle plates
  23. toxic waste
    toxic waste
    from Iowa
    I think you can adjust secondary with a small screw and open them alittle
  24. Nocero
    Nocero
    Thank you I’ll take a look!
  25. toxic waste
    toxic waste
    from Iowa
    If ****erfly's open to fare then idle screws on side of metering block will not adjust right if at all.
  26. Nocero
    Nocero
    I definitely have them open beyond the idle circuit to keep it running now
  27. Nocero
    Nocero
    Thanks guys
    I’m going to play with the distributor, check for vacuum leaks, and try to open the secondary’s a little this afternoon I’ll report back later with my findings
  28. toxic waste
    toxic waste
    from Iowa
  29. Deuces
    Deuces
    :D:D:cool::D:D
  30. Nocero
    Nocero
    Well I played with the timing it likes 30* the best
    There isn’t an adjustment to open the secondary so I uncapped a couple vacuum ports in the bases to hopefully simulate drilling the throttle blades
    I’ve been anywhere from 1/2 turn to 2 1/2 turns on the idle mixture screws
    Really nothing makes a difference because I can’t close the blades enough to stay in the idle circuit and still keep it running.
    I’m not a carb guy and am frustrated
    I think I’m going to call a local carb guy to look at it or order carbs.
    I hate to spend $1600 on Blower carbs
    These are remanufactured from Holley and I’ve had nothing but trouble they had bad needle and seats and leaked out of the Welch plugs from the start. So I’m not really impressed from them from the get go
    Any other ideas?
