Projects 60s Model A Coupe on Deuce chassis 392 Hemi
Discussion in 'Traditional Hot Rods' started by wdglide, Aug 30, 2019.
  1. Gammz
    Gammz
    from Lincoln Ne
    Go man go!! I ain’t going anywhere!
    kidcampbell71 and wdglide like this.
  2. RustyDogg
    RustyDogg
    Looking really good!
    wdglide likes this.
  3. wdglide
    wdglide
    Floors finally done
    Vic Walter, VNTGE41, brEad and 17 others like this.
  4. dentisaurus
    dentisaurus
    from Boston
    wdglide and loudbang like this.
  5. wdglide
    wdglide
    Walden roof insert welded in. Got a lot of hammer dolly work, then close up the visor corners.
    Vic Walter, VNTGE41, brEad and 16 others like this.
  6. Bullit68
    Bullit68
    from Verona, PA
    WOW! Nice work on the roof panel!
  7. VA HAMB
    VA HAMB
    Awesome work!
  8. wdglide
    wdglide
    Thank you.
  9. Japper
    Japper
    That is some great work, thanks for sharing. My project is at a similar stage.
    loudbang and wdglide like this.
  10. Blue-Collar-HotRods
    Blue-Collar-HotRods
    Excellent work!
  11. Halfdozen
    Halfdozen
    Nice work all round.
    Pedals look good, it looks like you're going to mount the master cylinders behind the dash, facing rearward. Is that right?
    Also, I really like the recesses in your boxing plates. Care to share a little more detail on them?
  12. wdglide
    wdglide
    The pedals will use a 60's truck M/C in the normal (outside) location. The lever above the pivot are for the brake light switch. The pedals are from RJays.
    The boxing plates are doubled. One set had the windows cut out. That windowed plate was then welded overtop a full boxing plate. The cir***ference of each window was then tig welded and ground down to give the illusion that it was stamped. A lot of work -- that I did not do. Mike Wagner from Cornfield did it.
  13. JUNK ROD
    JUNK ROD
    Wow nice craftsmanship I'll be following!!
  14. RustyDogg
    RustyDogg
    Beautiful work!
  15. wdglide
    wdglide
    Some progress on the rear bulkhead.
    Storage underneath...
    crazycasey, Vic Walter, brEad and 8 others like this.
  16. dentisaurus
    dentisaurus
    from Boston
    Quality workmanship going on here.
    What was your reason for stepping the rear fire wall out into the p***enger compartment to meet the roll cage? I'm 6.4 so the parcel shelf had to go for me to fit in an A. Maybe it isn't as deep as it looks?
  17. wdglide
    wdglide
    Thanks. Needed Room for the gas tank. Any further back and the filler neck would hit the deck lid. It’s only forward 1.75”
    brEad and loudbang like this.
  18. GordonC
    GordonC
    Nice work!
  19. wdglide
    wdglide
    Got the wood back in. It was pretty easy. I posted a thread on how I did it, in case anyone needs some ideas.
  20. loudbang and wdglide like this.
  21. swade41
    swade41
    from Buffalo,NY
    I've been following along but never commented, but you're doing a helluva nice job here.
    kidcampbell71, wdglide and loudbang like this.
  22. Bullit68
    Bullit68
    from Verona, PA
    Wow! Just Wow!
  23. wdglide
    wdglide
    Spent the week on some smaller projects. A drop-down battery box for a group 51 battery. And a low mount for a denso alternator.
  24. Just Gary
    Just Gary
    Cool car & beautiful workmanship.
    But how do you adjust alternator belt tension? Does the one little slot give you enough adjustability?:confused:
  25. wdglide
    wdglide
    Yes it does. Thats typical with this style low mount. (Hot Heads)
    loudbang and Just Gary like this.
  26. Just Gary
    Just Gary
    Thanks- good to know. :)
    It's a pretty tight fit down there between the frame, timing cover, and lower pulley.
  27. wdglide
    wdglide
    Yes it is tight. My biggest concerns are the bracket flexing and the small amount of belt contact area on the crank pulley.
    Just Gary and loudbang like this.
  28. Super Streak
    Super Streak
    from Florida
    Awesome job, like every aspect of it.
  29. wdglide
    wdglide
    ***embled to check for clearances and gaps and screw ups.
    E20BF84A-68B4-44BB-9EC7-7D553E2E7E09.jpeg 94F64455-CF24-41E9-915F-0D3BEA885EFD.jpeg DDCBB3DA-F14F-40C3-8E31-D3B069176F6A.jpeg E9E8A7AA-926A-413D-8548-E0273574B8D9.jpeg 27103B07-9155-48B1-82D8-AE502145FC2C.jpeg A13E905B-5A5A-4E0D-9572-8FD604660FDE.jpeg CCFB0E46-8E81-44F8-8B4C-4FFD2652B7BF.jpeg
    crazycasey, brEad, Joe Lemay and 11 others like this.
  30. grichards790
    grichards790
    Incredible work!
