Hot Rods 1938 dodge gasser build thread “simplicity and speed”
Discussion in 'The Hokey Ass Message Board' started by flyin flattie, Apr 25, 2020.
  1. flyin flattie
    flyin flattie
    from Redmond OR
    Ok well it’s been some IMG_7372.JPG IMG_7492.JPG time since I’ve done a build thread. I’ve moved up to Central Oregon and have had a lot of life changing along the way since my T. Now I’ve been graced with putting my hands and mind to work on this *****in little big 1938 Dodge coupe for a good friend I’ve met through an even better friend up here. This is what it’s starting out as. It’s been a project that seemed to have the right idea but sadly p***ed around a few times with hastily done work. Thankfully though it came with some great parts to star so here we go. IMG_7104.JPG
    My first order of business was out with the old front end and in with the new
    After that I figured I needed to move the fire wall back some. There’s a huge dead space between the fire wall and where the hood lays so it was time to knife that old ugly fire wall out and start new IMG_0268.JPG
    And it fell into place. Now it was time to figure out the motor placement. 60583400379__EB2D2502-3D07-4222-B9A0-CFDBB12342C5.JPG
    My drill press took a turn for the worse. But I’m a man with a Milwaukee so....
    I wanted something between a solid mount with some cushion to spare. So I decided 1/2 plate tapped to 1/2 20 would do and what can I say I’m a hot Rodder so Flathead motor mounts are my go to.
  2. flyin flattie
    flyin flattie
    from Redmond OR
    Ok guess my photos go a little jumbled but that’s ok, you can get the point. IMG_7260.JPG
    I forgot to mention I re welded the shackle mounts up front. Idk bout doin wheelies and landing on those little dips. IMG_7266.JPG
  3. flyin flattie
    flyin flattie
    from Redmond OR
    I soon moved on to the trans crossmember. I like using the speedway universal trans crossmembers when I can. Saves some time and money. I did cut it up a bit and make it tie into the X member while being removable as well. IMG_8142.JPG
    I’ll add more pictures of the trans crossmember on a future post.
  4. flyin flattie
    flyin flattie
    from Redmond OR
    And now I’m on to the rear end buildung the longest ladder bars I could shove without getting too outta hand. IMG_8305.JPG 60879270733__F263042E-E576-4BC1-9C84-763425AC403E.JPG IMG_8312.JPG IMG_0241.JPG IMG_0259.JPG IMG_0261.JPG IMG_0258.JPG
  5. flyin flattie
    flyin flattie
    from Redmond OR
  6. loudbang
    Looks like a great start. :)
    kidcampbell71 likes this.
  7. j hansen
    j hansen
    I like it,,,,,,subscribed.:)
    kidcampbell71 and loudbang like this.
  8. 41rodderz
    41rodderz
    from Oregon
    Welcome to Oregon. Looks like a cool coupe and nice work .:)
  9. Nice work! Subscribed! What kind of big block Dodge is that?
  10. Blue-Collar-HotRods
    Blue-Collar-HotRods
  11. Texas Webb
    Texas Webb
    Really nice fab work.What's the machine in the 1st picture?
  12. 53 hemi
    53 hemi
    Looks like a 440. Has the pad in front of the valley.
    Sent from my SM-G950U using The H.A.M.B. mobile app
  13. flyin flattie
    flyin flattie
    from Redmond OR
    It’s a vibro shear, same idea as a pullmax.
  14. flyin flattie
    flyin flattie
    from Redmond OR
    You are correct it’s a 440. I wish it were a hemi or a 413 but it’s cheaper to go with the 440 IMG_0282.JPG
  15. flyin flattie
    flyin flattie
    from Redmond OR
    Here’s a better look at the machine
  16. southcross2631
    southcross2631
  17. Texas Webb
    Texas Webb
  18. lemondana
    lemondana
    from Lincoln NE
    Thank You for the Mopar engine!
  19. slayer
    slayer
    Cool project. I like how you cut the cowl down. Those late 30's Mopars have tight engine compartments. Dad and I had a hell of a time fitting a 392 Hemi into his 37 Dodge.
  20. Adam Derr
    Adam Derr
  21. scrap metal 48
    scrap metal 48
    Very cool build and the firewall looks great... Your welding ain't bad either....
  22. flyin flattie
    flyin flattie
    from Redmond OR
    Hey thank you! It’s all taken years of practice and picking the right brains
  23. flyin flattie
    flyin flattie
    from Redmond OR
    I’m sure you did! Also when you think about the engine bay as a whole the further you move back the more room you have for the heads since the frame is at its widest point in the center of the car.
  24. swade41
    swade41
    from Buffalo,NY
    Nice job you're doing, looks great
  25. flyin flattie
    flyin flattie
    from Redmond OR
    I got the car sitting on its own suspension again!!! It looks great! This is the lowest setting and I live it but I’m sure I’ll have to adjust the wheel arches a bit.
    View attachment 4668322 60971670679__0C77766E-829E-4D98-A577-E16227706A01.JPG IMG_0295.JPG IMG_0327.JPG
  26. flyin flattie
    flyin flattie
    from Redmond OR
  27. Rickybop
    Rickybop
    I like old Mopars. I like Mopar B & RB engines, A833, 8.75...
    I like your car.
    Nice work.
    VANDENPLAS, b-body-bob and loudbang like this.
  28. Rickybop
    Rickybop
    Your firewall is so unique. I've never seen anything quite like it.
    A work of art. Distinctive.
    Can't wait to see how you finish everything.
  29. Adam Derr
    Adam Derr
    Seeing it in person is so much better! The firewall is unique and will be painted to match the car. Probably going dark blue with some metallic flake.
    Sent from my VS996 using The H.A.M.B. mobile app
  30. Fitty Toomuch
    Fitty Toomuch
    from WVa
    Mopar in a Mopar, the way God intended.
    subscribed.
