Projects ‘32 tudor project
Discussion in 'Traditional Hot Rods' started by triumph 1, Apr 7, 2018.
  1. triumph 1
    triumph 1
    Thanks. I’m looking forward to seeing your project, it’s sounds like it will be a cool hot rod!
  2. triumph 1
    triumph 1
    Managed to find enough time to get the pistons & rods installed today[​IMG][​IMG][​IMG]
    brEad, Runnin shine, 32SEDAN and 5 others like this.
  3. vtwhead
    vtwhead
    Sweet! Keep at it.
  4. triumph 1
    triumph 1
    [​IMG][​IMG]
    Made a anthill amount of progress today.....
    Cleaned, masked, primed, painted the front cover & figured out how to mount my degree wheel with a 5/8” center hole on my 3/4” crankshaft bolt w/o drilling the wheel bigger.
    I’ll use my balancer installer adapter to mount it.
    32SEDAN likes this.
  5. vtwhead
    vtwhead
    yep, that is a good idea:)
  6. Rickybop
    Rickybop
    Just saw your thread.
    Good car.
    Good engine.
    Good work.
    Fresh, painted block with shiny new guts. So pretty.
    Sent from my VS835 using The H.A.M.B. mobile app
  7. 343w
    343w
    It's great to see you back on your tudor engine work, looking good. I been buying parts for mine with Christmas money and working on the door alignments, hinge-pin holes being worn is the next issue.
  8. triumph 1
    triumph 1
    It’s good to be back at it. I’m glad to hear you’re making progress on yours.
  9. triumph 1
    triumph 1
    Thanks
  10. triumph 1
    triumph 1
    [​IMG][​IMG][​IMG][​IMG][​IMG]
    Been making a little progress finally. Degreed the cam, installed my rebuilt oil pump & ****oned up the short block.
    Masked, primed, painted & cleared the heads. Just have to get them on, figure out pushrod length & order them. Hopefully I’m on the home stretch.....
  11. vtwhead
    vtwhead
    So, why are the freeze plugs in the block by the forward cylinders?
  12. triumph 1
    triumph 1
    I believe they were there from the factory & I had the machine shop replace them. I’ll have to go back & look at my original pics now to see if they were indeed there
  13. triumph 1
    triumph 1
    It’s probably hard to see with all the muck but I’m 98% sure those Welch plugs belong there
  14. triumph 1
    triumph 1
    It looks like my 303 block had them too, just corroded through. The ones in the front bottom coolant p***ages are restricted w/ 3/8” holes in them.
  15. gonzo
    gonzo
    The 56 block under my bench has them too.
    triumph 1 likes this.
  16. vtwhead
    vtwhead
    I do not recall seeing any in my 54 block. Wonder if Frank @F&J or @Paul could suggest why these are there and what ramifications might be seen without them?
  17. triumph 1
    triumph 1
    Yeah, I would be curious to know as well.
  18. vtwhead
    vtwhead
    I just watched a GM promo video of the engine building process at the new plant. Near the end it shows a tech working on an ***embled 303 before the heads were on and you can clearly see that one port has a plug. This is going to bug the **** out of me now as I can' recall if my block has them or not.
    Mark Grabo likes this.
  19. Heath.H
    Heath.H
    My 54 324 block has them as well.
  20. triumph 1
    triumph 1
    [​IMG][​IMG][​IMG]
    Slowly getting closer to getting it installed & fired up....
    TFoch, nunattax, brEad and 4 others like this.
  21. vtwhead
    vtwhead
    Nice progress, bet your getting anxious!
  22. triumph 1
    triumph 1
    Thanks Walt,
    yes I’m definitely getting anxious
  23. triumph 1
    triumph 1
    Damn HF engine leveler fell apart as soon as I removed my engine from the stand!
    I was able to fix it & get it installed [​IMG]
    chryslerfan55, gonzo, brEad and 4 others like this.
  24. Malcolm
    Malcolm
    from Nebraska
    Nice work on the new engine! Great to see the progress. Super cool Sedan, as well!
  25. triumph 1
    triumph 1
    Thanks man. It’s been a long journey to get to this point.
    chryslerfan55 and Malcolm like this.
  26. Runnin shine
    Runnin shine
    I don’t know if spark plug wire holding could get more perfect than this.
  27. vtwhead
    vtwhead
    Like what I am seeing, looks sweet setting in that ch***is
  28. Mat Thrasher
    Mat Thrasher
    Looking good, glad to see you're making progress.
  29. triumph 1
    triumph 1
    Thanks Walt! It feels good finally seeing it back in the car.
  30. triumph 1
    triumph 1
    Thanks. I was on the fence with the tubes but they’re growing on me. I have a nice set of ‘49 valve covers with the separators I plan on running with cloth covered wires eventually.
