Technical paint new aluminum radiator
Discussion in 'The Hokey Ass Message Board' started by bedwards, Apr 25, 2020.
  1. bedwards
    bedwards
    Can I paint a new aluminum radiator black as the original or should I use it as is?
    thanks
    Desoto291Hemi likes this.
  2. squirrel
    Yes, you can paint it black. They look so much more natural in an old car, that way
  3. bedwards
    bedwards
    thanks, that's what I was looking for. Should I clean it with anything before?
  4. southcross2631
    southcross2631
    The Southeast G***er group requires aluminum radiators to be painted black.
    I painted mine with Black engine enamel . just wiped the tanks down with prep sol and sprayed it .
    squirrel, bedwards and Desoto291Hemi like this.
  5. Hey Southcross ,
    What kind of Hobart you got there,,,,,mine works great ?
    Some of the best money I ever spent .
    Tommy
  6. Pats55
    Pats55
    from NJ
    PPG: aluma prep It'll etch the aluminum and you will get much better adhesion
  7. rustydusty
    rustydusty
    I would recommend "zinc chromate" primer.
    pitman and bedwards like this.
  8. 51504bat
    51504bat
    LAROKE and bedwards like this.
  9. rbrewer
    rbrewer
    I used rustoleum flat back.
    lothiandon1940 likes this.
  10. lothiandon1940
    lothiandon1940
    Don't forget...........light coats just for the color and coverage. Don't overdo it and affect the cooling capacity.:)
    rockable, Slopok, bedwards and 4 others like this.
  11. JWL115C
    JWL115C
    I painted my aluminum radiator with rattle can lacquer. Good coverage on the tanks, but just enough on the core to cover. No primer coat and it looked and lasted.
    bedwards and olscrounger like this.
  12. 42merc
    42merc
    I wiped mine down with lacquer thinner then sprayed with VHT epoxy flat black. Looks good & resists chipping.
    bedwards likes this.
  13. Blue One
    Blue One
    from Alberta
    rbrewer and bedwards like this.
  14. Bandit Billy
    Bandit Billy
    Go on line and buy some entomologist's collection, paint the radiator black and while the paint is wet throw a jar full of bugs on it so it looks like it has been driven hard all summer. Radiator patina. Very cool.
  15. Blue One
    Blue One
    from Alberta
    Billy shame on you :D You shouldn’t give advice that you don’t follow yourself :D
    Bandit Billy likes this.
  16. rusty rocket
    rusty rocket
    I used John Deere muffler black. It’s expensive but works well. It drys fast and cures with heat.
  17. Bandit Billy
    Bandit Billy
    On the truck I used an aluminum radiator that has a stamped upper tank so it looks pretty much like a br*** and copper job. I considered painting it br***, then semi flat over the top of that and sand back through the flat paint on the edges and wear spots to reveal the br*** below. I decided not to but I think it would look cool....and I often give advice I don't follow, it's how I raised my children to be good adults. :cool:
    Blue One and DIYGUY like this.
  18. el Scotto
    el Scotto
    from Tracy, CA
    Chicka chicka 1 2 3
