GARAGE ART: What'd you build?
Discussion in 'The Hokey Ass Message Board' started by neonloverrob, Oct 28, 2009.
  1. BlownMerc
    BlownMerc
    from Jerome
    Had an extra Model A grill laying around.
  2. atch
    atch
    Can you drill into the back of the sealed beam and install an LED light in it? I don't know how to drill into gl*** but gl*** companies can do it .
  3. 23tee
    23tee
    from australia
  4. harley jim
    harley jim
    You can get a bit for your dremel that will drill a hole in it.
    That was my thought, put a LED in it
    That would be cool
    Sent from my SM-A102U using Tapatalk
  5. he is a force on any instrument....love to hear him play
  6. Deuced Up!
    Deuced Up!
    I made my daughter the garage version of a Faberge egg for Easter. 20200412_101650.jpeg
    Sent from my SM-G970U using The H.A.M.B. mobile app
  7. Deuced Up!
    Deuced Up!
    And for my sister who loves Angels, a pretty cool piece of yard art. Check out that baby moon baby! Lol
  8. saltflats
    saltflats
    from Missouri
    I have been missing my are little dog that p***ed awhile back so I have been in the junk parts dog building mode.
    I sure miss my little buddy. :(
  9. olds vroom
    olds vroom
    Now that’s cool
  10. Moon50F3
    Moon50F3
    Thought about it. Actually I was thinking I’d have to cut the back off at least to get the filament and all out. But a small hole would be more do-able. I really do want to see it lit up. Do you suppose the bit I’d need is diamond tipped?
  11. Moon50F3
    Moon50F3
    Might try. I want to see it lit
  12. harley jim
    harley jim
    I think it was garnet. I think dremel still lists bits and uses on the internet. I used to drill holes in Jack Daniel's bottles with it. Practice on an old light to get the hang of it
    I bought some LEDs to redo the lights in my 64 C10 dash and bought some on amazon not much bigger than a pencil eraser.
    It would look good lit up
  13. Hellfish
    Hellfish
    Here's another Bluetooth speaker I built. 94258067_3233889223302425_9148281843718553600_o.jpg 94760129_3233889253302422_6723099483103559680_o.jpg
  14. 4speed411
    4speed411
  15. selectedgrub
    selectedgrub
    Wow Alot of good stuff here.
    Thanks all for sharing.
  16. Lone Star Mopar
    Lone Star Mopar
    You can buy a spade style gl*** and tile bit for under 10$. They're usually good for at least a few holes before they wear out.
    Sent from my LM-Q720 using The H.A.M.B. mobile app
  17. 1pickup
    1pickup
    Texas plates. Some old bolts. Drank some Lonestar beer. Here's the result. I call it the "Lonestar."
  18. PoTaToTrUcK
    PoTaToTrUcK
    Going to make this old motorcycle windshield into my pandemic screen for my office at work.
  19. just finished this flamin 3 string cigarbox geetar sittin on littles way kool cl***ic Ford...wide whites and flames...
    Okie Pete and ct1932ford like this.
  20. Speed~On
    Speed~On
    I have quite a few Model A grill shells. I restored this '31 shell and framed a photo of my Model A. (Shadow box style) It's hanging in my office.
    Excuse the glare off the gl***.
    Okie Pete, FRANK GRELLE, putz and 9 others like this.
  21. Speed~On
    Speed~On
    I just finished making this....this....whatever you want to call it. It's a display....i mean a board....or a wood/aluminum frame that holds my vintage race helmet.....**** I don't know.o_O I made this from scratch....but I have no idea why.
    Okie Pete, Big Dad, putz and 7 others like this.
  22. KevKo
    KevKo
    from Motown
    Here is a lamp I made from a swap meet carb. Base is oak plywood leftover.
  23. It looks like this may be the place to ask. I have about 5 feet of wooden waterpipe that has been in the ground for 100 years and have no idea what to make out of it. It is in very good shape for it's age. About 8" dia and has steel wire wrapped around it. All I can think of is a floor lamp but the wife does not like that idea, any others?
  24. Hellfish
    Hellfish
    Post a pic
  25. 20200526_133135.jpg 20200526_133146.jpg Found a 1 foot long section, but it is just 7 strips of wood joined around to make a pipe and has wire wrapped around it to hold it together.
  26. KevKo
    KevKo
    from Motown
    How about a Tiki? Can either carve part of it, or weld stuff to the wire cage.
    46international likes this.
  27. That's a good idea for the short pieces but for the 5 foot long one? guess so....
  28. guthriesmith
    guthriesmith
    Helped build this sign for Sid Drapal to hang inside his shop. B-Scott had done some t-shirt artwork for Sid with the skull and axle in its mouth. Then, Sid found a skull that was used in Pirates of the Caribbean as a prop while out at Pomona swap meet. So...he needed some arms and “Nostalgia Sid’s” to tie it all together. I decided drawing skeleton hands in CAD to cut it out on the waterjet was not as easy as it looked. :D Turned out pretty cool though.
  29. Almostdone
    Almostdone
    Not sure if this qualifies, but it’s a bit artsy and it is in my garage. I used some old push rods for storing the dies.
  30. uncleandy 65
    uncleandy 65
