Projects 1932 Ford Sedan build
Discussion in 'Traditional Hot Rods' started by IronFord, May 1, 2020.
  1. IronFord
    IronFord
    from NoDak
    I have been working on this car off and on for the past four years. I fully admit this project shouldn't have taken this long but life happens. I haven't started a build thread until now because I didn't want to drag it out forever without updates. The car is really close to being on the road so I have decided to start a build thread. I'm hopeful that some of the car events this summer won't be canceled. This is my first build and I think it's turned out well.
    The information on HAMB has proven invaluable to me. Guys like Dennis Lacy, NealinCA and B*** have been huge influences on me throughout this project. With that being said, this is my 1932 Ford sedan.
    Deuce Pics 001.jpg Deuce Pics 002.jpg Deuce Pics 003.jpg Deuce Pics 005.jpg IMG_0589.jpg IMG_0591.jpg IMG_0682.JPG IMG_0784.JPG IMG_1283.JPG
    The sedan came from my neighbor's farm a half mile from where I grew up. I remember riding the bus and seeing the grill of the car sitting in the machine shed.
    I have history on the car from mid-1950s. The sedan was, at some point, purchased by a farmer in western ND and driven back to eastern ND. Eventually, the farmer decided that it was no longer needed as a car. So the decision was made to turn the car into a spray coupe. His intentions were to cut the back of the body off and mount a sprayer. After inspecting the frame he decided it wasn't heavy enough for this and the car was parked in the barn.
    Dennis bought the sedan from the farmer around 1957. He graduated from Nome ND in 1959, I think. He's the one that added the pink (now faded white) paint on the outside of the car. He also added the pink interior. He told me that the girls really liked it! There is a large picture of the car with a few girls standing on the running boards pulling away from the school in the 1959 year book. He also told me he sent a picture to the Ford Times magazine. He said it was published in the back of the magazine in the late 50s. (I have never tried to find this pic) Dennis kept the car until I bought it in 2001. He wanted to fix the car up but never got very far with it.
  2. IronFord
    IronFord
    from NoDak
  3. IronFord
    IronFord
    from NoDak
    Greg Haynes of Anson dropped axles, dropped the original heavy axle to the car. downsized_1229041534.jpg
  4. IronFord
    IronFord
    from NoDak
    First time the body was taken off the ch***is.
  5. IronFord
    IronFord
    from NoDak
    The front crossmember was badly broken. I built a jig from good 32 crossmember to rebuild my original. I added a model A center while I was at it. I also changed the rear crossmember to a Model A. If I ever want to run a quick change in the future. The rear crossmember was also widened to the frame rail width and riveted. The rear kick up was boxed and C-notched. I also made a removable plates that tie into the boxing plates and the K-member legs.
    IMG_0567.JPG IMG_0621.JPG IMG_0624.JPG Img_5087b.jpg Img_5117b.jpg IMG_1025.JPG IMG_1026.JPG IMG_1035.JPG IMG_1036.JPG IMG_1037.JPG IMG_1038.JPG IMG_1040.JPG IMG_1043.JPG IMG_1044.JPG
  6. IronFord
    IronFord
    from NoDak
    The original plan for the car was to be flathead powered. Unfortunately with the flathead I didn't have enough clearance from the oil pan to the ground. So I will be running a 1958 283 with 10.5 pistons, ported X heads, 300hp 327 cam, tri power and early Hedman Hedders. I know I'll never be able to use all of it with the 39 trans and the Columbia but it should still be fun. IMG_7603.JPG IMG_E7608.JPG IMG_7612.JPG
  7. IronFord
    IronFord
    from NoDak
    32 Ford V8 motor mounts modified to work on an SBC. Rear shock mounts made from some left over wishbone. Steering arms dropped and a 1937 Hudson steering box that was rebuilt by NealinCa.
    IMG_1063.JPG AFRJ4393.JPG FCCL0501.JPG JHOZ2295.JPG SPTK4247.JPG PYHV4163.JPG VVIF0954.JPG JQZV7360.JPG
  8. IronFord
    IronFord
    from NoDak
    Modified headlight bar and F1 shock mounts. I had to cut up the floor in back for clearance. So this is what I came with. I tried to keep as much of the original floor as I could. I also modified the original trans cover to work with the 39 trans. RZVH1009.JPG BXSS2732.JPG QBJZ8930.JPG IMG_9127.JPG IMG_9129.JPG IMG_9130.JPG IMG_9156.JPG RTKK3448.JPG PLOW5827.JPG
  9. kidcampbell71
    kidcampbell71
    Clicking off every box .. thus far. Dig it. 3 thumbs up.
    lothiandon1940 and IronFord like this.
  10. IronFord
    IronFord
    from NoDak
    I've never done any kind of exhaust work before making the collector for the Hedman Headders was challenging. I also started making the exhaust system at the same time.
    MMZJ7177.JPG KZLS3671.JPG GFDO6005.JPG WHFN8819.JPG LSTI3200.JPG LLOU0066.JPG
  11. IronFord
    IronFord
    from NoDak
    The brakes are MT backing plates and drums. I mounted the master cylinder below the K-member. I guess I didn't take any pictures of how I modified the pedals. Made up the brake lines.
    Tim_with_a_T, dwollam, texkbc and 4 others like this.
  12. triumph 1
    triumph 1
    Nice work, I’m fond of deuce tudors.
    343w and IronFord like this.
  13. Thanks for posting. If I had that car, I'd be doing it the same way.
    IronFord likes this.
  14. IronFord
    IronFord
    from NoDak
    I know absolutely nothing about fake patina. I didn't think I would be able to pull it off on the frame since I had areas of bare metal. So I had a good friend of mine paint it for me. The body will be painted at some point but I'll be running the body as is for now. At this point I was rushing to try and finish the car by Memorial day 2019 for a friends wedding. Ch***is ***embly and my take on a modified Ford E-brake system.
    RRIS2801.JPG IMG_0911.JPG IMG_0913.JPG IMG_0926.JPG IMG_0775.JPG IMG_0776.JPG IMG_0777.JPG IMG_0779.JPG
  15. IronFord
    IronFord
    from NoDak
    I’ve been working on the car everyday for the last four weeks rebuilding carbs, bleeding brakes and doing all of the little stuff. We put the body on for the last time on Tuesday. That’s where I’m at currently.
    E51FBE27-B185-4024-9863-31D9DB8E3E33.jpeg 2878090A-E687-44DE-803F-4B07BB41EFDE.jpeg 3D267170-2BF1-438E-9201-740E9A7039E5.jpeg BC912356-2C54-4C43-8669-A78AA82B3401.jpeg 581AC36A-2D85-4D74-A2DF-A260FDFE94E5.jpeg 2F3020FB-B3CB-4911-9414-04F8C752130D.jpeg BB262FD2-9EF5-4CF8-A3F1-F9EEEA30C973.jpeg A37414FA-CE39-40EC-BB0F-86F812BECFA5.jpeg
  16. brady1929
    brady1929
    Nice hot rod.
    IronFord and kidcampbell71 like this.
  17. Great stuff , I'm in.
  18. koolbeans
    koolbeans
  19. 40Standard
    40Standard
    from Indy
    interesting build, always wanted a 32 sedan hiboy
  20. Malcolm
    Malcolm
    from Nebraska
    Looking good!
  21. 51box
    51box
    from MA
  22. HOTRODPRIMER
    HOTRODPRIMER
    Good looking car. HRP
    deathrowdave and IronFord like this.
  23. Stovebolt
    Stovebolt
    Love the build, It's a great reflection on those that influenced the build. you've taken their builds, and blended their finer points into your build.
    now what ever happened to that banger??? :D:D:);)
  24. 32partsguy
    32partsguy
    from DFW,Texas!
    Lookin' Great!
  25. IronFord
    IronFord
    from NoDak
    The banger was sold to a friend of mine that has another 32 tudor sedan he wants to restore. I probably should have kept it but I was never going to use it.
    Stovebolt likes this.
  26. WC Durant
    WC Durant
    Ch***is looks great, the stance is really nice.
  27. x77matt
    x77matt
    Wow! Love this!
    kidcampbell71 and IronFord like this.
  28. continentaljohn
    continentaljohn
    Sweet Tudor thanks for sharing the build
    kidcampbell71 likes this.
  29. ROBRAM
    ROBRAM
    Perfect patina! I wouldn't change a thing about the body.
  30. hotrodA
    hotrodA
    Winner!!
    Not that I'm biased, with a similar one in the garage.
    Yours is better!
