Technical What is the easiest way to get a title?
Discussion in 'The Hokey Ass Message Board' started by ratfink, Apr 16, 2020.
  1. gimpyshotrods
    gimpyshotrods
    Well, the still are required by Federal law to report their data to the NMVTIS, on a regular basis, which means, if someone pulls some kind of stunt using a number that is active in another state, it won't matter that Iowa is not the one keeping the records.
    For perspective, there are fewer people in Iowa than there are in the City of Los Angeles. Not the LA Basin. Not the LA metro area, just the namesake city in the center of all of that. The LA metro area alone, has 4x the population of Iowa, and it is not the only large metro area in California.
    It already happened here, and in-time, it will happen to every other state. The computer systems used will break down, and be no longer serviceable. When that happens even the most bare-bones, entry-level systems sold to the smallest states, will have the capacity to store every present, and potential do***ent. It is not speculation, it is Entropy, and the Second Law of Thermodynamics. Neither cares what your opinion of either is.
  2. dirty old man
    dirty old man
    Man, this **** gets deeper every time it comes up, regardless of what state of residence the OP is in, or what state the respondent calls home.
    lothiandon1940, chopped and MO54Frank like this.
  3. rudestude
    rudestude
    How about this deep.....
    Look in the glove box...you migjt get lucky.....
    Some times if you can get the right person behind the DMV counter its not difficult at all..a few years ago I went with a friend to the dmv in Oregon he was from Washington state .
    He had bought a 64 Fairlane that was registered in Oregon and the last owner had signed it off but in the wrong location so we went to a Oregon DMV to ask what to do.
    We get to the counter and told the guy that he, my friend, had bought this car and he wentto the Washington dmv to get it transferred but they couldn't do it because it was not signed off properly...the guy looks at us then looks at his watch and says its about lunch time ...if you two want to go get some lunch and when you come back we can get this figured out...we kind figured ok..then he says here's a pen, just in case you happened to run across the previous owner ...she needs to sign and date it right here as he points to a line on the paper.......
    You know ..we found that gal having lunch at the same place as we did ...went back to dmv the guy says great you found her..finished the paper work ...no problem.
    That guy was cool...
    Sent from my SM-T387V using The H.A.M.B. mobile app
  4. theHIGHLANDER
    theHIGHLANDER
    A client had me build him a whole new car from all aftermarket stuff. He had a receipt for the engine and trans and an MSO from American Speed for the body. Had his paper work from Lobecks for the frame. That stuff plus an inspection from a cop who was more impressed looking at his and the other cars in the shop made it an easy thing to do. His sign off allowed for a state issued VIN, that got him a ***le from MI.
    And he didn't have to win an election...:rolleyes:
  5. JUSTIN PERSINGER
    JUSTIN PERSINGER
    Your state is the one who sets the rules in this procedure. There maybe several options other than a bonded ***le. Do your research, I know in Missouri we have abandoned vehicle applications, bonded ***les, Antique rebuild which requires a major modification i.e cowl or frame replaced, and some others.
    Also, you may have the declaratory judgement option too, which is basically you take your bill of sale with matching VIN # and hire a lawyer, Sue the previous owner, and the DMV for a right to ***le and go in front of a judge and then he decides ownership and grants you the judgement. Then you take that judgement to the DMV and a new ***le is issued. So good luck in your process, as it is a long one.
    Sent from my XP8800 using The H.A.M.B. mobile app
    Boneyard51 and dirty old man like this.
  6. Boneyard51
    Boneyard51
    That’s what I’ve said, many times, it’s not what a clerk “ can “ do..... it’s what a clerk “ will” do! I’ve seen it in person , also.
    Bones
    VANDENPLAS and rudestude like this.
  7. Boneyard51
    Boneyard51
    I did that one time on a boat , here, in Oklahoma but I didn’t need a lawyer. I knew the District Judge, told him of my problem , he wrote out a piece of paper and I took it to the DMV went through, no problem! But, that has been many years ago. Oklahoma has changed a lot of laws regarding tags and ***les recently. Not sure what you can or cannot do now. Luckily, I’m not playing with any new “ old” cars now! But my friend and I are opening up his salvage yard, again! So I’m sure I will be learning, soon! Lol
    Bones
    VANDENPLAS likes this.
  8. HOTRODPRIMER
    HOTRODPRIMER
    The best & easiest way to get a ***le is when you purchase the car one comes with the sale. HRP
    VANDENPLAS, 51504bat, 5window and 3 others like this.
  9. chickenridgerods
    chickenridgerods
    from DSM, IA
    That's cool and all, but you seem to be failing to realize the enormity of the number of cars that were registered prior to 1996 and wouldn't be in that system. That is the point. Some 1933 Whatchamacallit that had its last ***le transfer in 1955, and sat in a field behind grandpa's barn since 1961 won't be in such a system. That's often the type of car for which people here are trying to obtain ***les.
    Hard drive space isn't the issue. Scanning technology isn't the issue. The lack of source material is the issue.
    Why are you afraid of the ***le saying "bonded" across the top. A vehicle with a bonded ***le can be purchased, sold, or traded just like any other, and when the bond period is up the ***le will no longer be "bonded".
    What's possible in other states is irrelevant to your situation in Wisconsin. Follow the Wisconsin process and be done with it.
  10. LOU WELLS
    LOU WELLS
    from IDAHO
    Very Informative Thread And Still No ***le?...They Can Be A Challenge...
    lothiandon1940 likes this.
  11. 340HilbornDuster
    340HilbornDuster
    Found this on Craigslist.....THIS CAN'T BE RIGHT!?
  12. dirty old man
    dirty old man
    Dealing with that guy just might get you free admission to the cross bars hotel:eek:
  13. Mr48chev
    True there. I still cannot understand why people think that they have to cheat on the ***le thing and probably pay three times what they would if they just went though the steps to do it legally.
    I've got two ***les to my OT truck in my safe, the good ***le in my name and the original ***le that was in my uncles name that had a LOST ***LE application filed on it and is just a nice piece of historic paper that is absolutely worthless otherwise. Show up at the DMV with it and you are going to find out that it has no value as it has been replaced.
    Guys need to once and for all quit posting what happens in their damned state (s) that has no bearing on what state the person asking the question has to do as all states are different.
  14. gimpyshotrods
    gimpyshotrods
    Hubris leads to nemesis.
    People need to stop taking risks that endanger not only themselves, but our entire hobby.
  15. Hudson31
    Hudson31
    Pb
  16. 5window
    5window
    Lead?
  17. gimpyshotrods
    gimpyshotrods
    That's what I was thinking.
    5window likes this.
  18. Some of these horror stories have originated as the laws dealing with stolen cars and interstate regulations have changed over time. The feds would make a law, and the states had to p*** an enabling law to bring them into compliance. But the states didn't always get it right the first time, or sometimes even the second or third time. As demonstrated by current affairs, legislators aren't always the brightest people. You'd get ******* matches between agencies as to who was responsible, or they'd fail to give clear direction to the affected agencies. You'd run into clerks that didn't know how to do whatever had changed, and weren't interested in learning. There could be times when you were sure the only law operating was Murphy's... I even had a situation similar to post 93, although in my case I ran into the widow's husband...
    As to the national database, it's real. Washington state used to require every out-of-state vehicle to be inspected, all they were checking for was hinky VINs. These days, if you have a clear ***le, it's just paperwork. You will get flagged for inspection if the vehicle is from a no-***le-if-its-too-old state or if it's a 'conditional' ***le of some sort (salvage, rebuilt, etc) or if the declared value is out of line, but if everything is on the up-and-up it's no problem. The only ***les I know they won't accept is a Maryland 'certificate of destruction' ***le, which I've been told can only be transferred in a few states.
    Like Gimpy says, you DON'T want to get caught playing ***le games. An wheeler-dealer acquaintance I used to know who skirted around the edges of the law (and got caught a few times) tried that, and he not only lost the car, but also a even bigger pile of money in fines and legal fees in keeping his dumb *** out of jail. I heard through his ex one of the conditions of his settlement was he could only buy vehicles in-state and from licensed retail dealers, no auctions or private sellers. Pretty sure he's out of the hobby....
  19. Darin Younce
    Darin Younce
    IN South Carolina, if you purchase a vehicle from Georgia, to get a ***le , you need a bill of sale and a current registration from Georgia.I had both those when I Bought my 39 ford pickup. Seems there was some other simple form but I did what they said and got a ***le .The ***le will come with the words ( forget exact phrase) Unknown Liens or something similar but after 4 months you can go back and they will give you a clear ***le. Unless laws have. Changed , I understand folks have gotten friends , relatives or others in Georgia to buy their car, register it and sell or back then do as I did and it is legal. sorta like what the gentleman from Kansas above suggested.
  20. vor
    vor
    The easiest way to get a ***le in the UK is to give a member of parliament a cash bung and you will be a lord in no time.
  21. Elcohaulic
    Elcohaulic
    I have found that when dealing with the state, if you go in there with a good at***ude and realize they are there to help you and not hurt you, things usually work out well..
  22. chopped
    chopped
    Four pages and the answer was on page one. My suggestion would be to become a citizen of the Conch republic and get one there. But that's just me.
  23. 5window
    5window
    I bought an Ohio '31 A with a PA ***le and VIN tag. When I re -***led the car in my name, Pennsylvania DMV abandoned/vacated/nullified the existing ***le and issued me a new ***le with a completely new VIN tag that matches no other number on the car. From previous attempts to understand the DMV, I mounted the new tag and drive the car. :)
  24. Mr cheater
    Mr cheater
    TrailerTrashToo likes this.
  25. This right here “ Felony “
    Most folks think it’s just a bit of paper no big deal, until it becomes one.
    a story from when I was a snot nosed 14 year old.
    Out after school with some friends and a postal van was parked filling up those big mail boxes for a town house complex.
    Well three of my buddies get the bright idea to steal it for a joy ride!
    My buddy Phil and I turned tail and walked down the street as if we knew nothing.
    Well those three bozos got caught and ended up in court. Judge told them
    What they did was a felony offence and IF he wanted to throw the book at them he could and essentially **** there lives.
    He chose not to.
    It might look like a simple thing but if you get caught and don’t get a sympathy judge /cop etc.
    A couple months of paper work can turn into a huge pain right on the inside of your ***hole.
    Not a good place to have pain!
  26. Sonofabob
    Sonofabob
    While Kansas is a "Bill of sale" State. Meaning you can buy a antique car with a bill of sale and be able to get it ***led. (The VIN has to match the bill of sale and no current ***le available.) Sold multiple antique cars in Kansas. Most had good ***les, some were projects that did not. In your case I believe that the best way to get a ***le is to do it legally and by the letter of your states laws.
    dirty old man likes this.
  27. Deuce Lover
    Deuce Lover
    Years ago (1990's) there was an ad in Hemmings for ***les with rusty frames,$125.The frames he said were toast but had the ***les.The seller was in NY. Robertson's Salvage if I remember correctly.A friend of mine bought one for his '32. Well the VIN number was not even close.It was more like a 1937.My buddy tossed it.
  28. southcross2631
    southcross2631
    Built a Morris Minor with a old Tn ***le . Hadn't been registered in over 20 years.
    The original owner whose name was on the ***le couldn't get a replacement ***le because it was no longer in the Tn computer system.
    Sold the car for a dollar to a friend in Ga. Had it inspected by a Ga.. cop. Bought a tag and he turned around and sold it back to me for the same dollar. Took the bill of sale and the registration to the DMV in Tn and was issued a Tn. ***le. DSCF0936.JPG
    A little run around ,but it worked . The car was inspected by the state of Florida when I moved there and was issued a Florida ***le. Sold it it to a guy in Minnesota and he got a legit ***le.
  29. GeeRam
    GeeRam
    Only if your're a British citizen (or a citizen of some of the Commonwealth countries that allow the honours system) ;)
    Bandit Billy likes this.
  30. 5window
    5window
    Nice car!
