Technical Early front mount 265/283 in a 41-48 Chevrolet Car
Discussion in 'The Hokey Ass Message Board' started by pzary3233, May 6, 2020.
  1. pzary3233
    pzary3233
    As the ***le states, I see lots of info for getting a side mount SBC into a 41-48 Chevrolet... However, I am wondering about the early motors with front mounts. I have a 283 4bbl motor from a 57 that would be a good candidate for this car and keep the late 50's early 60's vibe I am going for.. I'd ***ume fab up some mounts and use stock 55-57 type stuff to make it fit? I know this had to be done back in the day... What was done?
  2. hemihotrod66
    hemihotrod66
    Yep it was done a lot before side mounts came to be...In fact Hurst made a front mount that uses flathead Ford motor mount biscuits...
  3. pzary3233
    pzary3233
  4. 325w
    325w
    Might run into an issue running the stock fuel pump. Real 57 283 has no side mount boss I think
    hemihotrod66 likes this.
  5. pzary3233
    pzary3233
    Correct I can modify the hurst style mount to make that work. Correct NO side mounts on a 57 v8.
  6. The front mounts for SBC were still available from marine supplies a few years ago.
  7. 41rodderz
    41rodderz
    from Oregon
    I have one somewhere out in the shop .
  8. 24riverview
    24riverview
    Better view of the AC-40 adapters.
    20200511_085834-1.jpg 20200511_085849-1.jpg 20200511_085903-1.jpg 20200511_085915-1.jpg
    scrap metal 48 likes this.
  9. pzary3233
    pzary3233
  10. rusty1
    rusty1
    ...if you go with front mounts, you should also use bellhousing mounts,...not just a trans tailhousing mount
