Technical how to remove 46 Ford/Merc clock hands without damage
Discussion in 'The Hokey Ass Message Board' started by Do it Over, May 8, 2020.
  1. Do it Over
    Do it Over
    from NYC, NY
    So I'm converting my dash clock into a tach. Got it mostly worked out except for removing the hands. Those ****ered seem glued on. The hands are thin stamped metal and won't withstand my attempts to liberate them. Is there a tool available or I could make? Are they glued on ? I only need the long hand. Anyone have one for sale?
    Thanks
  2. squirrel
    I expect they are just a light press fit on a very slightly tapered shaft, and will pop off if you can figure out how to pry the very center of the hand (the hub) off the shaft.
    Good luck....the last time I tried to do something like that with a 70ish year old part, things broke.
    Do it Over likes this.
  3. Warpspeed
    Warpspeed
    Always just a tight press fit.
    Usual tool people use is an ordinary kitchen fork !!
  4. X38
    X38
    I watched a watch maker do it with two screwdrivers. One from either side. But there are special little fork lever things to do the job.
  5. Reidy
    Reidy
    Do it Over and X38 like this.
  6. Warpspeed
    Warpspeed
    A proper jewlers puller is obviously going to be best.
    But if you slip a kitchen fork under the clock hand, and either pull directly, or lever against something wedged against the clock face, it should just pop off.
  7. gatz
    gatz
    I've used 2 razor blades, one on each side to gently pry it up.
    These are the "industrial" kind
