History Mickey Thompson Aluminum Pontiac Block
Discussion in 'The Hokey Ass Message Board' started by Little Wing, Dec 2, 2008.
  1. Little Wing
    Little Wing
    from Northeast
  2. Fishtail8
    Fishtail8
    Betcha that'll go cheap, sounds like something the guy who bought the Tempest needs, or Steve from Pontiac Heaven...
  3. Look like a cool piece but, it'll coat a real fortune to have some machine it ( unless you have the resources to do it yourself ).
    I have an alum Ram Air V block I am machining then I am building 2 custom forged billet blocks for my Pontiac Top Fueler.
    Steve Barcak
    www.pontiacheaven.org
    <DIR>Hosting 11th annual Pontiac Heaven, show, swap, drags, party and all around good time. Saturday April 4, 2009 at Speedworld near Phoenix, Az
    Also hosting- 7th annual Nostalgia drags, show and swap coming Sunday April 5, 2009 to Speedworld. Phoenix, Az
    </DIR>
  4. monsterflake
    monsterflake
    i was waiting to see who'd post that...
    kidcampbell71 likes this.
  5. I have a friend who bought a rough cast aluminum RAMAIR V block. He had a HELL of a time getting it machined...it didn't have any indexing holes...
  6. Little Wing
    Little Wing
    from Northeast
    $5000...wonder what the cost of actually being able to use it is,,or will someone just hide it away and sell for more down the road
  7. axle
    axle
    from Drag City
    Wish i would of went to those auctions back in the 80's when i had the chance !
  8. HighSpeed LowDrag
    HighSpeed LowDrag
    from Houston
    I love me some Pontiacs.
    If I had the "extra" scratch laying around, I'd own it just to say that I did.
    Investment wise its a good deal.
    Use it? Never.
  9. My guess why that block was never machined and finished is because is was not up to task. It even looks weaker than the iron blocks of the time. Based on all that, I think it was a reject.
    Here is the alum V block I am working on. It is a much beefier design. I bought it as a raw casting with only a cam hole. built all the tooling to do it. So far the mains are in, align bored, oil pan bolts, timing cover and bellhousing. Still have to do the lifters, cyl bores, dist hole.
    Steve Barcak
    </DIR>
    Deuces and kidcampbell71 like this.
  10. 55chieftain
    55chieftain
    New aluminum Pontiac blocks are under 5k , machined. Someone really wanted this one pretty bad. I would never put this in the Tempest sd racecar that was just sold recently, it would be worth alot more with a correct sd 421.
    Deuces likes this.
  11. 51 Hemi J
    51 Hemi J
    Steve,
    Is that a main girdle on your block - was that provided with the block? Any more info out on the net about this piece?
    EDIT: After looking on your site a little more - this is probably a custom piece you machined.
    Thanks,
    Neil
  12. Neil,
    I bought the block raw, in a similar condition as the one on ebay. I did all the work ( or had it done to my specs). I also desigined and had built this 6 bolt main lower end the ties all mains together and uses crossbolts. I have 3 of these lower ends.
    I am now comtemplating selling this block. It would be without the main ***embly.
    I bought this block in 2000 when there was no other option at the time. It was destined for my AA/Fueler dragster. since then, other options have materalized including to 2 block forgings I had made. , The forgings are better suited to my needs.
    Not sure if I will do ebay or not.
    Steve Barcak
    </DIR>
  13. Algon
    Algon
    There were two of the early 59-60 M/T aluminum blocks in Hemmings 12-13 years ago. They had Iron liners in the bores, neither was fully machined, and one had the liners "stuck" half way in. I put money on them after working a deal but the guy kept changing the deal, and claimed he had higher offers. Dude, ripped me off pretty good, if I ever make it out to California this the first person I'm going to look up.
  14. tjs44
    tjs44
    Those 2 M/T alu hemi blocks are in my possession.Tom
    Deuces, egads and 67drake like this.
  15. tjs44
    tjs44
    pic of one of the blocks that has the sleeves
