Technical Stikit vs hookit disc backer pads
Discussion in 'The Hokey Ass Message Board' started by X-cpe, May 10, 2020.
  1. X-cpe
    X-cpe
    A question for the body men. Just received a new backer pad for my air grinder. I use Stikit discs. They sent a Hookit pad in a Stikit box. (3M) The surface of the new one feels and looks like the Stikit one that I have, save for a lot of minute cuts in the surface that I can't feel. Can I successfully use Stikit discs on the Hookit pad.
  2. Texas Webb
    Texas Webb
    Try it.I like both but the hook allow on/off/on again easier.
  3. HotrodHR
    HotrodHR
    You can try it but I'm not sure how long stickits will stay on the hook and loop pad.
    Now might be a good time to switch to hook and loop... I did 20 years ago, and never looked back.
  4. K13
    K13
    A hook it pad has actual hooks on it like one side of velcro not just a bunch of slits. Your description does not sound like a hook it pad. This is a hook it pad. 1589170000616.jpeg
    Sent from my SM-G950W using The H.A.M.B. mobile app
  5. 41rodderz
    41rodderz
    from Oregon
    I have both and the stick on won’t stay on my hook pad.
  6. OLDSMAN
    OLDSMAN
    Stik it needs a smooth pad to stick. They won’t stay on a hook it pad. I think if you try the hook it pad you will like them
    guthriesmith likes this.
  7. oldiron 440
    oldiron 440
    I like both but you need to switch backing plates or have two of everything. I like the 320 for my finish DA, I believe it cuts better longer. The disks are expensive.
    Lloyd's paint & glass likes this.
  8. X-cpe
    X-cpe
    Thank-you everybody for the responses, especially K13 with the picture. I didn't know what a Hookit pad should look like. There was a sneaking su****ion in the back of my head that what I had wouldn't hold a Hookit disc. What they sent me is a Stikit pad, it just had the wrong label put on it at the factory.
