Hot Rods GENERATOR NATION post your generator pics
Discussion in 'The Hokey Ass Message Board' started by pecker head, Feb 6, 2019.
  1. Stogy
    Stogy
    :rolleyes:...this pic is optically interesting and of course includes a generator...;)
  2. Desmodromic
    Desmodromic
  3. rod1
    rod1
    Stogy and Truck64 like this.
  4. pecker head
    pecker head
    7390ED58-1AC5-43BD-B1F6-D0132F7B2410.jpeg 9DA2F1B8-5AD0-4683-AE09-610F3D2F5FC1.jpeg C9DFE6AF-5420-43AB-9E21-E9B39E9B8429.jpeg Just getting started on this set up, gonna wind up building new brackets.
  5. Stogy
    Stogy
    I see what your doing...this will allow a full hood without a Blister...The Belt will be in a interesting profile when tightened up...I'm curious about slippage. Does a generator have resistance when under running load?
    Happy New Year Pecker Head...:D
    pecker head likes this.
  6. pecker head
    pecker head
    Always heard you run generator belt loose.??? And yes full hood.
    Stogy likes this.
  7. Stogy
    Stogy
    Well mines going on 4 Years now without a burp or fart so I must have it in a sweet spot...That's good to know...
  8. dirty old man
    dirty old man
    Didn't have a camera that day in 1966 that I slung the segments out of armature on a generator on my SBC powered '53 Studebaker coupe, but that was the last day I ran a generator on ANYTHING.
  9. pecker head
    pecker head
  10. seabeecmc
    seabeecmc
  11. seabeecmc
    seabeecmc
  12. Paul
    Paul
    Editor
    With cover
    and one without
  13. Sorry it’s so filthy but here you go anyhoo... D159BA06-F1C7-4AFC-9760-360B00DE4C2B.jpeg 564B607C-A93F-4154-A927-E0E6AB96CFB4.jpeg
  14. pecker head
    pecker head
    chryslerfan55 and cactus1 like this.
  15. Thanks. I will grab some pics tonight. The bracket is a “Jitney Jake Jacobs” piece that I don’t think is available any longer? I do have some measurements I can send if it looks like something that will work for you.
  16. MO54Frank
    MO54Frank
  17. goldmountain
    goldmountain
    Here is a bracket that mounts like cactus1's setup. It consists of a www.welderseries.com alternator mount kit #WS2392 for the hard to make pieces and a fabbed rear support. IMG_1420.JPG
  18. Paul, 30tudor, chryslerfan55 and 2 others like this.
  19. ckdesigns
    ckdesigns
    from Ogden,Utah
    I know it’s an alternator but it mounts like a generator and plays one on TV. I built the mount off where the fuel pump mounting location and used the Flathead bracket on the alternator. Welded pieces of key stock to create a channel for the Flathead bracket. I only have a few hundred miles on it but it seems ok so far.
  20. uncleandy 65
    uncleandy 65
  21. pecker head
    pecker head
    6FA62FEE-398F-4342-AAB3-5C3097DAF6D1.jpeg D10B5813-ED31-4E48-9BDD-58C68AE75D0A.jpeg B809B69A-C134-45C3-8469-158A0455C288.jpeg 760C8AC6-7F92-4D3B-991D-628A1A003E60.jpeg 61 283 . Not wired up yet.
    chryslerfan55, Stogy, cactus1 and 4 others like this.
  22. pecker head
    pecker head
    EFFB3D67-8FFC-46C3-A37D-481F593DF6D4.jpeg All wired up and charging.
  23. old.hot.rodder
    old.hot.rodder
  24. squirrel
    Checking generator output on the T with the correct meter. 8 volts, fast idle not long after start up. I guess it's working.
  25. Justin in PA
    Justin in PA
    EF3BBF18-940D-4D5C-8261-7098D283F1DF.jpeg Not enough B field generators here...
    Stogy, sidevalve8ba and pecker head like this.
  26. Stogy
    Stogy
  27. alfin32
    alfin32
    from Essex, Ma.
  28. Thepartsbinguy1
    Thepartsbinguy1
    from Space
    Just put new brushes in this Delco generator. It does the job. 215AE720-8305-41EF-898D-9B046ECD168D.jpeg 85FC5981-83C8-4069-9D6B-1B8BE03B5B5E.jpeg E00B72CA-BCBD-41E0-B2E4-9BB43837412C.jpeg
    pecker head, Stogy and tb33anda3rd like this.
  29. Well, Due to my case of S.G.D. I can't show mine but it's there. photo 1 (2).JPG
    S.G.D. severe generator disorder
