Hot Rods Can mag wheel bolt pattern be changed ?
Discussion in 'The Hokey Ass Message Board' started by Belair1964, Apr 21, 2020.
  1. Belair1964
    Belair1964
    from Illinois
    9C889848-5779-4210-B043-C656C007B5CA.jpeg Thought I would finish the thread out. Machinist took a 1/8 crescent out and brought the pair to 5on5. Looks good. Works good. Balances good.
    quick85, swade41, 31hotrodguy and 4 others like this.
  2. slowmotion
    slowmotion
  3. So did you use Auto Machine ?
  4. Belair1964
    Belair1964
    from Illinois
    Actually I did not. Thanks for the tip. I called twice but the fellow who would do it worked at another shop and wasnt there all the time so I was able to source local. Worked out well. Was tired of the Supremes look. Added bonus was the weight of thos steel Supremes had to be 5-10 lbs per rim heavier. Rides different now.
    31hotrodguy likes this.
  5. 31hotrodguy
    31hotrodguy
  6. swade41
    swade41
    from Buffalo,NY
    Looks great and I wouldn't be worried about it one bit, was the cost reasonable?
