Hot Rods Help! Somebody With a Speedway Motors '27 Track T
Discussion in 'The Hokey Ass Message Board' started by Trethewey, May 12, 2020.
  1. Trethewey
    Trethewey
    I think I'd like to build a Speedway Motors '27 Track T, but I rilly need some measurements off the frame to see if what I have in mind is even doable. I've bought both Speedway's ever-so-informative, well-photographed build manual and Dennis Parks' book AND talked to Speedways' sales guys...
    ...and here I am wondering if somebody out there with the kit's frame & body could take some measurements for me?
    Ed
  2. 41rodderz
    41rodderz
    from Oregon
    Good luck .:) I can’t remember which mag but a few years back (Rod and Custom)? Did a Speedway T kit and I believe trying a low budget build . Maybe there was some info. in the article.
  3. Tim
    Tim
    from KCMO
    You may want to tell us what measurements you’re wanting ;)
  4. Trethewey
    Trethewey
    Thanks!
    I saved a Hot Rod Magazine that built one Speedway's T kits, but twasn't the '27 Track T "kit" I'm interested in.
    The Speedway Track T has a pinched-nose frame using a Vega steering box and cross-steer steering, limiting lower left side engine room as well as effective radiator space.
    While I'm using a widdle 4-cylinder wheezer in place of an engine, I'm still concerned about radiator/engine length and width fitment. Plus I'm building an engine startup/run-in cradle and I'd like to go ahead build the engine mounts and mount system and header now, as part of the cradle and setup, which will transfer to the actual completed go-kart, I mean "car".
    Eddie
  5. Trethewey
    Trethewey
    DO'H!
    Let's start with a pretty simple one--lower radiator extension clearance.
    Utilizing Speedway's front axle and steering packages, what is the clearance at full lock between the back of the front axle and the leading edge of the tie rod?
    I could cipher this'n out, or build a mockup out of wood and junk bolts--but I have no real exact idea of the kingpin/spindle angles at a real full lock.
    The radiator can only be 12-3/4" inches wide, so if I can build one that will drop down in that space 'tween moving axle and tie rod it would be (wait for it) cool! (sorry):rolleyes:
    Eddie
  6. X38
    X38
    And what might this be?
    Most anything is doable, but it really helps to have actual parts to mock up.
    Moriarity likes this.
  7. OLDSMAN
    OLDSMAN
    Yes you will need the actual parts for a mock-up. Guessing doesn’t work in this game
  8. Tim
    Tim
    from KCMO
    You’re not going to fit a radiator between a tie rod and the axle I can tell you that much right now. A lot of track nose cars out the Radiator in front of the axle. Depending on nose shape it may be slanted to fit with the top further back
  9. low down A
    low down A
    speedway's T kit car's are very basic simple affordable entry level car's it's up to the buyer or builder to bolt together as is or do your rocket science on it
  10. stillrunners
    stillrunners
    from dallas
    Or could the radiator be moved under the back turtle deck - with a fan ?
  11. justabeater37
    justabeater37
    Why can the radiator only be 12 3/4" wide?
  12. Phil1934
    Phil1934
    Civic half size radiators are about 14" wide and cheap
  13. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Easiest way to do things, is just do them (for me anyhow)
    If you do facebook theres several t bucket groups. Probably someone on there could get the measurement you need. BUT be prepared for 1 person to answer your question, and 50 others to tell you they have a big block with a blower and what radiator they have.
    Almost like the HAMB, ha!
    41rodderz likes this.
