Hot Rods THE INDUCTION THREAD
Discussion in 'The Hokey Ass Message Board' started by mad mikey, Dec 9, 2016.
  1. loudbang
  2. loudbang
  3. XXL__
    XXL__
    Crate full of Potvin...
  4. XXL__
    XXL__
    Fuel/air for the W...
    And fuel/AIIIIIIRRRRR! for the W...
  5. XXL__
    XXL__
  6. mgtstumpy
    mgtstumpy
    Took the air bonnet off to install some air-cleaners
  7. loudbang
  8. loudbang
  9. loudbang
  10. loudbang
  11. roseville carl
    roseville carl
    started with 2-2's then
    then
    then **** it off we go.......originally a broken four port off a 6-71, made a two port out of it
  12. loudbang
  13. loudbang
    Yellow Fang.
    Anyone got any idea on the "injector BOX"
  14. loudbang
  15. loudbang
  16. deadbeat
    deadbeat
    The fuel lines on some of these engines is pure art imho, cheers
    Stogy, Jet96 and loudbang like this.
  17. Dean Lowe
    Dean Lowe
    The riser box on the Yellow Fang appears to be just that, it raises the hat up from the blower. For why, I don't have a clue. Maybe Roo will give us an explaination.
    enloe and loudbang like this.
  18. loudbang
  19. saltflats
    saltflats
    from Missouri
    can someone tell me what's going on here?
  20. 64 DODGE 440
    64 DODGE 440
    from so cal
    One blower feeding both engines.
    Stogy, enloe and loudbang like this.
  21. Fordors
    Fordors
    @saltflats I don’t know how that duct received boost from the blower, but the rail is M/T’s running two 215” aluminum engines, the rear one is an Olds and the front a Buick. Here’s a later photo of maybe the same car but they switched the position of the engines and adapted a new blower set up. A close look at the heads shows the variation in the engines, but the 215’s did share a common block with a few machining differences.
  22. Jet96
    Jet96
    from WY
    Man he built some neat stuff...
    Stogy, enloe, METAL MELTDOWN and 2 others like this.
  23. wrenchbender
    wrenchbender
    If I remember correctly the ducting come from where the blowoff valve would normally be on any old m/t blower intake I personally don’t think it could have ran very well with only fuel from the rear engine as it only had the one injection on top of the blower Mickey was an evening innovator for sure he tried everything at least once lol some didn’t work so well the second version looks like it would work way better
    Stogy, Jet96, Fordors and 3 others like this.
  24. Jet96
    Jet96
    from WY
    49993D01-6907-434B-AD9D-24C071821C0E.jpeg Mad Mikey- did you ever figure you would get 200 pages out of this?
  25. loudbang
    The Empress '51 Chevy Carl Casper
  26. loudbang
  27. loudbang
    Peter Georgeades’ 1930 5 Window Coupe
  28. loudbang
  29. loudbang
  30. loudbang
