Technical 1965 Chevy 327 Distributor upgrade
Discussion in 'Traditional Hot Rods' started by MIKE STEWART, May 13, 2020.
  1. MIKE STEWART
    MIKE STEWART
    I have a 1965 Chevy 327 in a 1939 Ford Coupe - with stock distributor. I replaced plugs, points and condensor with A/C Delco items. Coil is stock replacement items - I bought a dist. cap and rotor from Corvette repo buisiness - repo heavy duty Corvette items. Points and condensor are stock units.
    Engine has solid cam - I have GMC shipping tube the cam was packaged in - from the 1970 overhaul engine build. Old and can not read part number - the cam has 16 inches of vac*** idling at 1,100.
    Car was my Dad's - want to keep period look. No room on firewall or larger HEI type distributor. Any suggestions for upgrades. I see small cap electronic dist available. Any suggestions from folks more knowledgable on 327 Chevy engines. I usually wrench on Winsor small block Fords.
    Graybeard4545 and rbrewer like this.
  2. 41rodderz
    41rodderz
    from Oregon
    Yes small cap, Pertronix set up to replace your points , magneto or dish in your cowl area .
  3. JUSTIN PERSINGER
    JUSTIN PERSINGER
    Pertronix upgrade is a good way to go, or the small cap distributor. Either one will work. A SBC does not care if your distributor comes from a 283, 305, 327, or 350 all will work with each other. We done the pertronix in the 57 Chevy we built due to no room on firewall. Used the stock distributor from the 283 factory motor in the 350.
    Sent from my XP8800 using The H.A.M.B. mobile app
    OLSKOOL57 and MIKE STEWART like this.
  4. 57 HEAP
    57 HEAP
    I got my conversion from Crane Cams about 20 years ago. Except for differences in the wiring you would never know.
  5. olscrounger
    olscrounger
    ^^^ me too-in wife's 55 for many many years-no issues
    lothiandon1940 and MIKE STEWART like this.
  6. Dual point :), maybe bend up some hardline in place of the rubber fuel line. My .002
    Randy D likes this.
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    what is wrong with the points setup? I run em on my cars with zero issues
  8. Bob Lowry
    Bob Lowry
    I have been hot rodding SBC, from 265" to 400" to 409" W motors.
    I have used Mallory distributors, single point SBC, dual point SBC, MSD ignitions, Pertronix…..I have
    always come back to a good old SBC single point distributor, set up correctly with a good advance curve.
    It has never failed me yet, and oh, by the way, I do redline at 7,000 and have gone to 7,500 with no
    issues.
    Have fun with the build.
  9. Bob Lowry
    Bob Lowry
    Forgot to mention, I'm speaking from 60 + years of wrenching on them.
  10. saltflats
    saltflats
    from Missouri
    I'm with the KIS points hands down if your distributor is still in good condition.
  11. The stock GM distributor is pretty much bullet proof when you use quality points, condenser and cap......no real reason to change it out. Make sure you use a quality coil and plug wires also. Also make sure the shaft "end play" is within spec, and the drive gear is in good condition. I install Pertronix on all my SBC engines, mainly because they can handle 7000+ RPM easily (no point bounce), but not necessary for everyday reliability.
    olscrounger and MIKE STEWART like this.
  12. jimmy six
    jimmy six
    What’s wrong with what’s there? A 327 had a “window” distributor stock and they worked from 57-74. If your looking to modernize it, Pertronix 2 with their coil or Bosch replacement and a ballast resistor is hard to beat. If you want “ period correct” pop that Edelbrock off the front of the carb or at least cover it up. That screams 2000 more than anything. How about a black snorkel or chrome L79 repo dual snorkel air cleaner...
    tractorguy, MIKE STEWART and squirrel like this.
  13. Mimilan
    Mimilan
    Pertronix conversions only eliminate the points, they dont add any more energy to the spark.
    Thats what an HEI does.
    The only disadvantage of points is regular maintenance [setting points]
    Buy a dwell meter. [and learn to set the points by dwell]
    With Chevy's you can do this with the engine running [about 30 second job]
    If you want a hidden electronic ignition, get the points to trigger a Ford TFI unit that is wired remotely. The points will last forever.
    The TFI triggers when the points open ,the same as a normal points Ignition ,so there is no rotor phasing issues
    MIKE STEWART likes this.
  14. squirrel
    Just curious, why are you scared of points?
  15. Fogger
    Fogger
    All it takes is one failure of a electronic ignition when on the road and you'll think again that you should have left in the points. I agree with the advice of learning how to use a dwell meter and carry a set of quality points, condenser, cap and coil and you won't have an ignition failure that can't be fixed. All three of my cars have points, two are AC Delco and third one is a Roto-Faze. Never been stranded.
    tractorguy, swade41 and MIKE STEWART like this.
  16. thecj3man
    thecj3man
    from TN
    I had a stock chevy points distributor converted to HEI a couple years ago. The points in my car worked ok and it ran good, I just wanted to try something different. The converted distributor looked pretty good in the car, and you had to really look to see the ignition module on the bottom.
  17. MIKE STEWART
    MIKE STEWART
    hard line is under the heat shield. Will clean up when I pull engine to paint firewall.
  18. bobss396
    bobss396
    I like points and had them in stock cars twisted up to 7000 RPMs. Just had to use good points, Accel or Blue Streak by Standard Ignition. All you need to do is carry a good used points and condenser and the tools to swap them out.
    tractorguy and MIKE STEWART like this.
  19. MIKE STEWART
    MIKE STEWART
    agree ..... the OEM black air cleaner was 4 or so inches and dropped base - would not fit the new carb. I need a Holley 5 inch base and go back with period correct air cleaner. The crome one is tempary . Might buy a repo L79
  20. MIKE STEWART
    MIKE STEWART
    not scared - just changed them last night - first time in 20 years for me. I am a Ford engine guy - they were easier to reach vs Chevy. Just looking for performance increase and low maint. - but this car will never really be driven alot - perhaps 2,000 miles per year.
  21. Taboo56Chevy
    Taboo56Chevy
    Between my grandfather and I's fleet of old cars, we are running points in pretty much everything. Have had cars with HEI and Unilights and swapped them back to points.
    You can run a MSD 6AL box with points, I have that set up in my 33 pickup and its been trouble free for over 20 years with lots of drag strip p***es.
  22. saltflats
    saltflats
    from Missouri
    Then I would save the condenser and use the points to operate a MSD box like a 6al or 7al depending on how many bells and whistle I wanted.
  23. squirrel
    2000 miles a year? you already did the maintenance for the next five years. Worry about the ignition in five years.
  24. MIKE STEWART
    MIKE STEWART
  25. squirrel
    Why do you need a hotter coil?
    Sent from my Trimline
    Moriarity likes this.
  26. fastcar1953
    fastcar1953
    I would say leave it alone. Find something else to work on. Clean it and drive it. Go for 3000 miles a year.
  27. 30tudor
    30tudor
    You have what you need right now just keep it tuned. Might want to check the clearance on those valves if it is a solid cam. Can you make out any of the numbers on the tube? Just curious.
  28. Fordors
    Fordors
    96D9214A-776E-410C-BC11-1EE8C48D9DA7.jpeg 9ADB2395-0644-4CA7-92C2-B9518DE3E0AC.jpeg I agree with your choice of cap and rotor and also your standard D106P points. There’s no need for the D112P points with the heavier spring, they will just wear the rubbing block faster.
    If you did want to change the coil you might consider the Bosch 00012 coil, it is a 3 ohm coil and you want to remove the ballast resistor if you do get the Bosch. Made in Germany, it is top quality, and if you ever wanted to go pointless it will be perfect with a Pertronix.
  29. swade41
    swade41
    from Buffalo,NY
    It's a Chevy, it doesn't need the crutches like a ford motor to run good, leave it alone and you'll be a set for years, I would look at NGK plugs though.
  30. MIKE STEWART
    MIKE STEWART
    No really can not. My dad and his mechanic 1st cousin rebuild the 327 in 1970 - both has p***ed. Has 16 inches of vacuum.
    1Nimrod likes this.
