Projects 1939 Packard Custom
Discussion in 'Traditional Customs' started by CadMad, Apr 15, 2020.
  1. kidcampbell71
    kidcampbell71
    Damn. Pbbbbbt' !!! Metal skills are rippin' !! Exponential thumbs up !! :cool:
    winduptoy and CadMad like this.
  2. Rick Coast
    Rick Coast
    now this is what I call a KUSTOM. totally awesome! You my friend are a true artest. It bugs me to hear guys say the word custom and no body mods were made.Yours is real.
    weps, CadMad, j hansen and 2 others like this.
  3. CadMad
    CadMad
    I’ve come this far.... may as well go all the way.
    Gonna build whole inner cowl from stainless and maybe engine turn it once done.
    If it’s good enough for Tesla.... it’s good enough for me. 3BCB4B43-3A6B-4B04-B554-FD08E0613E49.jpeg 7EB115AA-9F5F-400F-80EE-54959FB35917.jpeg 0EC1A977-739C-42BE-AA0E-061168CFADA7.jpeg E9DA3363-459C-499B-BB30-779872632F2A.jpeg F505B4FA-10A2-4F4B-9D10-1DF20D4458EF.jpeg
  4. 296moon
    296moon
    from england
    Cant get enough can you build a bit quicker please.............................
    Squablow, kidcampbell71 and abe lugo like this.
  5. CadMad
    CadMad
    More stainless than a Maytag washing machine.
    I talked to my mate Jason who does engine turned dashes and if I’m lucky he’ll make me a jig to engine turn the cowl. That can happen later. Got to put it all together again. 3F000DA6-7A1C-466F-B082-BCDD14CB147F.jpeg 4AF978CE-0993-4885-A285-60A36EA6D0F5.jpeg
  6. Nick Agius
    Nick Agius
    Damn Quinten... This is so cool, Nice to get more of a backstory to the photos I see on Instagram
    chryslerfan55 and CadMad like this.
  7. CadMad
    CadMad
    Thanks Nick. You’ll have to drop by in the roadster one of these days. Haven’t seen it finished. Bring John with you so I can ****er him up to rebuild the gearbox.
    chryslerfan55 and Nick Agius like this.
  8. CadMad
    CadMad
    Cowl is now bolted up and inner sill screwed up and square. Nice to finally have clean metal to work with. Cowl face is moved back 4 inches yet floor area remains the same. Toeboard is steeper. Nice and rigid. The rest should be like Meccano. 5B7345DC-037A-41FC-AF00-9E24C081171A.jpeg 6F0EE68B-C843-4E16-911A-B60DC9D406FC.jpeg
  9. CadMad
    CadMad
    3CD7CCCB-5CA5-4001-B934-B9EA36E475E2.jpeg 6DFA718D-E429-4B97-B72B-75B337F2B492.jpeg Long afternoons and the weekend to get the floors cut and folded up and screwed down. Work is back to normal so won’t be as many Packard play hours but the hardest work is now done.
    Found a replacement of the roof mech that I threw away. Happy Days.
    Practiced doing some engine turning on my drill press, rough and quick but I’ll make a proper jig and give the cowl a go on the weekend. DFD5BC34-04A8-4BAD-BCA9-E36B2BDDDE6A.jpeg
  10. theHIGHLANDER
    theHIGHLANDER
    You'll be in good company with the engine turned stainless. I'm sure you're aware of how Bugatti and Alfa used it, but this one is under the hood of a supercharged Duesy Model J with Brunn Riviera coachwork. Yeah, every bright surface. Rad, huh?
    weps, mgtstumpy, Okie Pete and 8 others like this.
  11. CadMad
    CadMad
    Thanks Highlander, just the inspiration I have been looking for. I need to put a few dimples in the firewall and am tossing up to do the engine turning prior or after. I think prior.
    Got the engine out last evening. I’ll drop in a running 39 Six initially, till I can afford to do the 8. But it’s definitely getting the 8. I’m onto a running Super 8 engine that was only a suburb away till recently. Got given away. Trying to negotiate now Got some rust repairs to do to the front crossmember and now I can get to it.
    I’ll get the gearbox out next and get it overhauled. 53C4B5DA-B288-4786-87B4-91F13BCE745C.jpeg 8E9D9FB9-7998-46C5-83EC-B198E97774B0.jpeg A5AAAC6E-B17C-4FDA-99D6-90867997885F.jpeg FEE01938-37A5-46D4-8EA2-D63D7BA3BBF0.jpeg
    mgtstumpy, Okie Pete, 66gmc and 10 others like this.
  12. theHIGHLANDER
    theHIGHLANDER
    I'm rootin for ya on the Super 8. If it's a 356 or 359 you'll think you died and went to Packard Heaven! Arguably Packard's best engine ever, yes, above their mighty 12. Even if you end up with a 327 (48 and up I think) they too are worthy. Pulled those ugly bath tubs rather well;)
    392
    Cut, grind and weld. Nice work and lots of it.
  14. CadMad
    CadMad
    44C04492-ED2A-402E-9D44-CF9578D2799E.jpg 72738D8E-699F-4DF7-B95D-96A934E6A7B3.jpeg Got the engine apart and Piston’s out. Bottom end is good even reusable Valves need doing and bore has been sleeved ( a few were badly pitted). Probably back in the day when oversized Pistons weren’t available. They just sleeved them and reused original pistons.
    I checked the vin against the Packard database and it’s the original 5 main 282 120 engine so regardless of the fact that another 9 main Super8 engine might show up, I think this deserves doing. I’ll clean it up and get it crack tested first and go from there.
    Will have to bore it out past the sleeves, and either find new pistons or resleeve worst bores.
  15. theHIGHLANDER
    theHIGHLANDER
    Don't bother with hardened valve seats, not needed. It's a deep dig to verify but past research noted that Packard used a high nickel iron in their castings, essentially "cast steel" when compared to other's engine blocks. If lots of miles are the goal nothing more than stainless valves to stave off seat pitting from lead-free fuels. Additives or the occasional use of a couple gallons of race or aviation fuel helps too, and not needed every fill up. Still, if you do get a "deal" on a running 9 main GO FOR IT! I just sold a 47 Super Clipper last year with the 9 main 356 AND overdrive. Talk about heaven, and it was a big heavy car...:cool:
    chryslerfan55 and kidcampbell71 like this.
  16. CadMad
    CadMad
    I’m on a sharp learning curve. I’d love to put a blower on it one day. Missed out on the perfect m90 Eaton for $75 yesterday ( Damn fool am I, he who hesitates....)
    I took the gearbox over to my hotrod guru mate John, he looked at it for a second and said a T5 will nearly bolt straight up. He had 3 littering under his bench, discovered they belong to another mate who rang me 20 minutes later.... talk about synchronicity. He only wants one out of the 3 and I can have the other two. There’sa Commodore one with the gate further back down the case which would be perfect for my moved 11 inches back seating position. We’ll see !
    I do like the idea of keeping it 39 running gear but remember I’m also building the Packard 6 28 model A boattail and 30 roadster with the Packard dash and grille. Better pull my finger out and keep building. 09498E01-A4D2-4662-A4A0-3C4D4909D542.png 8A0F7423-32B1-42C7-ABE1-E741811E5A66.jpeg BCB8B578-4E27-44DE-B178-F67098ACF613.jpeg F6F1CD73-0577-48A4-B1C7-005B5B3C81B6.jpeg AED41498-494B-417C-BDFB-8A104744D7C0.jpeg C5EFCB19-8D87-4453-BF88-75F2172E41DA.jpeg
    weps, UNSHINED 2, mgtstumpy and 18 others like this.
  17. DIYGUY
    DIYGUY
    from West, TX
    Amazed by your talent , skills and vision!
  18. brEad
    brEad
    Lot of killer projects going on there!
  19. CadMad
    CadMad
    Decided to do the fit up of steering prior to engine turning firewall. Fitted a nice alloy (which I’ll polish) Borgeson joint that came off the Saab Aero donor car that provided the convertible top. My mate turned up two steel adapters to fit the original steering shaft.
    Got a nice stainless tube from the s**** yard for the column. 57D5E7EF-01EF-4926-B49D-7B351A139AB7.jpeg
  20. CadMad
    CadMad
    Scored a roll of SS flex pipe yesterday. I lifted off the heavy cast iron exhaust manifold the other day and thought I need to make stainless extractors. Have some mandrel Bent pool handrails in 35mm stainless that are perfect to cut and shut. The manifold has 8 outlets so 4 pipes on the right side of the hood might be nice. 9BA5D513-1E64-4302-A628-A3613D93CC3B.jpeg E7F4F4B2-0B0B-4A11-83CC-311630FB0A7E.jpg 3CA4F2B9-D728-420C-A9BE-54B344BC741C.jpeg 52E974CE-A114-4956-BF7E-E75C72BDF8EE.jpeg
    mvee33, mgtstumpy, DanGunit69 and 8 others like this.
  21. 1-SHOT
    1-SHOT
    from Denton
    I used pool hand rails on my A to fabricate exhaust. You can weld it with 309 L stainless filler, I back purged mine when I TIG it up. Also 309 L works great on cast iron repairs, but, its really hard to drill (Carbide Drill) and you can only tap it a 1/4 turn at a time. I tool a carbon rod and threaded it and threaded it into the broke off boss on my motor and built it up then all you have to do is clean the threads out. The first time I did that I didn’t use a carbon rod bolt thats when i found out just how hard it’s to drill and tap. It welds just like spreading ****er. Hope this helps. Frank
    P.S. love the steering wheel
    Sandgroper, chryslerfan55 and CadMad like this.
  22. CadMad
    CadMad
    I finally got a chance to remake the cowl sides today as I stretched the cowl another 4 inches back and laid the screen a further 5 degrees from my first iteration. It’s much better balanced now. The transition into the rolled sills was a little tricky but I’m very happy with the look. Tomorrow arvo I can roll the edges.
    Getting close to door time. 3F98C32F-CD61-4B56-A220-15D88F53523F.jpeg 1ECF7A16-A398-4BEE-B175-5F3191154EF7.jpeg CFE15B5F-F3A5-4B49-A64B-5FA26C0F3B4E.jpeg
    mgtstumpy, ClarkH, 40two and 15 others like this.
  23. 1-SHOT
    1-SHOT
    from Denton
    I am really anxious to see this completed.
    kidcampbell71 likes this.
  24. CadMad
    CadMad
    Cowl edges stepped. I decided to roll the lower sill to give a little more drama. May need a little tweaking still. But very swoopy. 41B84305-3C44-4160-9F06-754105A3FBF1.jpeg DB836F95-20BA-4CAA-BD7A-0452580DCD9B.jpeg 26528EA2-1BA2-41D0-9C86-4380BFAC460E.jpeg 0F33D997-47D2-4654-828D-3538DDC92387.jpeg
  25. Bandit Billy
    Bandit Billy
    Wow! That is going to be stunning.
    CadMad, 41 GMC K-18 and Gasser 57 like this.
  26. 1-SHOT
    1-SHOT
    from Denton
    What ever happened to the man building the 39 Cad down under. Did he fall off?
  27. CadMad
    CadMad
    The Cadillac is safely stored across the road. Once I get the Packard up to the same stage I’ll do body and paint together.... and won’t think about starting another project....( famous last words)
  28. 1-SHOT
    1-SHOT
    from Denton
    I am really like the Cad. Thanks for replying I really enjoy following your thread thanks for letting me tag along. Frank
    CadMad likes this.
    just ready the whole thread.
    Damn you got some skills and some fantastic projects!!
    Go man go !!
  30. CadMad
    CadMad
    That’s the funniest thing I’ve seen in a long time!!!!
    He’s playing Nintendo... right????
