Technical Small parts ID please
Discussion in 'The Hokey Ass Message Board' started by 34 GAZ, May 15, 2020.
  1. These were in my Flathead parts stash. Cleaned them up but what are they ? Part A is 3 piece, the round piece with the slots fits inside and jiggles around. Part C has a adjustable thread which is concave at the end. Part D has a thread all the way through. B,C,D,E do not fit each other. What do they need to be complete ? bits 2.JPG bits 4.JPG
  2. squirrel
    They look like special tools, don't they?
    34 GAZ likes this.
  3. 302GMC
    302GMC
    from Idaho
    "A" , if pipe thread, is most likely a "Donaldson Valve'' for crankcase ventilation. No #s or anything stamped on it ?
    34 GAZ likes this.
  4. VOETOM
    VOETOM
    from MO
    "A" does look like part of a broaching tool ***embly...
    34 GAZ likes this.
  5. Flathead Dave
    Flathead Dave
    from So. Cal.
    The blue one is a ball point pen. What makes it versatile is the manually operated, push ****on spring loaded clicker, which when depressed, will force the tip of the ink tube to protrude to a determined distance so that the nib will be able to touch a surface and when forced to move about, will in turn, make the ball in the point turn thus releasing a colored ink on to almost any surface. Some people will use the item to write words or scribe a line, draw a pattern or allow it to sit in a shirt pocket.
    Probably mid 2000-2020. Not very traditional, but it, no doubt, gets the job done.
  6. Had to google that. Found similar for a Willys Jeep crankcase. No numbers on any of these parts.
  7. nobby
    nobby
    fan hub
    generator mount bolt
    Hnstray likes this.
  8. Which one ?
  9. squirrel
    D mostly....but B and C could be also.
