Projects '23 Ford Roadster build aka The Incredible Hulk
Discussion in 'The Hokey Ass Message Board' started by Paul, Feb 22, 2018.
  1. 64 DODGE 440
    64 DODGE 440
    from so cal
    Definitely one bad*** little hotrod.
    Paul and loudbang like this.
  2. Paul
    Paul
    Editor
    Shuffled things around in the shop to clear a space for the frame table, pulled everything off the frame and clamped it to the table.
    Will start welding it up tomorrow.. hopefully.
    Tim, Stogy, kidcampbell71 and 15 others like this.
  3. Paul
    Paul
    Editor
    Another example of similar front suspension treatment,
    V8-60 axle, spring behind, non parallel four bar
    George "Whitey" Gould's T
    George-Gould-T-Bucket-Car-Craft-April-1962.jpg George-Gould-T-Bucket-roadster-005.jpg
    gonzo, Tim, Stogy and 10 others like this.
  4. Paul
    Paul
    Editor
    Had to take a break on the car.
    Working around the house after last progress post I managed to strain my back
    enough to lay me up for a couple days,
    as soon as I started to feel halfway human
    I over did it again
    and it put me down for a few more days.
    Finally almost back to normal.
    I got all the major welds done on the frame and bolted big things back in place.
    'Plan to work on the rear engine/transmission mount cross member next,
    then on to finish welding brackets on front and rear axles..
    Tim, 51box, Stogy and 9 others like this.
  5. Paul
    Paul
    Editor
    worked on that cross member
    it'll get two bolts poking up and two bolts poking out at each end with nuts welded in frame walls to take 'em
    IMG_20200526_142822.jpg IMG_20200526_162009.jpg IMG_20200526_164210.jpg IMG_20200526_145551.jpg IMG_20200526_171831.jpg IMG_20200526_171822.jpg
    Atwater Mike, Tim, Stogy and 13 others like this.
  6. Paul
    Paul
    Editor
  7. bct
    bct
    I image your projects around the house are just as clean and neat. Lol. Good you got your sacroiliac back.
    Stogy, loudbang and Paul like this.
  8. J_J2
    J_J2
  9. Paul
    Paul
    Editor
    Right here on the shelf
    Stogy, Shadow Creek, J_J2 and 3 others like this.
  10. dumprat
    dumprat
    from b.c.
    That crossmember is beautiful.
  11. Paul
    Paul
    Editor
    Thanks man
  12. loudbang
    YA gotta remember that we are no longer "Incredible Hulks" as we get older. And have to take it a bit easier. :rolleyes:
    Stogy, OFT, bchctybob and 1 other person like this.
  13. vtwhead
    vtwhead
    Nice job on the crossmember Paul. Glad to hear your 'back" is back. :) I've fought with those issues now for thirty years so I know it can be a ***** at times.
    Stogy, Paul and loudbang like this.
  14. J_J2
    J_J2
    Stogy and loudbang like this.
  15. Paul
    Paul
    Editor
    Pulled the front axle
    and welded the four bar brackets
    and the perch stops to it.
    Reinstalled the axle,
    adjusted the upper shock mounts a bit
    to better align with the plane of the spring,
    made a simple jig to check and align lower shock mounts,
    and welded them to the perches.
    And started to clean up and blend those together.
    IMG_20200527_162949.jpg IMG_20200527_163009.jpg IMG_20200527_171650.jpg IMG_20200527_171655.jpg IMG_20200527_171839.jpg IMG_20200527_195816.jpg IMG_20200527_195932.jpg
    Kreepea_1, Just Gary, Tim and 13 others like this.
  16. dumprat
    dumprat
    from b.c.
    That front end set up should be in the gold standard for a T front axle set up. Perfectly done.
    I am going to blatantly rip off your ideas sometime in the future.
  17. Paul
    Paul
    Editor
    If you must copy any ideas shown here
    please don't credit me,
    I stole them from somebody else.
    But thank you for the kind words ;)
    Tim, 51box, Moriarity and 7 others like this.
  18. Paul
    Paul
    Editor
    Front suspension is done enough to move to the other end.
    All major welding and grinding done until finish phase.
    Going to try to get the rear suspension to same state of completion next.
  19. So good!
  20. alchemy
    alchemy
    That's a lot of leaves for the front spring of a T, but I guess when you're an Oldsmobile man you gotta keep them all in there. Looking good!
    loudbang, brEad and Paul like this.
  21. 51box
    51box
    from MA
    Nice work @Paul great details on the front end. I need to get more efficient, you’re flying through this build!
  22. wheeltramp brian
    wheeltramp brian
    Your car is perfect!good job!
  23. Paul
    Paul
    Editor
    found a pair of NOS shocks the right length for the rear,
    so I made some top brackets..
    simple 1/4" plate tab with hole for shock stud
    with 3/16" plate to spread weld load at frame
    IMG_20200601_175352.jpg IMG_20200601_175404.jpg IMG_20200601_181158.jpg IMG_20200601_181206.jpg IMG_20200601_181211.jpg IMG_20200601_182419.jpg
  24. Paul
    Paul
    Editor
    that won't do..
    structurally sound but ugly and out of place..
  25. Paul
    Paul
    Editor
    broke the tacks and took them back to the bench.
    cut the mounting studs off just below the face of steel plate
    welded the shock side to the plate,
    rosette welded the cut stud to the plate on the opposite side,
    cut some 3/8" plate same shape as the tab,
    beveled all edges and welded it to the tabs.
    ground everything nice and rounded to get rid of the sharp edges.
    and tacked them back in place.
    that'll do
  26. dumprat
    dumprat
    from b.c.
    Well that's better!
  27. Paul
    Paul
    Editor
    Better match to the front mount
  28. brEad
    brEad
    Nicely done! The rest of us mere mortals would have stopped at version 1. Version 2 is soooo much better.
    ratrodrodder, OFT, Paul and 2 others like this.
  29. Stogy
    Stogy
    The Art of Fabrication...truly...a joy to watch from this front row seat...
    @Paul, thanks again for sharing...;)
    OFT, Paul, loudbang and 2 others like this.
  30. chopndrop
    chopndrop
    How much do you charge for someone just to stand at the door of your shop to watch you work?
    Only joking,
    . . . kinda
