Hot Rods Belly Tank!
Discussion in 'The Hokey Ass Message Board' started by Rehpotsirhcj, Jun 24, 2019.
  1. Joe Blow
    Joe Blow
  2. Rehpotsirhcj
    Rehpotsirhcj
    OHV 4 I guess, I need to find a list of compe***ive cl***es.
    loudbang and 26 T Ford RPU like this.
  3. RichFox
    RichFox
    That's a 750 cc OHC Crosley. These days there are plenty of better 750 bike motors. But with much less soul. SCTA will be happy to sell you a rule/record book for you to look through
    Rehpotsirhcj and 26 T Ford RPU like this.
  4. Rehpotsirhcj
    Rehpotsirhcj
    Thanks Rich, I wasn’t even thinking cycle motors. Just ordered a copy of the rule book
  5. 26 T Ford RPU
    26 T Ford RPU
    I got mine at Bonneville last year. JW
  6. 26 T Ford RPU
    26 T Ford RPU
    Got to go pick up my newF- gl*** Tank today, very happy with it. It is the P-38 with an extra 20 inches. i may take some out of the length but i think it looks in proportion so it may stay as is and have more room for me. JW
  7. 26 T Ford RPU
    26 T Ford RPU
    And rough mock up, now i can start the build. JW
  8. Rehpotsirhcj
    Rehpotsirhcj
    That’s fantastic! Looking forward to seeing your build. Plans for your frame?
    26 T Ford RPU and loudbang like this.
  9. 26 T Ford RPU
    26 T Ford RPU
    Frame will most likely be box section with the necessary and relevant safety roll cage. Now i have the body i will get some thin MDF sheets and draw an out line and use that to map out where things will be. JW
    Rehpotsirhcj and loudbang like this.
  10. Rehpotsirhcj
    Rehpotsirhcj
    Don’t know whose this is, but I like it.
  11. 26 T Ford RPU
    26 T Ford RPU
    That is a great photo with good detail. I have started mine, just making small brackets. I start the ch***is next week all going well. JW
    loudbang and Rehpotsirhcj like this.
  12. Rehpotsirhcj
    Rehpotsirhcj
    You should start a build thread so we can follow your progress!
  13. 26 T Ford RPU
    26 T Ford RPU
    I thought about that but progress will be slow for a while, will keep updating on here then start one down the track. Once i have frame done and start dummy mounting things in i will look at it then. I think my Wife is more excited about it than i am, see wants to drive also.:cool::cool: JW
    SEAAIRE354, loudbang and Rehpotsirhcj like this.
  14. 26 T Ford RPU
    26 T Ford RPU
    Pic of a painting at Kindig Customs. JW
    juan motime and loudbang like this.
  15. Bearing Burner
    Bearing Burner
    from W. MA
    I have one that Jerry Kugal drove over 200 MPH with a 260 Ford Fairlane engine in the mid 60's.
  16. 26 T Ford RPU
    26 T Ford RPU
    Cool... any pics??? JW
  17. 26 T Ford RPU
    26 T Ford RPU
    Started the ch***is,bent the top space frame rails.....will start the bottom one next then check fit to body and then work out axle location and fixing. JW
  18. Rehpotsirhcj
    Rehpotsirhcj
    So, super interested in your build, slow or otherwise..
    What type of tubing are you using for the frame? your own design?
  19. 26 T Ford RPU
    26 T Ford RPU
    It will all be 1- 5/8'' mild steel tube with 1/8 wall. The frame will be a space frame type. i am waiting for my seat as i want to know how much room i will have up front before i set where the back axle will locate. The ch***is will come together fairly quickly once i have these points worked out. Tire size is another issue the will need to be worked into axle mountings, it also has to look right. JW
    Rehpotsirhcj likes this.
  20. chopnchaneled
    chopnchaneled
    from Buford Ga.
    Going to tag along for the ride, Looking forward to your Build and results JW.
    Is there a plan for the salt here in the US?
  21. 26 T Ford RPU
    26 T Ford RPU
    Yes it is, i have been twice and i got bitten hard by the ''Salt Bug''. i have been interested in it for a long time. It won't be a record setter.....i just NEED to do it.
    All the photos i take for the project are in a specific album (find it on my profile page) , when i have enough to show i will start a build thread. JW
  22. 26 T Ford RPU
    26 T Ford RPU
    Sat the the top frame tube in the body for the 1st time. Can now start measuring for the placement of the axles. JW
  23. 26 T Ford RPU
    26 T Ford RPU
    The '46 Willys Jeep motor (134cid) that will power it. They are 63hp standard so a bit of a warm up "should'' see a marked improvement. JW
  24. 26 T Ford RPU
    26 T Ford RPU
    Rear axle is MK III Zephyr (English) with 3.54:1. Oh, i got my seat so i can start measuring. JW
  25. loudbang
    Time for your build thread. :rolleyes:
    26 T Ford RPU likes this.
  26. 26 T Ford RPU
    26 T Ford RPU
    Soon, maybe by Christmas, i have a lot on my plate at present. :D JW
  27. RichFox
    RichFox
  28. RichFox
    RichFox
    Stock Jeep intake turned over and heat sink area opened up to allow more carburation. Needed to mess with the bolt holes also.
  29. 26 T Ford RPU
    26 T Ford RPU
    I had looked at that...briefly:), but i want to run a Holley 350 2bbl so i have a design in my head for that. I want external adjustments. JW
  30. RichFox
    RichFox
    engines.jpg That will work. But just to be different, if it was mine I might run one of these throttle bodies on the upside down intake and drill for nozzles in the runners. Score a pump and metering block somewhere and make a pill box to use Holley jets for the return. That seems to go more with the idea of a Willies powered tank for the salt. Maybe I would make a cool twin plug flathead and dual distributor drive while I was at it. Why be normal?
