Technical What is the angle of your nuts ?
Discussion in 'The Hokey Ass Message Board' started by Blue One, May 17, 2020.
  1. Blue One
    Blue One
    from Alberta
    :D Now that I have your attention, I want to know what the proper seating angle would be for lug nuts for steel wheels like my WV Gennie 14 series.
    I see 45 and 60 degrees listed.
    What is the correct seating angle for steel wheels?
    Deuces and Phil P like this.
  2. squirrel
    Stock lug nuts, perhaps?
    (which seem to be 60. 45 degree nuts are oversized and used in a few specific applications)
  3. DDDenny
    Right nut or left nut, one is lower than the other!
    Sorry Larry, I had to be "that guy".
    mgtstumpy, Deuces, VANDENPLAS and 5 others like this.
  4. Blue One
    Blue One
    from Alberta
    Thats what I thought, I don’t have any stock ones to look at.
    I bought a set at Princess auto and I think they’re just for trailer wheels.
    They’re probably 60 degrees, but I think they’re of questionable quality.
    Once I wake up I’ll go check one out :D
    I had one seize up yesterday, it was horribly galled and wouldn’t come off until I cut it off destroying a stud too. (One of these on my Winters QC which of course aren’t available locally)
    Brand new studs and nuts, first time they had been torqued.
    The Mechanic who did my inspection torqued them, once I got home I wanted to pull the wheels off to adjust the brakes :(
  5. hotrodjack33
    hotrodjack33
    Nope, not gonna touch on that...but maybe I could get the wife to...…..
    Blue One likes this.
  6. 41rodderz
    41rodderz
    from Oregon
    Touche
    Al T, hotrodjack33 and Blue One like this.
  7. Blue One
    Blue One
    from Alberta
    So to add to the debate, do you lube your nuts?:D
    I have to wonder if a little never seize would have prevented the galling that caused my problem in the first place.
    I know there are 2 schools of thought on that.:D
  8. Phil P
    Phil P
    I always use anti seize, you are supposed to ajust your torque value down to compensate for the lubricant. Most torque charts give the appropriate values.
    Phil
  9. 57 Fargo
    57 Fargo
    Larry, I strongly advise against using anything on your nuts.[emoji3]. Get quality lug nuts and you shouldn’t ever have a problem.
    Deuces and Blue One like this.
  10. lippy
    lippy
    from Ks
  11. rusty rocket
    rusty rocket
    I use bees wax on my nuts so they don't rust!
    Deuces likes this.
  12. Moriarity
    Moriarity
    SUPER MODERATOR
    Stock Ford lugnut. 60 degrees
  13. Contact the “ LUG NUT KING”
    He’s at every show here in ontario he specializes in lug nuts and studs , spacers etc.
    Top shelf dude and loves to help
    egads, Deuces and loudbang like this.
  14. rusty valley
    rusty valley
    thats a nice degree thingy there mr moriarity, i am jealous
    Deuces and Moriarity like this.
  15. squirrel
    Me too. I have the cheap copy, they have them in stock at the builder supply. But I do have a bunch of other Starrett tools.
  16. Truck64
    Truck64
    from Ioway
    They do? There sure is all kinds of screeching boilerplate about lugnuts, usually bold print, lots of exclamation points and portents of impending doom.
    My old Ford shop manual specifies the lug nut torque is for lubricated threads. That went bye-bye somewhere along the way. Too many gorillas with an impact wrench I guess.
    Desoto291Hemi and Deuces like this.
  17. trollst
    trollst
    There's no angle to mine, can't really say though.....haven't seen them in years. Let me go out to the shop and check, be right back.....yep, still there.
  18. 57 Fargo
    57 Fargo
    Ok I can’t help it, hopefully I don’t get Larry’s thread closed, being as I went and got neutered on Thursday I could help but laugh when I first saw this thread!
    Sorry Larry, carry on...[emoji3]
    Blue One and loudbang like this.
  19. Phil P
    Phil P
    I was referring to a general chart, one that list torque by fastener size and thread pitch.
    Phil
  20. Beanscoot
    Beanscoot
    I put oil on the wheel nut threads and never-seize on the chamfer surfaces.
    I also put oil on my con rod nuts and main bearing cap bolts, and they haven't fallen off yet.
    Truck64, Desoto291Hemi and Deuces like this.
  21. Blue One
    Blue One
    from Alberta
    I went out to the local self serve auto parts yard this morning and scoured around the full sized Ford Crown Victorias.
    Managed to find 30 lug nuts that on examination are OEM.
    Leaving the yard with them in a clear plastic cup that I grabbed from one of the cars they charged me a whole $2 :D
    Got home with them and the quality difference is really obvious.
    Threading a Chinese one from princess auto onto the stud you can grab hold of it and it has some movement like a little wiggle indicating excessive thread oversize.
    Threading on a OEM Ford lug nut and it fits nice and smooth and no excess thread clearance. Way better fit.
    Nice quality and yes 60 degrees.
    A little cleanup in the tumbler will do the trick. :cool:
    Tim, loudbang, VANDENPLAS and 4 others like this.
  22. rusty valley
    rusty valley
    also note, the oem nuts are not threaded all the way thru, instead missing a few threads on the bottom in case some of the stud with no threads is too high.
  23. Flathead Dave
    Flathead Dave
    from So. Cal.
    My wife measured and rubbed oils on my nuts to keep them clean. No more squeaks. Easier to handle and turn and twist.
    She knows how to work on cars.
    loudbang, Blue One and Deuces like this.
  24. 41rodderz
    41rodderz
    from Oregon
    VANDENPLAS likes this.
  25. 41rodderz
    41rodderz
    from Oregon
    :p
    Deuces likes this.
  26. Deuces
    Deuces
    I thought everybody had one of those in their toolbox.... I have 3...:):confused::cool::rolleyes:
  27. Hnstray
    Hnstray
    from Quincy, IL
    Do you know what “Fat Chance” means? :D
    (a girlfriend from years ago introduced me to that saying ...)
    loudbang and hotrodjack33 like this.
  28. rusty valley
    rusty valley
    deuces, you're just trying to hurt my feelings. poor folk have to put up with the chinese plastic variety. IMG_0655.JPG
    loudbang and Blue One like this.
  29. Hnstray
    Hnstray
    from Quincy, IL
    What.....you have a mirror on the floor out in the shop? :eek: :D
  30. Hnstray
    Hnstray
    from Quincy, IL
    Wait! What?? They are supposed to only disconnect them....not REMOVE them! :eek:
    loudbang, hotrodjack33 and Blue One like this.
