Projects Floating grille install.
Discussion in 'Traditional Customs' started by ZZ Top Chop, May 17, 2020.
  1. ZZ Top Chop
    ZZ Top Chop
    Well, I got laid off on Friday, isn't this fun times? So after trying to process the situation, I decided to go to the garage and get $hit done. I hope this helps someone out there trying to figure this out. 20200517_170856.jpeg
    Sent from my SM-A102U using The H.A.M.B. mobile app
  2. ZZ Top Chop
    ZZ Top Chop
    I decided to lay everything out using yardsticks as it would be close to the stock I was using anyway. 20200515_150057.jpeg
    Okie Pete likes this.
  3. ZZ Top Chop
    ZZ Top Chop
    I then transfer the measurements and angles to the stock. I didn't need to use square stock because the 56 Windsor grille bar is very light. I utilized the bolt holes on the apron near the air intakes. 20200515_142814.jpeg
  4. ZZ Top Chop
    ZZ Top Chop
    I test fit the Windsor grille bar to the horizontal mount to make sure I got the right pitch, then I tacked it into place. 20200515_191940.jpeg
    neatoldclassics and Okie Pete like this.
  5. ZZ Top Chop
    ZZ Top Chop
    Here's what the completed mount looks like. I used Krylon Matte black w/all in one primer, which I was very impressed with. 20200517_105404.jpeg
  6. ZZ Top Chop
    ZZ Top Chop
    Because of the angle of the arms, extending from the bottom up, they are hardly visible giving a very convincing floating effect. 20200517_170907.jpeg
    32SEDAN, OzMerc39, Okie Pete and 14 others like this.
  7. ZZ Top Chop
    ZZ Top Chop
    I'm either going to make black perforated sheet metal covers over the intakes or paint them.
    Okie Pete and Just Gary like this.
  8. gene-koning
    gene-koning
    The floating grille looks great. Paint your intake ports semi gloss black and they will blend right in, someone will have to look for them to see them. Gene
  9. Bugguts
    Bugguts
    Very simple and cool. I love that look. Nice job!
    mr57 and ZZ Top Chop like this.
  10. fastcar1953
    fastcar1953
    very nice. good job
  11. Finnrodder
    Finnrodder
    from Finland
    Looks really good and it fits there perfectly
  12. Lines
    Lines
    from Germany
    Nice and easy. Looks good
  13. michaelvz51
    michaelvz51
    from So Cal
    That is clean and effective fabrication. Should work great too for keeping it cool, nice work!
    ZZ Top Chop likes this.
  14. jivin jer
    jivin jer
    Excellent from start to finish.
  15. Straight Axle Guy
    Straight Axle Guy
    Looking good! Nice work, thanks for sharing!
  16. japchris
    japchris
    from England
    Nice work! Yeah - blacking out the background really helps the floating effect. (I painted a bit of the lower valence too following the curve of the opening.) 69378255_10156766319028897_9014005536659603456_n.jpg
    I also put a dogleg angle iron upright centre support behind the grille bar, painted satin black to lose it in the shadows, as I was concerned about the slam panel. Without support would it flex when you shut the hood?
    I also put a safety chain on as I lost the hook bit.
  17. Mr48chev
    Nice work on that setup. Make sure that you post some after the satin black shots. I'd still put screens over the openings just to keep critters out if for no other reason.
    32SEDAN likes this.
