Technical 53 Chrysler New Yorker
Discussion in 'Traditional Customs' started by Dixie Rambler, May 18, 2020.
  1. Dixie Rambler
    Dixie Rambler
    Driving down the road this Am and my car started smoking. A white cloud came up from what I though was my tail pipe. I pulled over and Saw that I was leaking trans fluid and rusty water and a a small flame was eating up the oil.
    Any suggestions of where I need to start would be much appreciated. I’m thinking torque converter seal?
  2. Dixie Rambler
    Dixie Rambler
    Leak was coming from that owing in this photo.
  3. blowby
    blowby
    from Nicasio Ca
    Floor jack, stands and a creeper.
  4. flatford39
    flatford39
    Blue flame???? On what an exhaust pipe??? rusty water??? Did you check your coolant level??
  5. Dixie Rambler
    Dixie Rambler
    Orange flame and it was a little shy of coolant but not bad. The oil leak was coming from the ******. But take a look at the pics no sign of the small fire. Weird.
  6. Dixie Rambler
    Dixie Rambler
    I can’t find any singed wires u see there either
  7. Dixie Rambler
    Dixie Rambler
    Done that. Check the pics
  8. gene-koning
    gene-koning
    I'd be way more worried about why there was fire at that point then I would be concerned about where the oil is leaking from.
    The only thing in that area that might remotely have a flame source would be the exhaust, and that appears to be in decent condition in that area. Are you sure the rusty water isn't gas? Maybe a rubber or steel line cracked and is spraying gas onto something that would normally get hot. Whatever is burning may be the cause of your oil leak.
    The only way i know to find a leak is to start the motor, get under the car and watch for where the leak is coming from, but before you do that, check the condition of your gas lines and hoses. replace any thing on the gas line that looks like it might be questionable before you start it up and look for the oil leak, you may not be so lucky if you have a gas leak that was catching on fire this next time.
    Is this car something that has been sitting a while and just recently started, or has it been on the road a while and has had some recent miles put on it? Gene
  9. 270dodge
    270dodge
    from Ohio
    To check the fluid level. Engine idling, run through the gears pausing a couple of seconds in each one.
    Check in neutral- with a cold engine fill to the L mark.
    When a car with an auto transmission sets for 20 or so years the oil drains from the seal and upon starting the seal lip is ripped out.
    Chrysler recommended a 20,000 mile change interval.
  10. squirrel
    picture from his other thread. It looks like a Powerflite, eh?
  11. Dixie Rambler
    Dixie Rambler
    Thanks, Gene. It’s been on the road for about 3 months after sitting for 20 years. I think the fires started from the trans oil leaking on the exhaust.
  12. bobss396
    bobss396
    I've seen some crazy parking brake fires in similar cars.
    ClayMart likes this.
  13. Paychobilly53
    Paychobilly53
    Fluid drive
  14. Dixie Rambler
    Dixie Rambler
    Thanks, ********er. Good insight.
  15. harpo1313
    harpo1313
    from wareham,ma
    Wont get far here with that **** my friend.
