Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. JUSTIN PERSINGER
    JUSTIN PERSINGER
    Shaved my hood ornament on my 55 ford last night, just need to do a little sanding and some painting. IMG_20200521_201203.jpeg IMG_20200521_201222.jpeg IMG_20200521_201241.jpeg
    Sent from my XP8800 using The H.A.M.B. mobile app
  2. The37Kid
    The37Kid
    Of all the millions of listings on eBay there is a photo of a pair of new roller skates on the front page of my computer, that I have listed. Guaranteeing they won't sell. Bob :confused::confused::confused::confused:
    chryslerfan55 and stillrunners like this.
  3. ratrodrodder
    ratrodrodder
    from Boston
    I'm thinking there's gotta be an easier way to change drill press speeds than with a Q/C, but I can guarantee you'll be able to fling metal further than the rest of us! :D
    mark latham, 61Cruiser and X-cpe like this.
  4. HotRod33
    HotRod33
    IMG_20200518_103838.jpg . Somebody punched a bunch of holes in my car...
    chryslerfan55 and Jalopy Joker like this.
  5. Sold a pair of cyl heads and 4 bbl intake for a small block ford. Been a long time since ive sold any parts.
  6. j hansen
    j hansen
  7. LOU WELLS
    LOU WELLS
    from IDAHO
    I Did A Upgrade To My 1964 El Camino Shop Truck...Better Mileage... DSCN3756.JPG
  8. Greg Rogers
    Greg Rogers
    Took 56 for 1st ride this year. Drives and sounds like a new truck, after all new window tracks, gl*** and door seals. Really happy! IMG_3126.JPG IMG_3126.JPG IMG_3125.JPG
  9. squirrel
    Hauled home a Model T.
  10. blowby
    blowby
    from Nicasio Ca
    Well...let's see it.
    Gonna drive it cross country?
    61Cruiser likes this.
  11. The37Kid
    The37Kid
    Photos Please.
  12. squirrel
    27 coupe. It got painted, and then not really put back together all the way. Has a few things that need to be fixed, and some parts are missing. But it's a nice solid car, and it looks good (aside from the interior color!). And the roof has a big hole in it.
  13. gimpyshotrods
    gimpyshotrods
    Today I sanded smooth about 20-feet of weld.
  14. T. Turtle
    T. Turtle
    I just got up and had breakfast, but yesterday I managed to get to the car and grab the driveshaft + gearbox output yoke to take to the shop which will lengthen it after the basic setting-up of the 5sp has been fixed. Hoping to get back to the car later in the week to do more work like restructuring the cross member which on Comets/Falcons has to be cut to fit this box.
  15. oldsfrench
    oldsfrench
    from France
    95AC769B-4FDA-4FF3-AB82-1CC2558ACBE8.jpeg Put new rear shocks and sway bar
    Under my 1953 olds
    I think shocks were never replaced since 1953
    the new sway bar is not designed like the original but it fit very well
  16. Greg Rogers
    Greg Rogers
    Those look like the shocks I put on my 56 F100. Did you get them from Rockauto? The ones I got I was surprised that they have no warrantee. I bought 'em anyway and seem OK.
  17. oldsfrench
    oldsfrench
    from France
    The new shocks and sway bar came from summit
  18. winduptoy
    winduptoy
    Got the heads off the engine today. The pistons are stuck. Soaking with penetrating oil... It's 101 years old IMG_20200524_145931821.jpeg
    Sent from my XT1585 using The H.A.M.B. mobile app
  19. PoTaToTrUcK
    PoTaToTrUcK
    I had a picture frame where the gl*** broke, damaged the print that was on the inside, too frugal to throw it out I painted the print flat black, emptied the bag of dash plaques out and viola, more garage art.
  20. blowby
    blowby
    from Nicasio Ca
    Lopped another inch off my pole cap/scoops, decided to make a go if it, so sanded out all the roughness with a DA and fired up the buffer. Tech tip: if you've dislike sanding and buffing, first spend a couple hours in the yard raking leaves and pulling weeds. Makes it almost enjoyable. 20200524_120503.jpg
  21. WTF really
    WTF really
    My brother brought me the floor pans I bought from a guy in Wisconsin 20200524_095846.jpg 20200524_095850.jpg 20200524_095900.jpg
  22. Neb Hillbilly
    Neb Hillbilly
  23. Blues4U
    Blues4U
    from So Cal
    Over the past few days I got the mirrors installed, new gas cap, got the exterior door handles installed and working (first time since I've owned the truck that it's had exterior handles on it), modified the roof insert to fit better and installed it, and then fired it up for the first time in about 8 weeks, took it to the car wash and sprayed off the ch***is and cleaned things up. Cleaned up the huge spot of trans oil on the ground where it had been sitting, and topped off the trans with fresh oil (whenever it sits for about 3 - 4 weeks the oil in the TC slowly drains back into the pan and then finds its way out). Then parked it out on the lawn to shoot a few pics. Got Roscoe to pose for a photo. DSC_3861small.jpg DSC_3871small.jpg
  24. mickeyc
    mickeyc
    So Greg, whats up with the gas filler spot? I had a couple of 55- 56 Ford F100s. My 56 had the gas filler
    up high on the body to accommodate the behind the seat gas tank. The earlier models had the under body
    tank location.
    rpm56 and chryslerfan55 like this.
  25. squirrel
    Took apart a 93 year old carb...and found the plugged hole, so maybe it'll work when I put it back on.
  26. junkyardjeff
    junkyardjeff
    Went and picked up what was thought to be the torque converter for the 62 Galaxie COM I got a couple weeks ago,its definately for a Ford and the pilot fits the Y block crank but non of the splines match up and its not a 3 bolt converter for the 2 speed. I need to order the correct 4 bolt flywheel(I have the 3 bolt version) and if it fits and if we still have a converter rebuilder in town I will take it with the 67 converter that fits but has a smaller pilot and have them make me one from the two.
  27. jimmy six
    jimmy six
  28. jimmy six
    jimmy six
    Cleaning a lot of boxes and found this....cleaned up pretty good. 8F75F540-9297-4A2A-961C-F7772AC55A11.jpeg
  29. 56don
    56don
    Man I love that setup. I wish they had not become so expensive.
    Me...I did nothing car related yet.
    I gave blood at the Memorial Day blood drive. The lady that took my info was so pretty that my blood pressure was almost too high..;)
    chryslerfan55 and 65pacecar like this.
