Projects 1960 Pontiac Catalina Stick Car!
Discussion in 'Traditional Hot Rods' started by 31hotrodguy, Mar 3, 2020.
  1. 31hotrodguy
    31hotrodguy
    Picture bump. Work has been slow (I’m a ICU nurse) so no money. In the mean time I’ve pretty much been parts washing and working on stripping the fire wall. Basically doing free stuff. It’s not very picture worthy but needs to be done! [​IMG]
    j-jock, Stock Racer, scotty t and 5 others like this.
  2. 31hotrodguy
    31hotrodguy
  3. bchctybob
    bchctybob
    Hey, it all needs to be done and sometimes the low dollar stuff is the most gratifying, like cleaning and painting the engine compartment or underside of the car. I just finished stripping and painting the floor in my car and it made a huge improvement for just the cost of a wire wheel and a few rattle cans!
    Sorry your engine turned out to be basically a core but at least when you’re done you’ll have a good engine you can rely on. Love the car and enjoying following along on your progress.
  4. 31hotrodguy
    31hotrodguy
    I don’t think the engine is a total lose but we will see. I’m planning on pulling the heads and pan this weekend.
    My great dilemma is if I run the later engine I run into clutch linkage problems with the later bellhousing. If I was rebuild the 59 block and use the factory cast iron bellhousing then I don’t think my new very expensive long branch headers will clear the starter. I guess I just need to start mocking stuff up.
    loudbang and scotty t like this.
  5. Poncho60
    Poncho60
    from N Illinois
    Use a mini starter with the long branch exhaust on the early block.
    loudbang and wvenfield like this.
  6. 31hotrodguy
    31hotrodguy
    Do they make one for the 60 block? That would solve a lot of problems.
  7. 31hotrodguy
    31hotrodguy
    Boys and I started taking the 63 389 apart. [​IMG][​IMG]
    Looks pretty clean up top. [​IMG][​IMG][​IMG]
    Heads look clean.
  8. 31hotrodguy
    31hotrodguy
    Looks like pistons are 0.030. Are these the generic 4 valve relief pistons that accept both cylinder head angles?[​IMG][​IMG]
    Old wolf, loudbang and kidcampbell71 like this.
  9. 31hotrodguy
    31hotrodguy
    Does anybody have an idea what cam this is? [​IMG]
    On the side it says 1805? It is a replacement cam for sure but does anyone recognize the part number? I’ve tried looking it up.
    Thanks
  10. 31hotrodguy
    31hotrodguy
    And my 20 yr old gates belt just broke on my 50 yr old compressor thus bringing all bead blasting to a sudden halt! Adjustments.JPG
    kidcampbell71 and loudbang like this.
  11. Is it still under warranty?
    :D
  12. 31hotrodguy
    31hotrodguy
    I wish! I couldn’t find one local so I ordered online. Hopefully it will be here in a few days. Plenty of parts washing to do in the mean time. [emoji6][emoji1303]
  13. 31hotrodguy
    31hotrodguy
    Duck’s Goat suggested this bracket from BOP performance so I ordered one today! Hopefully this will solve my clutch linkage dilemma. It would be nice if it works with the ****tered shield but if not I’ll probably switch to the factory bellhousing. [​IMG]
  14. 31hotrodguy
    31hotrodguy
    Now that my dinosaur of a compressor is back online progress has started up again! A bead blast cabinet is such a game changer!!!! Adjustments.JPG
  15. Rocky
    Rocky
    Classified Editor
    Keep goin! I'm following your work. As for the double eyebrow pistons.....I dunno. I'm using late [1974] heads on a '57 block and even with my .125" over Jahns pop-up pistons I have plenty of valve/piston clearance.
    31hotrodguy and loudbang like this.
  16. 31hotrodguy
    31hotrodguy
    Thanks Rocky! I appreciate the encouragement!
    What size valves are in your heads?
  17. Rocky
    Rocky
    Classified Editor
    1.96 intake, 1.66 exhaust. Using big block chevy 7/16ths screw-in, adjustable studs, factory Pontiac pushrod guide plates and hardened seats.
    Elcohaulic, 31hotrodguy and loudbang like this.
  18. Liking this thread, great you’re getting the young fellas on board, they grow up way to quick.
  19. 31hotrodguy
    31hotrodguy
  20. 31hotrodguy
    31hotrodguy
    And from what I remember you telling my your coupe runs pretty good times with that set up!
  21. sloppy jalopies
    sloppy jalopies
    buddy just picked up an early '60s poncho ****tershield… PM me if interested... may not sell...?
  22. 31hotrodguy
    31hotrodguy
    Because of the clutch linkage issue mounting to the bellhousing I had to set aside the ****ter shield an I ordered a factory bellhousing from that famous auction site. Now I can start mocking up the engine clutch linkage and exhaust manifolds.
    scotty t and loudbang like this.
  23. 31hotrodguy
    31hotrodguy
    I forgot that the older engines used 7/16 bolts for the bellhousing so I’ll have to drill out the newer BOP bellhousing!
  24. 31hotrodguy
    31hotrodguy
    At only 91 degrees today we got some of the firewall partially stripped! Adjustments.JPG [​IMG]
    I’m not going for full resto but I figure since the engine is out is like to detail the engine compartment.
    Elcohaulic, greaser, loudbang and 3 others like this.
  25. A 65 bell will not fit a 59 or 60 block, and a 61 thru 64 block uses a bell housing mounted starter the 65 bell uses a block mounted starter. In other words it will not work and that billett part is as worthless as ***s on a boar hog.
  26. Gman0046
    Gman0046
    IMG_0104.JPG What the Wolf Man says is why my 60 Pontiac has a 65 engine block to accommodate an 87 Buick Grand National 2004R. BOP bolt pattern.
  27. 31hotrodguy
    31hotrodguy
    A 65 bell will not fit a 59 or 60 block, and a 61 thru 64 block uses a bell housing mounted starter the 65 bell uses a block mounted starter. In other words it will not work and that billett part is as worthless as ***s on a boar hog.[/QUOTE]
    Old wolf,
    I have a 63 block with a later bellhousing and the starter adapter from butler performance which from what I understand should solve my starter problem.
    As for the billet adapter I haven’t mocked everything up so I don’t know what part of it won’t work. They claimed it would bolt to the clutch linkage.
  28. 31hotrodguy
    31hotrodguy
    Sorry Gman0046 but an automatic is not in the Catalina’s future.
  29. Gman0046
    Gman0046
    I've had my share of standard shift cars. The 2004R is my first 4 spend automatic and thought I'd give it a try. I sure can't complain about the road trip gas milage and low engine cruise RPM's. Haven't been on the road too long but so far so good.
  30. 31hotrodguy
    31hotrodguy
    From what I understand that are a good trans. I actually have plans for one with a 57 Chevy custom (or my attempt at a custom) if it ever materializes. But as for the Pontiac it gets a 4spd for sure.
