Projects 26 T Roadster Pick Up build Thread
Discussion in 'The Hokey Ass Message Board' started by Blue One, Mar 27, 2010.
  1. T27owner
    T27owner
    from Nebraska
    This has been a awesome build following from the start, inspirational I need to get back on mine.
    loudbang, bobbytnm and Blue One like this.
  2. Blue One
    Blue One
    from Alberta
    I posted in a separate thread about an issue I had with poor quality lug nuts.
    Trying to remove my wheels for brake adjustment I encountered a seized and galled lug nut on the driver’s rear wheel that cratered it’s threads when it was torqued at the inspection.
    It wasn’t coming off no matter what.
    Getting it off destroyed the nut and stud.
    The studs for my winters quick change aren’t available anywhere in Canada so an order was placed to Speedway and a full set of genuine Winters studs showed up by courier 3 days later :cool:
    Then I went to the local self serve wrecking yard a got a set of OEM lug nuts off some Crown Victorias.
    They are much better quality thread and fit than the Chinese **** I had.
    During the brake adjustment I looked at a problem I’ve had with my rear brakes that existed since they arrived with my quick change.
    They’re new 11” loaded drum brakes from Currie.
    I couldn’t seem to get the self adjuster arm for the left side (drivers side) to contact the Star wheel so that it would work properly.
    The right side was fine and worked well.
    Finally I decided that somehow it didn’t look right, it looked poorly stamped and deformed and dimensionally wrong.
    I picked up a Raybestos self adjuster repair kit and installed it. Perfect :cool:
    Comparing the new piece to the one that came with the left brake it was obviously a manufacturer defect. But it’s fixed and only cost me $20 :D
    Brakes are adjusted now and should be much better.
    Since it’s going to be raining for the rest of the week I’ll clean up the garage and then I’ll have the music on and the buffing and polishing stuff will get well used getting after the paint that I haven’t got to yet :cool:
    Larry
    0F264A96-E7E1-4669-9BBA-3EEC488CB10A.jpeg 7F03523C-8AC8-437E-8092-C25586F50711.jpeg 02D9609C-7ABB-48A6-9050-46318A4F8607.jpeg
    Dino 64, OFT, loudbang and 4 others like this.
  3. Blue One
    Blue One
    from Alberta
    Spent the last 2 rainy days in the garage with the heat on and the tunes too.
    Had the rear of the RPU up on the jack stands and found that I had to put the front on 6” blocks to level the carbs because fuel was seeping out of the front carb.
    Up on the blocks leveled out and it stopped.
    Went through the brake adjustment front and rear and then started buffing and polishing paint front to back.
    3000 grit and 5000 grit Trizact pads and then the 3 stages of 3M Trizact polishing compounds.
    I cut through the paint in 3 spots on edges :oops:
    because of the single stage paint I was able to mix a little bit and touch it up and then gently blend it in and then polish. :)
    A final coat of Mother’s Carnuba wax would finish it off.
    The street sweepers have been through our neighborhood and enough of the street’s in the area are cleaned up so that tomorrow when it’s warm and sunny it will be time for a little run to test things out :cool:
    AF8ECCF8-CD93-4655-B704-B20D1D2F9613.jpeg DE3F1206-65AE-4F42-9053-05EEDD0FAD36.jpeg
    Dino 64, Shadow Creek, Tim and 11 others like this.
  4. rusty rocket
    rusty rocket
    SWEET! Good luck! Hope you don’t get cramps in your cheeks from smiling.
    bobbytnm, loudbang and Blue One like this.
  5. 57 Fargo
    57 Fargo
    I’ll be down there tomorrow, hopefully I see it out cruising[emoji41]
  6. Blue One
    Blue One
    from Alberta
    Good luck with loading up your new acquisition.
    We’re waiting patiently for the reveal. :D
    You may not see me, I probably won’t stray far from home initially :D
    loudbang, 57 Fargo and kidcampbell71 like this.
  7. 57 Fargo
    57 Fargo
    Thanks, I’ll start another thread on it. Apparently jumping the gun was a bad idea!
    It’s a quick trip there, load the car, headed back home. Won’t see much of the city either.
    Good luck on the maiden voyage.
  8. kidcampbell71
    kidcampbell71
    Ha !! Had to visit Blue to get the scoop on Fargo's new ride. :D Great timing !
    Blue One, loudbang and 57 Fargo like this.
  9. Rickybop
    Rickybop
    Saw your thread back up. Thought I might've missed your maiden voyage. Nope, just in time. Good.
    Truly happy for you, Larry.
    Seems sometimes as though some of the more prolific builders around here only have to fart and a hot rod pops out. Others of us might be able enough to build only one awesome car in a lifetime. And the whole hot rod dream is right there in that one car.
    You guys were talking about "grinning from ear-to-ear". If I had worked as long and hard as you have to build such a nice hot rod... and FINALLY fulfilled my dream... I'd be grinning from ear-to-ear, too. And I know I tend to be a bit of a softie, but I gotta say... and I don't mind saying... that I think I'd also be experiencing some fairly deep emotions. For good reason.
    Cheering for you. [emoji2]
    brEad, Stogy, Blue One and 2 others like this.
  10. 57 Fargo
    57 Fargo
    I feel like with your attention to detail you could jump in that thing and drive it across the country!
    Let’s see pictures when it’s out, looks like it’s going to be a beautiful day!
  11. 26 T Ford RPU
    26 T Ford RPU
    Video!! sight, sound, movement and a smiling Larry.:cool::cool::cool: JW
    bobbytnm and loudbang like this.
  12. Rickybop
    Rickybop
    Seems kinda fitting that your hot rod is emerging at this time. It's Memorial Day weekend... when we celebrate our freedom... and the cost ***ociated with it. The birds and blooms are emerging... new life. And of course, that we're all hoping that we too can soon emerge... to get back to normal... to be free.
    I think we'll all remember when Larry got his hot rod roadster pickup on the road. [emoji5]
  13. Rickybop
    Rickybop
    Go, Larry... be FREE! [emoji1]
  14. Blue One
    Blue One
    from Alberta
    Thanks guys. I’m over the top happy with my adventures today.
    First I plugged in my GPS speedometer sky drive antenna module ( Cl***ic Instruments) and did the simple calibration.
    After that I stuck it on the inside of the body just under the dash on the p***enger side with some 3M mounting tape and when the upholstered kick panel is in place it will be hidden out of sight and protected from the weather.
    Then I tightened the lug nuts and took it out for a short test drive and came back home.
    Adjusted the idle and added a little more transmission fluid.
    Also had to replace the connector to the brake light switch which wasn’t making good contact.
    After that I headed over to the other side of the city to visit my buddy Dave.
    Wanted to show him the finished car.
    He loved it.
    I’m really pleased with the way it drives.
    No wobble no bump steer at any speed.
    The Excelcior radials are really good and it handles like it’s on rails.
    We got the alignment right on judging by the way it’s handing.
    The suspension front and rear work really well and the ride is better than I thought it might be.
    I had it rolling along the ring road hiway heading to Dave’s place at 120 KPH.
    No problem at all smooth and steady.
    The quick change is loud like I knew it would be, between wind exhaust and that ear plugs
    are required for the hiway.
    Overall it has come together as a great little hot rod.
    I may try a set of helical gears in the quick change just to see what they’re like.
    I can’t stop smiling. Put 65 kilometres on it. :cool::)
    61BC7409-DFC6-4B1A-A8B1-BA951E12E736.jpeg EAEF6C34-72ED-489C-A730-377899E27B3B.jpeg D893447B-39D4-4CB6-9501-DEAE397AE0F3.jpeg 3797B136-1B0A-4974-87FB-644C631E2FB2.jpeg 3FF8FEC8-37A7-4200-B8CC-474AC3F5F7F4.jpeg AE31D1CF-C745-4179-9A69-BBC968315F8D.jpeg
    ALCAN AV8, Dino 64, DesmoDog and 23 others like this.
  15. brEad
    brEad
    Awesome car. You look great sitting in it instead of on it, too.
  16. Rand Man
    Rand Man
    So awesome. Glad to see you out and about.
  17. 26 T Ford RPU
    26 T Ford RPU
    So happy for you Larry, its just way cool and you should be every bit as pleased as you look. :cool::cool::D JW
  18. Rickybop
    Rickybop
    Let's see... 120 kph is equal to about 75 mph. In a hot rod Model A Roadster pickup. Yeah... I can almost feel it.
    0 to 120 kph is fun, too? [emoji16]
    Sounds like you had a great first outing. Congratulations!
  19. Rickybop
    Rickybop
    Sorry... model T... not A
  20. Blues4U
    Blues4U
    from So Cal
    This has been an epic thread, thanks for taking us all along for the ride! Congratulations on a job well done. Hope it isn't too much longer till the roads are cleared enough to get it out and enjoy it.
  21. Six Ball
    Six Ball
    from Nevada
    Well done, it looks good on you. Just the right color to go with your smile.
    I took my '53 on a run today too. I had to replace a stop light bulb and air up the tires. Nothing glamorous the first dump run of the season. My smile didn't compare to yours. :D
  22. razoo lew
    razoo lew
    from Calgary
    That looks great, you made a helluva car. Terrific to see it on the road; you deserve to be as happy as you look.
  23. 57 Fargo
    57 Fargo
    That’s awesome Larry, I made it home at midnight, I’ll post some pictures in the morning
  24. AndersF
    AndersF
    Congrats, I hope you got alot of nice rodsterweather now.
  25. Blue One
    Blue One
    from Alberta
    Another one set to drive off.
  26. Blue One
    Blue One
    from Alberta
    And a little video of the warm up before the first run :cool:
  27. loudbang
    AWESOME it's been a long slog for you and the members following your build. The Result is a Extremely desirable HOT ROD. Have some fun driving now. :)
    kidcampbell71, bobbytnm, OFT and 2 others like this.
  28. Rickybop
    Rickybop
  29. 57 Fargo
    57 Fargo
    Glad it went well, looks great outside! It was beautiful roadster weather down there yesterday.
  30. rusty rocket
    rusty rocket
    Hell yeah!! The feeling is amazing! I know a few years ago after 10 years of work on my deuce sedan when it fired and drove for the first time I had to wipe a few tears away, it had been a long haul.
    bobbytnm, Blue One and loudbang like this.
