Projects 33 Doll Build Page
Discussion in 'Traditional Hot Rods' started by 33Doll, Mar 20, 2020.
  1. 33Doll
    33Doll
    Thanks! Actually that has been on my mind the whole time I’ve been keeping my eye on that! But I did forget about the driveshaft maybe not coming in and out! I’m glad Dirk mentioned something the other day except for flipping it over is not gonna work!
  2. Johnboy34
    Johnboy34
    from Seattle,Wa
    Are you going to make 4 of those brackets to put the mounting bolts in double shear? And a similar but bigger bracket to box the X member where that cross member attaches? Then go to the outside rail, boxed the same where attached?
  3. 33Doll
    33Doll
    Si! Senore! That’s the Idea or close.
    And lots of gussets! I have to repair the broken and Bent pieces on the frame rails before I get into all that, its just the beginning stages. So its pretty bare looking right now. You’ll See! [emoji4]
    chryslerfan55, Stogy, brEad and 3 others like this.
  4. 33Doll
    33Doll
    Got The Tabs Made, Mocked and Tacked! Now I can Finish Weld, and Gusset the **** out of it! Then, fix the bottom frame rails, and straighten.
    And it’s just a matter of welding the crossmember in and then boxing the rails around it. Adding some horizontal braces to the outer rail.
    IMG_9757.JPG IMG_9758.JPG IMG_9759.JPG IMG_9764.JPG IMG_9763.JPG IMG_9765.JPG Adjustments.JPG Adjustments.JPG
  5. 33Doll
    33Doll
    Well I finished the crossmember!
    I jazzed it up a little bit, not to
    Snazzy-Jazzy!
  6. brEad
    brEad
    Looks good. Are you planning to add diagonal braces from the crossmember to the frame as well?
  7. 33Doll
    33Doll
    Thanks!
    Yeah, after I box it, 3 Triangle Gussets. one top, Vertically, and 2 horizontally, attached to the square Tubing, for forward and Backward torque. All that Flathead Horse Power you Know! Ha!
    loudbang and brEad like this.
  8. 33Doll
    33Doll
    Need
    Some inspiration!
    Heres Mr. Flatty.... still Patiently Waiting!
  9. Ohhh were that Flatty looks good
    The forward Torque from acceleration (Engine output x 1st gear trans x rear axle ratio) and rearward torque from braking will be at play back here. F3014875-86C1-44A5-B652-F71845429601.jpeg
  10. 33Doll
    33Doll
    Got my gussets and extended outer rail plates all cut!
    Boxing plates were cut yesterday!
    No holes, just arched on the ends to match the curved link gussets.
    So its gonna be welded on the inside of the X-member bottom, and side,
    Then boxed, with a notch around the square tubing, then welded, to the plate there also, then the gussets, and then the outer rails welded to the plates you see there, top, and bottom. I don’t want to box the outer rails right there. Want to Keep it open for fuel lines, wiring, and electric pump.
    Not to much Jazz!
    I think its gonna function fine AND look good!
    It will be about WAY stronger than the previous setup, is all I know.
  11. 33Doll
    33Doll
    Yeah, the back is really beefy, 3/8 plates, plus the inside of the tube still has the forged solid steel core, which was not cut when I pie cut the tubes.
    Heated and slowly brought them in, then closed up the tubes. Its solid back there.
    chryslerfan55, dwollam and loudbang like this.
  12. 33Doll
    33Doll
    Welp!
    33’ time is on Hold for a Month!
    Had an emergency Appendix removal last Night! (Not Fun! Really Sore today)
    So I’m Bummed!
    But My Pops sent me a few pictures of the 33’ a few years ago that I didn’t have, it was still together, just sitting waiting for me!
    E5DAEAA1-A17B-4FA4-952D-207F8EE67542.jpeg 2E8924FB-7DA6-4C55-B390-516F0924F004.jpeg
  13. dumprat
    dumprat
    from b.c.
    Looks great with aluminum slots on it!
  14. 33Doll
    33Doll
    Yeah, I think those went with 34’ behind it, I got the wires.
  15. 33Doll
    33Doll
  16. dumprat
    dumprat
    from b.c.
    I personally am not a fan of wires. Too lowriderish.
  17. alchemy
    alchemy
    Appliance wires with 50 series white letter tires. Keep them, as the 1970 era of hot rodding will be coming back into vogue any day now.
  18. guthriesmith
    guthriesmith
    I like the look with the slots!
    Also, praying you recover quick from the surgery. Sounds like no fun.
    brEad, 33Doll and loudbang like this.
  19. Dirk35
    Dirk35
    Looks good. Maybe you already have this planned (you might have even said so and I just missed it) , but if not, another option instead of welding it into the original frame crossmember, you can make it to where it bolts onto the crossmember similar to these pictures of removable crossmembers.
    Crossmemeber.jpg F221280555.jpg images8TPUO6CP.jpg KVB500060__31939_1566732181.jpg tko-5-speed-crossmember.jpg
  20. 33Doll
    33Doll
    Thats what it had on it when I was a kid-Teen thats why I wanted them even though they are out dated
    I don’t have any good pics with them on it though. FFB81D18-7B16-4142-BCB8-69AB6DC28A28.jpeg IMG_7471.JPG
  21. 33Doll
    33Doll
    I always liked the stance with those wheels on it you can see the way it has a nice rake, and fat-rear look in this pic even though its blurry IMG_7018.JPG
  22. 33Doll
    33Doll
  23. rusty valley
    rusty valley
    did the family 40 pickup go away?
  24. 33Doll
    33Doll
    That pick up has a little story of its own. my grandfather and uncle (on my moms side) we’re going to build it when my uncle was in high school, but got over their heads, so Pops being the car guy, ended up with it.
    Yes it eventually did go away. He made some sorta of cash up front deal, and built my Aunt Dolly the 40 Pickup. In order to get the 33 Doll.
    but he took so long building, it like seven years or more, she was pissed and when she finally got it. I think she drove it for a little bit and sold it, and bought a 65 Mustang convertible! (Which another Uncle ended up with Lol!)
    I should Write a book, about my family!
    Don’t laugh! Thats me in the 80’s
    Rocker dude!
    IMG_6169.JPG IMG_5806.JPG IMG_5805.JPG BCF36171-1759-46F9-8C8E-AA60EDBC6892.jpeg
  25. 33Doll
    33Doll
    Well! Had My Appendix Taken out Tuesday... Back in ER Saturday night for a Hernia... down there! Swollen like a balloon!
  26. dumprat
    dumprat
    from b.c.
    Keep kicking!
    loudbang and Stogy like this.
  27. Stogy
    Stogy
    x2...speedy recovery...ouch...been there done that twice
  28. brEad
    brEad
    That ****s. Prayers for a speedy double recovery!
    Stogy and loudbang like this.
  29. LSJUNIPER
    LSJUNIPER
    from ct
    That stinks!
  30. Dirk35
    Dirk35
    Hope you have a speedy recovery buddy!
    chryslerfan55, loudbang and 33Doll like this.
