Projects It’s alive!!! A 1964 Chrysler tale....
Discussion in 'The Hokey Ass Message Board' started by 57 Fargo, May 25, 2020.
  1. 4274SPEED
    4274SPEED
    Love it! All of those Mopars from the late 50s into the 60s have a feel of their own. The way they ride and sound brings back many good memories. Anyway, congratulations!
    Thor1, loudbang, Blue One and 2 others like this.
  2. Gotgas
    Gotgas
    from DFW USA
    Hard to beat a great big old American convertible! :D That car looks to be in great shape. You'll be having fun with it in no time!
  3. 57 Fargo
    57 Fargo
    Nope if it’s correct a 383 was the only option.
    A couple more pictures.
    The oil is spotless. A battery will go in tomorrow to see what works and doesn’t work. Hopefully will run as well.
    61Cruiser, 1947knuck, LAROKE and 8 others like this.
  4. 57 Fargo
    57 Fargo
    You wouldn’t believe the stuff out there, and I haven’t seen it all yet, there will be another trip for the parts car in the near future.
  5. Budget36
    Budget36
    The oil is spotless because everything has settled over the years.
    At least flush the pan before filling with fresh oil.
  6. 57 Fargo
    57 Fargo
    Quite likely, however I can pull the dipstick on other stuff here that has sat just as long and it’s not this clean. I appreciate the input and can ***ure you it’s not the first time I’ve done this.[emoji3] We will hopefully have some results later today!
    61Cruiser, Thor1, Sandgroper and 6 others like this.
  7. raven
    raven
    Is it a low mileage car? Looks to be.
    r
  8. 57 Fargo
    57 Fargo
    I think the odometer shows 95,000 miles
  9. 57 Fargo
    57 Fargo
    It runs!! Actually sounds pretty good. Getting tuneup parts tomorrow, have to get the old fuel out and get a carb kit, so far everything I’ve tried works fine, power windows and seat.
  10. Lloyd's paint & glass
    Some guys have all the luck :D That's good news man ;)
  11. 57 Fargo
    57 Fargo
    Hey I paid up to buy this car by my standards!
  12. Lloyd's paint & glass
    Yeah I'm sure it wasn't cheap! Otherwise it wouldn't have taken 4 years to talk them out of it ;)
  13. 57 Fargo
    57 Fargo
    I think I got an ok deal but it wasn’t exactly cheap, so far everything works, it sits and idles, all I did was change points and it’s running off a gas can. Gauges all work, lights all work, the horn, radio, power windows and power seat are working.
    Need to figure out how to add oil to the top motor, I’m new to this convertible stuff!
    Here’s some ****py pictures of the floor, its hard to take quality pictures laying on your back.
    Hnstray, catdad49, 1947knuck and 8 others like this.
  14. Baumi
    Baumi
    Looks pretty solid and unmolested ! That 's a jewel!
    loudbang and Thor1 like this.
  15. 57 Fargo
    57 Fargo
    It’s pretty nice, there are definitely areas on the body that have been worked over, but overall it’s a pretty nice car
  16. Lloyd's paint & glass
    Hey you remember that green truck you was building? What ever happened to it? :p:D
  17. Jack E/NJ
    Jack E/NJ
    from NJ
    >>>Need to figure out how to add oil to the top motor, I’m new to this convertible stuff! >>>
    It's nasty brake fluid if original. Flush pump & cylinders with alcohol to get it all out. Replace with ATF. Seals are compatible. Jack E/NJ
  18. 57 Fargo
    57 Fargo
    Yea, yea it’s sitting right beside it, it’s been cool and raining here so not ideal body work conditions, don’t worry it’s still in progress!![emoji2]
  19. 57 Fargo
    57 Fargo
    Thanks, is there a disadvantage to the brake fluid?
    chryslerfan55, loudbang and Thor1 like this.
  20. Lloyd's paint & glass
    Well yeah, it slows stuff down, even stops it! Get it? See what i did there? Jesus I'm funny! You're welcome Fargo :D
  21. stillrunners
    stillrunners
    from dallas
    Agree big time - even be nice to change the ****** oil/filter....put the rear tires off the pavement - on jack stands after starting - to run it thru the gears.....good luck and have fun !
  22. stillrunners
    stillrunners
    from dallas
    Brake fluid will rust what it touches....using ATF in my mopars - think you let the top down to check level - fill as needed then - and see how it does going up - might have to cycle it to get any air out.
  23. 57 Fargo
    57 Fargo
    It’s already running and goes into gear fine, the top went down fine, doesn’t want to go back up, pump runs and everything so that’s why I’m wondering if it’s low, I pulled the rear seat and don’t see any leaks. Need to fix the brakes and wheels and tires then away we go!
  24. 57 Fargo
    57 Fargo
    Oh boy.....[emoji53]
  25. Irvan
    Irvan
    It's beautiful
    Thor1 and loudbang like this.
  26. 57 Fargo
    57 Fargo
    Thanks man. I can’t wait to get it out and all shined up.
    catdad49, chryslerfan55 and Thor1 like this.
  27. AndersF
    AndersF
    Good score well worth the waiting.
    A friend of me and i talked about it about three years before he decide to sell his 63 to me.
    He parked the car about 10 years ago and bought a 60 Chevy with the intend to give the Chrysler some needed love.
    But he never really got started. But he had owned the Chrysler since 89 and put m***ive amount of miles trough the years so it was not a easy sell for him.
  28. 57 Fargo
    57 Fargo
    Beautiful car! The four year wait was to get my **** together! The car was his dads and when his dad got sick the car was parked in the garage and just never moved again.
  29. 57 Fargo
    57 Fargo
    Runs off of its own tank now, top goes up and down, all the bleeders opened no problem, tomorrow is tune up and bleed brakes and see how it does.
    And hopefully it’s not raining so I can clean it up!
  30. 57 Fargo
    57 Fargo
    Anyone have thoughts for wheel and tire combos? The front cap is 59 Dodge, they are ok.
    dan31 and loudbang like this.
