Technical Battery Maintainers
Discussion in 'The Hokey Ass Message Board' started by jaw22w, May 27, 2020.
  1. Pats55
    Pats55
    from NJ
    jaw22w likes this.
  2. Truck64
    Truck64
    from Ioway
    A "trickle" charger to my mind is an unregulated charger, the kind that really needs to be on some kind of timer. An example are the 2/6 amp chargers Schumacher and Sears and Wards and everybody sold for years and years. Modern "smart" chargers have some kind protection circuitry or float voltage mechanism to prevent boiling out the electrolyte. Sometimes the terms "trickle" are used interchangeably. What kind of charger was it?
    I agree paranoia is a healthy thing when it comes to batteries. There is an awful lot of potential energy stored in them.
    I actually like the old school "dumb" chargers for re-charging, I think they do a better job of getting them completely charged up than the micro-amp maintainers like the BT. It takes a long time to recharge even a halfway depleted battery at low amperes and the BT will automagically switch to float charge before this process is complete, to avoid excessive outg***ing.
    What it looks like to me from measuring charging voltages, the old school taper chargers were "sized" by way of their transformer, to top out at a certain range of end current and voltage for a typical automotive start battery. Since wintertime starting was the general problem they were kind of "tuned" for that situation. In zero wintertime temps, a battery has a high internal resistance and needs lots of juice to recharge, the charger could probably be left connected at 6 amps without hurting anything. Once things warm up though, the unregulated voltage will rise very high, 17 volts or more, and boil the battery dry.
    clunker and jaw22w like this.
  3. Chappy444
    Chappy444
    Joe Blow and jaw22w like this.
  4. Blue One
    Blue One
    from Alberta
    I have a dual battery tender and they work fine on my AGM batteries.
    Joe Blow likes this.
  5. no55mad
    no55mad
    Are the solar battery tenders still available? Some new cars used to come with them but only stayed in the cars during transport and storage, then removed before a sale.
  6. clunker
    clunker
    from Boston MA
    I misspoke, it was in fact a “battery tender”. Made by Duracell. It wasn’t cheap. The smart kind you can leave attached to the battery indefinitely. I never did that though, I just disconnected it after the batteries were fully charged (multiple motorcycles and vehicles), so I would cycle it around, repeated a few times over the winter. It actually was connected for less than 8 hours, like over night. There was no fire, no dramatic scene, just a bunch of pieces of the top of the battery
    ****tered around, I didn’t even notice until my arm started burning a bit from touching some of the acid on a surface. Kind of a mess to clean up.
    Not really a cautionary tale, I still use battery tenders, I think it was just a fluke. But I don’t really trust some gizmos. They work just fine until they don’t.
    wraymen and Truck64 like this.
  7. 325w
    325w
    What he said. Never a problem with one of these.
  8. Chappy444
    Chappy444
    See my post above... I think NAPA still sells them and I posted a link to them available on amazon... if those are the same "Solar" brand you are referring to.
    Chappy
  9. rosstom
    rosstom
    I got a Deltran battery tender from 4wheelonline. I have had it for about 7 years now and never had a problem.
  10. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Yes, battery tender brand makes one ( i have one thats awesome) and theres lots of knockoffs. I love my BT brand, my neighbor saw it and got a knockoff... he still has to jump his car
  11. Maybe I'm the oddball, or maybe it's because I am too cheap, but I move my batteries around car to car every now and then to keep them from getting too stale, and to exercise them every now and then
    WHY BE ORDINARY ?
    chevyfordman and Truck64 like this.
  12. wraymen
    wraymen
    clunker, just curious what make the battery was. I have had two from Interstate give me problems. One swelled up to the point of bending the hold down bracket. This happened quite some time ago though.
  13. 73RR
    73RR
    Another vote for the HFT unit. I have 4 of them working right now and no issues with dead batteries.
  14. BigDogSS
    BigDogSS
    from SoCal
    I agree. I never leave any kind of battery charger on a battery 24/7. My battery issues went way down since I started plugging my "smart charger" into a simple timer. After the battery is fully charged, I plug my smart charger to a timer. I set the timer to run the battery charger for 1 hour per day. Done.
    Truck64 likes this.
  15. Truck64
    Truck64
    from Ioway
    What I've read, is "stationary" lead-acid batteries - used for dedicated backup and the phone company and things like that have an expected life span of about 20 years. These are kept charged (I guess) and away from heat, and vibration.
    Nobody's gonna get 20 years out of a car battery but only 2 or 3 years isn't acceptable either. Maybe it's a matter of neglect. Different ways of approaching things depending on philosophy, safety, or maybe wallet. Some guys are perfectly fine with buying junkyard batts at $20 per.
  16. clunker
    clunker
    from Boston MA
    That can’t be good. Duralast, but I’ve had good luck with Interstate in the past.
  17. Dusty roads
    Dusty roads
    Battery Tender Plus for 2 vehicles with Odyssey batteries for over 10 years with no problems.
  18. indyjps
    indyjps
    Lightning - read up on lightning rods, you may want to install one if you get that much action. The ground rod for your electrical service is not a necessarily a lightning rod.
    Depending on your soil type and and moisture level the minimum code electrical ground rod may not be as effective as needed.
  19. indyjps
    indyjps
    Deltrans - readily available, my buddy who manages a vehicle and equipment fleet said they work great. I now own several. Have a few harbor freight tenders that get used for small equipment.
    After having trouble with new chargers failing in a short amount of time, I only buy schumacher now.
    I actually try to buy old chargers from farm or estate sales, if I can find one without a computer, Im happy.
    Have a 2 extra chargers solely for electrolysis derust.
    Truck64 likes this.
