History 55 chevy gasser find!!!
Discussion in 'The Hokey Ass Message Board' started by gripelec, Aug 19, 2010.
  1. Mac_55
    Mac_55
    Im not really sure , They will be replaced before it hits the road simply because they are not safe , ill get a size when i run over to the folks place tomorow.
  2. gripelec
    gripelec
    What tire are you going to?
  3. gripelec
    gripelec
    I NEED A 57 PONTIAC REAR END HOUSING!!!!!! WHO's GOT ONE????
  4. R. Seghi
    R. Seghi
    I have a '55 (Ithink) Pont. third member if you need?
  5. gripelec
    gripelec
    Thanks I need is a housing, and stock length 35 spline axles.
  6. gripelec
    gripelec
    I already have a carrier but I apretiate your help
  7. R. Seghi
    R. Seghi
    I have axles. I'll check what spline tomorrow.
  8. gripelec
    gripelec
  9. EMPEROR CHUCKYBOY
    EMPEROR CHUCKYBOY
    LOOKS GREATT BRO! WHEN I JUST SAW THOSE SEATS THEY ARE COOL IM GOING TO LOOK INTO THOSE SOON.... iVE BEEN MOTIVATED! i actually had luck with my 56 as well, i bought mine for 800$ and traded the original frame for a 57 g***er straight axel equiped set up straight across... i just bought a 57 olds rear that came out of a 40 ford drag car she holds 5.30s i paid 6 bills for it . im just slowly ***ming around the corner. next is the wheel wells. im graphing 55 buick wells in the rear... keep up the good work bro...
  10. gripelec
    gripelec
    Thanks man, yours is looking good too
  11. gripelec
    gripelec
    I need advise, my axle is too wide as I have stated before. 46-53 front I-beam streight axle is 50-1/2 king pin to king pin, thats what I need. Now the problem is my leaf spring location is 31-3/4 center to center. On the 46-53 truck axle its 26.6 center to center of leaf springs. What in the Phuck do I do with that???? Am I stuck with what ive got? does anyone else have this problem? and corrected it somehow? I dont want to cut off what ive got but it seems that is the only way to get all my wants and needs fixed. I want my wheels at stock width and what I have now looks stupid....Please help. What other streight axle has 31-3/4 center to center on leaf spring mounts and 50 inch king pin to king pin? Call me at 512-809-3711. My name is graham. Thanks. or post up what you got and pics, or send me some liks to other 55 g***ers with this problem.
  12. swade41
    swade41
    from Buffalo,NY
    Well if you don't want to cut anything you're going to have to get a tube axle made that accepts your spindles. That would be your easiest solution.
  13. gripelec
    gripelec
    please tell me more, how does it connect to my leaf springs, do i need to use radious rods or hairpins? what about the shock mount? who makes one for my aplication/ thanks swade41.
  14. gripelec
    gripelec
    i appoligise for my lack of knowledge on these front ends. Never had one like this before. Lots of guess work and head scratching, especialy since this front end was made in the late 60's with s****s put together and not knowing the origin of alot of parts on the car ie brake braket cut out and mede to accept disk brakes, the calipers, what the axle was out of, the reason one wheel is 3.7 inches further forward than the other. some say it was a way to cheat the light, others think it was lazyness, and I think someone quit in the middle and said phuck it hints the ****py welds after the frame rails were welded in. i do really apreciate the input.
  15. dirtyball
    dirtyball
    from G town Ks
    what size tire and wheels you running on the back an whats the offset​
  16. 1971BB427
    1971BB427
    from Oregon
    You really don't need a different front axle. The 55-59 axle is not too wide if you run the right wheel, with the right backspacing. Of course with a 7" wheel it will always look too wide, but a 3.5"-4.5" wheel will fit and look great.
    Why not look into a pair of Rocket 10 spokes if you don't mind new, or a used pair of slots in narrow width?
    I had a '56 Chev truck axle in my '55 g***er with 4.5x15 Fenton slots and skinny tires. It looked great, but 3.5"x15" look a tiny bit better! That's what I'm running on my present g***er. Found mine on the G***er Forum complete with new tires for $500 a pair.
  17. dirtyball
    dirtyball
    from G town Ks
  18. EMPEROR CHUCKYBOY
    EMPEROR CHUCKYBOY
    heres a ford axel with 15x4.5 rockets 5.60 firestones piecrust on the front to me it looks dead on for width....hope this helps:)
  19. nitrohonkey
    nitrohonkey
    I love the art work on this car! Cool build/find!
  20. firstgenaddict
    firstgenaddict
    from SC
    A 67 427 Block with Vette Suffix Code is valuable... as is a complete correctly dated 1970 LS6 - as long as the factory ***embly Stamps (behind the Alternator on the flat pad Ex: T0505JJ decodes to Tonowanda ***embly 5th month 5h day JJ - L89) and block broaching are unaltered.
    Both are most likely worth more than the cost of buying and building an engine to the same or better specs.
    A complete dated 70 LS6 engine will bring 5-6k or more as a restoration engine to install in a car which was built during the same time period, if the car is still around the owner may be willing to pay MUCH MORE!
  21. myron h
    myron h
    some guys have all the luck congrates on the find and deal
  22. Saxxon
    Saxxon
    There is a ton of straight axle stuff on the HAMB, just do a search and take your time wading through it all.
    Here is the best one that I have found. Awesome post.
    Also, talk to the guys at Speedway Motors. Their straight axle kit is as complete as they come. Comes as transverse leaf or parallel leaf, droped or straight.
    Good Luck
    http://www.jalopyjournal.com/forum/showthread.php?t=225171&highlight=puddin
  23. Kail
    Kail
    from Austin, TX
    Luke and I were talking did you ever get the old pictures of it?
  24. gassercrazy41
    gassercrazy41
  25. gripelec
    gripelec
    hey dude, its graham, have a lead on pics. ill stop by this week, car looks KILLER MAAAAN
  26. best2923
    best2923
    from north Id
    keep it like it is just clean it up. It's a part of history.
  27. kbuhagiar
    kbuhagiar
  28. kbuhagiar
    kbuhagiar
