Projects making a hotrod dash, lets see yours.
Discussion in 'Traditional Hot Rods' started by sloppy jalopies, May 28, 2020.
  1. sloppy jalopies
    sloppy jalopies
    I took the '28 closed car dashrail in trade... would work with either model A or other make dashrails...
    the radiused insert halves were '46-'47 truck hood side opening reveals … used about 8" from each side... ****ed them together...
    $47.00 aluminum gauge cluster = hot rod dash...
    ship luck, the vacuum packing stayed sealed on the polished surface... protection from me.
    View attachment 4701580 View attachment 4701581 View attachment 4701582 View attachment 4701586 DSCN6458.JPG DSCN6461.JPG
    with lower conduit added.
  2. Budget36
    Budget36
    I always enjoy your ingenuity!
    I did similar to a '42 PU Ford I had, but not as nice as yours.
    loudbang and sloppy jalopies like this.
  3. Jalopy Joker
    Jalopy Joker
    dare to be different
  4. 41rodderz
    41rodderz
    from Oregon
    I love a good tech thread . Thanks
    sloppy jalopies likes this.
  5. sloppy jalopies
    sloppy jalopies
    thanks boys,
    An atta boy now and then... Rocks the Casbar !...
    I have a '41 to '47 truck dash...they must be cut out of the cowl...
    will graft the top half of a '35 car to it...
    I like them as the cluster and glove box holes are the same size...
    once you set up the stock cluster with a glovebox door insert you could use multiple layouts of "gauge, speedo, gauge" combos on other glovebox doors, as well as the std and dlx '40 units...
    swap them when wanted...
    '40 truck has a raised [embossed] rectangle with '40 car chrome style script in the center...
    '41 to '47 have a smooth center having an inch thick rectangular, chromed, ford script, die-cast block screwed on...
  6. sloppy jalopies
    sloppy jalopies
  7. GordonC
    GordonC
    Here is the one I did for my 31 A.
    getow, Okie Pete, loudbang and 5 others like this.
  8. sloppy jalopies
    sloppy jalopies
  9. sloppy jalopies
    sloppy jalopies
    uncleandy 65 and loudbang like this.
  10. CadMad
    CadMad
    A4782E7F-7844-459F-BD52-4B05B2EEF6D5.jpeg F608CDA2-2026-4154-81C8-BED0D933C174.jpeg D4E58051-6A35-4CA4-B404-7859E6B5C2E2.jpeg 254E1588-2A44-459A-96CE-3F6372C24EE6.jpeg 8FA57B8E-481D-405F-B51D-57B97F0F4F4F.jpeg E3B3778B-8CE2-489C-BD15-360135CE9886.jpeg
    Okie Pete, Paul, charleyw and 4 others like this.
  11. redoxide
    redoxide
    47 shortened and grafted to a section of 31 dash rail , glove box lid has been tweeked to fit better than it does in the pics copper trim is just a filler piece with a couple of studs soldered to the back side and secured to the dash.. plan is to fit the chrome strip on top of this piece .. maybee
  12. jaracer
    jaracer
    Mine's pretty simple. Still have to figure out how to finish the switch panel. IMG_1439.JPG
  13. olds vroom
    olds vroom
    IMG_0401.JPG heres my dash I used actual WWII aircraft gauge bezels to keep with the theme of the car.
  14. dsiddons
    dsiddons
    from Indiana
    Man that Altimeter and VSI looks exactly like one I had in my Tri Pacer. I may to a old horizontal DG. Now a days I can set it with my phone and go. IMG_9402.JPG
  15. dsiddons
    dsiddons
    from Indiana
    You going to make the altimeter and VSI work? Pitot on the cowl?
  16. sloppy jalopies
    sloppy jalopies
    IMO... I would cap the ends with a swoopy panel on each end deep enough so you can't see the sides of the gauges and wires... I would cut, sand, file [widow's peaks] on the bottom edge of the panel, between the gauges... maybe some fender welting between it and the dash to smooth the transition between the 2...
    easy to tell you what to do... not so easy to do myself.
  17. 40FORDPU
    40FORDPU
    My '39 Deluxe coupe, I continued on where the previous owner had started..filling some holes adding an additional chrome strip on the bottom, then painted and added SW gauges.
  18. JOHN H EDGE
    JOHN H EDGE
  19. hemihotrod66
    hemihotrod66
    Had to modify the 34 Dash to get the gauges to look like they belonged there.. Build picture 9.JPG
  20. X-cpe
    X-cpe
    In progress coupster dash.
  21. sloppy jalopies
    sloppy jalopies
    yea !
    more dash and some body pix please x cpe… very nice work !
  22. rocsas
    rocsas
    from colorado
    redoxide, Okie Pete, 30tudor and 2 others like this.
  23. rustydusty
    rustydusty
    Some gorgeous dashes here! Mine is just a piece of mahogany from an antique church pew... 20200310_151322.jpg
    Okie Pete, Blade58 and loudbang like this.
  24. sloppy jalopies
    sloppy jalopies
    If we ever have safe swap-meets around here I will be ready to plant my flag... and my lawnchair..
    1/2" conduit... [2] 5' legs and [1] 4'6" back leg... [10] 5"ish pegs... foot pads... chain "stops"...
    holds [5] dashes that fit in Model As...
    the legs are 5' because that will fit inside my closed trunk...
    you could bend up [5] various length x 6"deep and 3" tall L bends to use as shelves... wire ties fit where you would slide them over the pegs so they don't tip...
  25. X-cpe
    X-cpe
    Thanks Sloppy Jalopies. I enjoy watching you make viable bodies by s***ching left overs and junk together. One of the revelations of adulthood was that you could buy material to fit a project rather than fit the project to the material at hand. Even now, I am still more likely to see what I have and figure out how to make it work than go buy exactly what I need. Here's a couple of pictures of the body. It was a coupe with no firewall, deck lid, inner fender panels or sub-rails. Then I cut the roof off before I learned about bracing. You should try squaring something up before you discover that someone has patch paneled the right quarter 5/8" shorter than the left.
  26. Blade58
    Blade58
    from apopka ,Fl
  27. butch
    butch
    from Michigan
    Filled model A
  28. two couped up
    two couped up
    from pa.
    343w and loudbang like this.
  29. sloppy jalopies
    sloppy jalopies
    Hot Rod Lincoln ! you are gonna drive your daddy to drinkin'.
    Just picked up a '63-ish pick up dash insert... big hole, gauges around the speedometer... clock and tack hole... ribbed face... but 3 dimentional…? DSCN6516.JPG DSCN6517.JPG
