Technical Lincoln 317 Y Block Questions
Discussion in 'The Hokey Ass Message Board' started by rodthrutheblock, May 30, 2020.
  1. rodthrutheblock
    rodthrutheblock
    Hello again from the UK...
    I have a 1952 Lincoln 317 Y Block (EAD engine) The valve stem seals I have taken out seem to be in two parts, one really small one that fits below the retainer (collet) with a larger seal also in the stem. They are obviously old and hard and broken.
    The Best Gasket set I have has these larger plastic/rubber ‘umbrella’ seals but not the smaller piece. Do these replace the two pieces originally fitted?
    Any help appreciated.
    Deuces likes this.
  2. jaracer
    jaracer
    Try contacting John Mummert, he has a lot of experience with the Y block family. www.ford-y-block.com
    rodthrutheblock likes this.
  3. jimmy six
    jimmy six
    Ted Eaton of Eaton Balancing in Leona Texas will also know this answer.
    If the valve has 2 registers on it, the top would be for a keeper and the second for a “square” o-ring and the umbrella over the guide in my experiences with other engines not the 317..
  4. rodthrutheblock
    rodthrutheblock
    That’s great help. I’ll try them both, thank you.
