Nomads!!!
Discussion in 'The Hokey Ass Message Board' started by Slimegreeeeeen, Nov 21, 2007.
  1. uncleandy 65
    uncleandy 65
  2. uncleandy 65
    uncleandy 65
  3. blowby
    blowby
    from Nicasio Ca
    Just stopped by for a dose of extreme jealousy.
    The ultimate wagons..
    raven, 6inarow and arkiehotrods like this.
  4. 1934coupe
    1934coupe
    Yeoman not Nomad. Cool wagon nonetheless.
    Pat
    toml24 likes this.
  5. rumblegutz
    rumblegutz
    1958 Nomad-crop.jpg I'm with 1934coupe, o_O 1958 Nomad, well yeah but NO. In name only.
    enloe likes this.
  6. uncleandy 65
    uncleandy 65
    Can't be any worse than that bucket t that somebody posted
  7. 1934coupe
    1934coupe
    Not worse by any means also ALL Nomads where 2dr. The Yeoman as you can see is a 4dr. I don't believe there is a 2dr. Yeoman.
    Pat
  8. uncleandy 65
    uncleandy 65
    I deleted it so you guys will be able to sleep tonight. Bill
  9. 1934coupe
    1934coupe
    Uncle I liked it , just pointing out the difference.
    Pat
  10. uncleandy 65
    uncleandy 65
    Ya I knew the difference, I liked it too. I would give it garage space.
  11. Dick Stevens
    Dick Stevens
    Actually they built a 58 Nomad, it was a Belair Nomad just not the 2 door hardtop that we usually think of when we talk Nomads!
    arkiehotrods likes this.
  12. rumblegutz
    rumblegutz
    If you look at the enlargement of the quarter panel I posted you should be able to read the Nomad emblem. Chevy did build a 4 door Nomad in '58 and I think '59 too. I think that is the last use of the name.
    I think there is a thread for long roofs. Your photo would be quite welcome there.
    I will sleep better Thanks.
    quick85 likes this.
  13. Moriarity
    Moriarity
    SUPER MODERATOR
    the last nomad wagon was in 1961, again a 4 door but it was called a nomad, there were no impala wagons in 61 so the nomad was the top trim level wagon. In 62 they went with an impala wagon....
  14. 32fenderless
    32fenderless
    My boss built this car about 15-17 years ago
  15. arkiehotrods
    arkiehotrods
    Chevrolet built 16,590 2 dr Yeoman wagons in 1958.
    quick85, 31hotrodguy, alfin32 and 5 others like this.
  16. arkiehotrods
    arkiehotrods
    • 1958 For the 1958 model year, Chevrolet moved the Nomad name to its top-line four-door Bel Air-based station wagon,[4] right above the new mid-priced Biscayne based Brookwood. This was the only four-door Bel Air-based Nomad station wagon. Like the rest of Chevrolet's 1958 full-size car line up, the Nomad featured Chevrolet's new "Safety-Girder" cruciform frame. Similar in layout to the frame adapted for the 1957 Cadillac, it featured box-section side rails and a boxed front cross member that bowed under the engine, these "x-frames" were used on other 1958 to 1964 Chevys, as well as Cadillac. The rear was tied together by a channel-section cross member.[5]
    • 1959 In 1959, the Nomad was transferred from the Bel Air to the expanded Impala model range, which had been the top-line Chevrolet two-door hardtop and convertible the previous year; Impala now became a separate model that included four-door cars. Nomad, still at the top was a six-p***enger car. The other 1959 Chevrolet station wagons were the new Kingswood four-door, nine-p***enger, the new Parkwood four-door six-p***enger, the new Brookwood two-door six p***engers, and Brookwood four-door six P***enger. With the Delray gone, the Biscayne-based Brookwood was now priced lowest. The Brookwood two-door marked the short-lived return of the two-door wagon and was the basis for the new-for-1959 El Camino. The El Camino carried mid-level Parkwood (Bel Air) exterior trim, with Brookwood (Biscayne) interior.
    • 1960 For 1960, the Impala-based Nomad four-door was revised with more conventional styling. The Kingswood and the two-door Brookwood were dropped at the end of the year along with the El Camino.
    • 1961 In 1961, all full-size Chevrolets were restyled on the existing GM B platform. The new body styling was more trim and boxy than the 1958-60 models. Chevrolet continued to use the Nomad name until the end of the 1961 model year when all Chevrolet station wagons adopted the names of the regular sedan models for 1962. The Nomad had body-on-frame construction, using the "X" frame to the end.
  17. arkiehotrods
    arkiehotrods
  18. primed34
    primed34
    About 1970 I heard there was a Nomad in a local junkyard. Made a speed run to see it. Turned out to be '58 Nomad. From then on if I heard about a Nomad for sale I asked what year it was.
    Bowtie Coupe and arkiehotrods like this.
  19. 1934coupe
    1934coupe
    Thanks Arkie, that's what's called "fact checking" I didn't know that about post 5,6,7 Nomads.
    Pat
    Bowtie Coupe likes this.
  20. rustydusty
    rustydusty
    Seriously? You didn't see the "Nomads" plaque? It's humor, lighten up!
    Besides, it's a T roadster...
    quick85, 6inarow and arkiehotrods like this.
  21. uncleandy 65
    uncleandy 65
  22. uncleandy 65
    uncleandy 65
  23. Shon Wittenbarger
    Shon Wittenbarger
    from Georgia
    Anyone know what happen or know where the Yellow 56 Nomad from the 1973 movie Outrage. It was also on the 1975 cover of 1001 Custom & Rod Ideas.
  24. uncleandy 65
    uncleandy 65
  25. Shon Wittenbarger
    Shon Wittenbarger
    from Georgia
    Yes, that's it. It has not been seen in years. Does anyone know what happen to it
  26. uncleandy 65
    uncleandy 65
  27. firemangordy
    firemangordy
    The last time I saw it was at a show at Orange County International Raceway and it was painted red, white and blue in a flag theme. I believe they called it the "Patriot".
  28. uncleandy 65
    uncleandy 65
  29. uncleandy 65
    uncleandy 65
  30. uncleandy 65
    uncleandy 65
