Projects '23 Ford Roadster build aka The Incredible Hulk
Discussion in 'The Hokey Ass Message Board' started by Paul, Feb 22, 2018.
  1. Malcolm
    Malcolm
    from Nebraska
    Another cool Paul project -- Thanks for taking the time to share this!
  2. Paul
    Paul
    Editor
    I think maybe in a way you already are.
  3. Paul
    Paul
    Editor
    made some lower shock mounts for the rear.
    cut and reshaped a bit of rectangular tube to fit on the back of the ends of some after market tube shock conversion mounts,
    cut the ends and pie cut them,
    made a cardboard pattern to guestimate the bend needed
    welded the pie cut
    ground them smooth-ish,
    fit them,
    and tacked them in place.
    the rear is now ready to come out to get all brackets welded.
    IMG_20200530_175942.jpg IMG_20200604_125948.jpg IMG_20200604_132831.jpg IMG_20200604_135956.jpg IMG_20200604_152420.jpg IMG_20200604_154220.jpg
  4. Paul
    Paul
    Editor
    this is just a filler post,
    like, how many times do we need to see mundane **** like this anyway?..
    I didn't feel like pulling the rear today
    so I drilled some holes.
    did a quick layout on the front backing plates
    followed by center punch,
    1/8" pilot,
    5/16" final hole size,
    used a 1/2" bit to clean up the burs inside,
    regular counter sink chamfer on the outside,
    minor clean up and temporary fit to check the look
    p***enger side and driver side
    IMG_20200605_131009.jpg IMG_20200605_132709.jpg IMG_20200605_140636.jpg IMG_20200605_141701.jpg IMG_20200605_143243.jpg IMG_20200605_143836.jpg IMG_20200605_152422.jpg IMG_20200605_160533.jpg
  5. Paul
    Paul
    Editor
    that will do but,
    I may use scoops instead,
    on another set of 'plates
  6. dumprat
    dumprat
    from b.c.
    I like the scoops, I have a pair on my truck.
    Are you planning on chrome for the front axle?
    loudbang and Paul like this.
  7. Paul
    Paul
    Editor
    I like the scoops too.
    If I was a rich man I would chrome everything.
    But alas...
    Paint will have to do for now.
    jebbesen, loudbang, brEad and 3 others like this.
  8. loudbang
    Those look like they belong right there. Really look good. :)
    Stogy, OFT and Paul like this.
  9. Paul
    Paul
    Editor
    scoops it is then
  10. gonzo
    gonzo
  11. vtwhead
    vtwhead
    Nice job on the brakes. Looks perfect. Those scoops available in the market any more?
    Paul and loudbang like this.
  12. asawman
    asawman
    Excellent job. None out place. Looks like it was done on a mill.
    Sent from my SM-N975U using The H.A.M.B. mobile app
  13. Paul
    Paul
    Editor
    I don't know, I bought them here on the HAMB from a member a few years ago.
  14. Paul
    Paul
    Editor
  15. OFT
    OFT
    ^^^^^^thanks for the link Paul!!!
    ratrodrodder, loudbang and Paul like this.
  16. vtwhead
    vtwhead
  17. jebbesen
    jebbesen
    from Winona, MN
    The car is really looking great! Are the radius rod joints the early Ford 11/16 ones? What's the distance between the top and bottom radius arm joints at the front axle brackets?
  18. Paul
    Paul
    Editor
    yes, 11/16"-18 R&L tube steel tie rods, 6-1/2" center-center
  19. Paul
    Paul
    Editor
    side tracked again,
    spent way too much time on non-critical path design aspect..
    made a simple jig for the bead roller
    IMG_20200608_124359.jpg IMG_20200608_124811.jpg IMG_20200608_125217.jpg IMG_20200608_202135.jpg IMG_20200608_202129.jpg
  20. Paul
    Paul
    Editor
    layout path for bead..
    simple line layout and hole drilled in sheet metal,
    roll bead until hole in sheet line up with hole in jig,
    drop 1/4" bolt through holes,
    roll radius around to line up with straight line,
    pull bolt and roll straight to edge,
    cut between the beads and around inside radius,
    fold the inside cuts and weld an arch to close off the radius
    times two
    00000PORTRAIT_00000_BURST20200608135301633.jpg 00000PORTRAIT_00000_BURST20200608135357811.jpg 00000PORTRAIT_00000_BURST20200608135601445.jpg 00000PORTRAIT_00000_BURST20200608135732939.jpg 00000PORTRAIT_00000_BURST20200608135832127.jpg 00000PORTRAIT_00000_BURST20200608140218790.jpg 00000PORTRAIT_00000_BURST20200608140952914.jpg 00000PORTRAIT_00000_BURST20200608142538640.jpg View attachment 4716215 IMG_20200608_160116.jpg IMG_20200608_173037.jpg IMG_20200608_173055.jpg
    RustyBullet, Jet96, treb11 and 16 others like this.
  21. Paul
    Paul
    Editor
    notch the turtle deck to clear upper shock mount
    tack weld temporary tabs to frame to support turtle deck
    check notch fit
    IMG_20200609_144334.jpg IMG_20200609_144524.jpg IMG_20200609_144531.jpg IMG_20200609_144951.jpg
  22. Paul
    Paul
    Editor
    layout for patch
  23. Paul
    Paul
    Editor
    cut turtle deck to take the patch
    trim patch to fit
    clamp the patch in place
    and weld it up
    IMG_20200609_160309.jpg IMG_20200609_160418.jpg IMG_20200610_151914.jpg IMG_20200610_153052.jpg IMG_20200610_160432.jpg IMG_20200610_161126.jpg
  24. Travis latour
    Travis latour
    from Putnam CT
    Detail on that notch is great!
    loudbang, Stogy and Paul like this.
  25. Paul
    Paul
    Editor
    grind down the welds
    and check fit
    Kreepea_1, gonzo, patmanta and 10 others like this.
  26. Paul
    Paul
    Editor
    I raised the turtle deck 1-1/4"
    to expose the same frame reveal as the body will have
    mostly to try to gain some room for the gas tank
    but still trying to keep it low as possible for visual aesthetics
    Just Gary, Old-Soul, Tim and 9 others like this.
  27. bchctybob
    bchctybob
    Hol-e-smoke Paul, that was a clever way to do an outstanding detail! Very cool.
  28. Stogy
    Stogy
    Neato, along with all the other Neato...You have a sleeve overflowing with Ideas @Paul...a joy to witness...Thank You
  29. warbird1
    warbird1
    Fantastic work!
  30. jebbesen
    jebbesen
    from Winona, MN
    Thanks for the tie rod end info! That beadwork in the last few posts is fantastic! It's the details like that which really make the car.
    ratrodrodder, loudbang, Paul and 2 others like this.
