Technical New Engine lacks power SBC in the Studebaker-RESOLVED
Discussion in 'The Hokey Ass Message Board' started by vtx1800, May 20, 2020.
  1. gimpyshotrods
    gimpyshotrods
    Kinda looks like a stylized Thermoquad.
    It appears to have Siamese secondaries, effectively making it a 3-barrel.
  2. vtx1800
    vtx1800
    @gimpyshotrods I measured both on the push rod side and the valve side, I was supposed to have .450 on the valve side and had .3** ?? now....is that a legitimate measurement when the lifter isn't pumped up? Bet you are glad it is me having the problem and not you:)
  3. vtx1800
    vtx1800
    @1946caddy I bought both new lifters and cam. Five year warranty. I am using the org valve springs, the machine shop said the springs would be OK for a mild cam so I didn't replace them. I did use the ZZDP that was furnished with the kit as well as cam lube. I really didn't want to have this problem.
  4. sdluck
    sdluck
    What spring were in it? How stiff?
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I never liked measuring lift with rockers in place with hydraulic lifters. Pull rocker and measure at tip of push rod instead.
  6. sdluck
    sdluck
    Can you fish the lifter out? How did it run when you broke in the cam?
  7. sunbeam
    sunbeam
    I had a customer bring me a Ford PU with a 300 6cyl it just had the head done the truck idled fine put not get any rpm the valve springs were giving up. I replaced the springs and the motor ran fine. He ask the shop that did the head and they had checked them against each other and they were all the came height. that was all that was done. If you adjust the rocker until it starts to open the valve and then check lift it should be ok..
  8. gimpyshotrods
    gimpyshotrods
    It could be that the lifters are not pumped up. Do you have an oil pump primer, or can you run it for a minute, and check again. That is way too little lift.
    I have my own, extra special problem. Leaving my finger tip hanging over the edge of the intake of a 6-71 did bad things to it, and it may never be the same again.
  9. carbking
    carbking
    Ray - no comment on the Demon other than it resembles a Carter TQ, which is one of my favorite 4-barrel carbs, if one has enough engine to support it.
    Studebaker used Carter WCFB's on the 259 engine, and while slightly technologically inferior to the Carter AFB or the Holley 4150, or the newer spread-bore carbs; they are completely bullet-proof! Get an original Studebaker version, and the calibration is correct, unless the engine has been significantly modified. Even then, while calibration parts are not locally available, they are readily available mail order.
    Studebaker WCFB's are not as common as those for Chevrolet, but they are not rare (like the Carter AFB's used on the Studebaker 289's).
    The Carter AFB's used by Studebaker are quite rare and very expensive, but relatively easy to re-purpose a Carter AFB designed for a Pontiac to Studebaker calibrations (have done several, it can be done) if one is not into "numbers-matching".
    The Holleys come with a totally different calibration than what the Studebaker wants. I am certain some of the Holley guru's here can re-purpose the Holley, but I am lazy. I like to start with something requiring less modification. I would personally look for a Studebaker WCFB.
    Gimpy - interesting the Demon has Holley-style casting numbers.
    Jon.
    loudbang, Hnstray and gimpyshotrods like this.
  10. big duece
    big duece
    from kansas
    Are any of the press in rocker arm studs being pulled out?
    '49 Ford Coupe and loudbang like this.
  11. gimpyshotrods
    gimpyshotrods
    Not that odd. The Demon brand is owned by Sentinel Partners.
    They own: ****** Headers, Weiand, Nitrous Oxide Systems, Flowtech Exhaust, Demon Carburetion, Earl's Performance Plumbing, Diablosport, MSD, Mr. Gasket, Accel, Superchips, Edge, Racepak, Mallory, Hays, Quicktime, Lakewood, and Holley.
    "Thank you for shopping at UniCorp! 'There's Nowhere Else To Go!' "
  12. nunattax
    nunattax
    thats a street demon carb
  13. sunbeam
    sunbeam
    The first post said he broke the cam in and drove the car
  14. sdluck
    sdluck
    Sorry I missed that.
  15. vtx1800
    vtx1800
    Partial update, my neighbor/friend came up, we pulled the rocker off of both valves on number two and found that we have full lift (.300 ) off of the pushrod. I guess I will now check all of the rest. Makes me wonder if it's springs?? Note we checked for TDC compared to the damper and it is OK. Note I used the original crank, timing cover and damper as well as a cover that matches the damper TDC (so the outside ring hasn't moved in relation to the center)
    '49 Ford Coupe and brigrat like this.
  16. brigrat
    brigrat
    from Wa.St.
    " I took a plastic 55-gallon drum full of take-off Holleys to the swap meet last year, and sold them all, because the customers did not want them back. "
    Around my area you can take a 55 gal. barrel of Holley's & a 55 gal. barrel of Eddy's to a swap meet and the Holley's will sell out every time over the Eddy's!
  17. '49 Ford Coupe
    '49 Ford Coupe
    Have you checked for any rats nest in your intake manifold? (My apologies..trying to be funny)
  18. partssaloon
    partssaloon
    Damn, that hurt just reading it!
    47ragtop likes this.
  19. vtx1800
    vtx1800
    @gimpyshotrods I think I will take more own problems over yours:( I can't imagine:(
    I ran all of the push rods (after taking off the rockers) see picture for my set up. The cam is spec'd at .300" lift on the cam. most lobes were short anywhere from about .018 to .006 with a couple right on. I called the manufacturer and the tech guy told me to drain the oil and inspect for metal as well as cutting the filter to look for metal. IMG_2985.JPG
  20. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Dial indicator isn't very parallel to push rod.
  21. the manufacturer and the tech guy told me to drain the oil and inspect for metal as well as cutting the filter to look for metal.
    You’ve
    got to get a good measure and repeated consistency to make a definitive call on short lobes. 0.018 isn’t a whole bunch and easily in the trueness of your indicators set up.
    And that 0.018 probably isn’t going to stop RPM gain past 2000.
    Not to say that the cam isn’t going flat.
  22. blowby
    blowby
    from Nicasio Ca
    I see the problem, there's no oil in it! :)
    While it's apart, split the overlap and see where the piston is.
  23. Johnny Gee
    Johnny Gee
    from Downey, Ca
    What's with the grade 8 bolt's that are welded?
    Fitty Toomuch likes this.
  24. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Intake looks funny as well. Has it been hogged out all the way to the outside so bolts will work?
  25. Kevin Ardinger
    Kevin Ardinger
    There’s a whole lot more to the cam than lift. Since you have the dial indicator on it might as well put a degree wheel on it and see if the cam events are correct.
    Black_Sheep likes this.
  26. vtx1800
    vtx1800
    @Johnny Gee I modified an early manifold to fit later heads. Holley part Number 90748 is a wedge so the center manifold bolts will tighten properly on the 14096217 head.
    Those aren't grade 8, just grade five, they hold the "shelf" for the magnetic dial indicator base. A farmer fix:)
    I followed the tech's suggestion, dumped the oil and drained the filter and cut it open. What PITA. I don't think there is a problem with the cam. The filter media looked the same inside and out.
    327-365hp and Johnny Gee like this.
  27. Johnny Gee
    Johnny Gee
    from Downey, Ca
    They look gold in the other photo.
  28. Driver50x
    Driver50x
    Did you try pulling the plug wires off one at a time to make sure all 8 cylinders are firing?
  29. Mikeszcz
    Mikeszcz
    from Winona, Mn
    Borrow a valve spring pressure tester. My first bet would be weak springs. If you can't find one, give me an address and I'll let you use mine for shipping cost.
    And, how did you set your valve lash?
    big duece likes this.
  30. 57 Fargo
    57 Fargo
    Doesn’t matter the color, only three marks on the head
    Dick Stevens and Blues4U like this.
