Has anybody out there had trouble with these shocks? Things like losing the nitrogen charge, leaking dampening oil, etc. I have a friend that has a puddle of oil where they sat on the shelf, and were brand new! If there are better shocks out there, like Carrera, QA1, AFCO, etc., that have a longer life, please do tell. The current application does not require "pretty", but it does require good function and "drive-ability."
When my Aldens leaked, I sent them back with copy of purchase receipt. Fixed for free under lifetime warranty. Think I did this three times over 20 years, 100k miles. Phil
Ridetech has a 1,000,001 mile warranty on their shocks. And I’ve heard some very positive things about them. No first hand experience yet. FYI Sent from my iPhone using H.A.M.B.
Ride tech changes their shock supplier pretty regularly. I believe FOX is the supplier of the month for them at the moment. Aldan shocks are entry level at best. QA1, Penske, JRi, good shocks, more money.
I’ve had good luck with Alden coil overs, only had one leak (out of about six pairs) and they repaired it, no problem. Sent from my iPad using The H.A.M.B. mobile app
Have you researched Koni or Bilstein? They have "traditional" style tube shocks that are every bit as good as their fancy pants stuff. And they will set them up for you, too, should you want to alter the feel. All you need to know is the extended and compressed lengths and mounting bolt hole sizes.
Do you have a local performance shock rebuilder? The dampers on my DD are rebuilt junkyard stockers with new seals and custom valving installed by a tiny local outfit called GT Shocks. If Cape Town can have one such, chances are there are more wherever you are.
I was fortunate enough to get the chance to work at JRI shocks for a day ***embling shocks. all hand made by Americans. shop is spotless and organized. it was a unique opportunity for me. I ***embled shocks that were destined for Harley Davidson side cars.
You get what you pay for. I stopped buying aldan shock a long time ago. Qa1 is my go to shock now. Look at the cl***ifieds for a set I'm selling.
I had Aldan coil overs on the front of my Deuce roadster. The springs were what were called "progressive springs" meaning the bottom 1/3 were wound tighter than the top 2/3. The ride got progressively worse and after about a year you couldn't get a business card between the bottom 1/3 of the coils. To me, when you have a spring that the coils are touching, it's not a spring, but a 3" spacer. This was after only about 2000 miles. The ride was also harsh, but I chalked it up to just being a hot rod. While at the Nationals in Louisville, I stopped by the PRO shocks booth and talked to the PRO people. They suggested that I send the Aldans to them in the off season and they would evaluate them for free. After they evaluated the shocks, they told me even though both shock's and spring's were correctly rated, the shock's were "blown" and needed to be replaced and the springs were useless. I purchased and installed a set of PRO coil over shocks and could not believe the difference in the ride. In fact, the first trip I took with my wife, she even mentioned how different and smooth the car rode. I have had the Pro coil overs on the car now for over 50K miles since, with no issues.
I just sent a 23 year old pair back to them and they replaced all seals, filled with new oil and recharged for me for the cost of shipping and treated it as under warranty. I say that is some damn good service.
I put a pair of Aldan coil overs on the back of my A pickup just a couple of years ago and have had no issues with leaks, yet. The ride quality is quite good, at least compared to the worn out shocks that were on it when I acquired it. Definitely NOT entry level, good quality, gas charged, adjustable rebound shocks. Priced accordingly.
Blew out 2 sets of monroes on the back of my 56 pickup, still have the 11 year old set of monroes on the front but they are the Yellow HD shocks, rears were the middle line, Upgraded to single adjustable QA1 and best thing I ever did, when the front shocks go I will put the same ones up front. On my moms 56 ford we pulled the monroes off and put the belltech drop shocks on, great bang for the buck shock for sure so far. They are good for lowered vehicles for sure. My 53 belair has the cheap blue monroes, they ride ok, just can control the rear end enough on hard fast bumps. Billsteins or KYB are not bad either, just problems most find is the gas is too hard and adds spring rate that kills ride. VOTE QA1 here is my top choice.
I have them on the front of my truck and they are leaving. I sent them back under the warranty, and I got over a $100 bill to rebuild them. Still not happy with them. I will match the QA1's I have in the back. Tony
Does anyone have a 15" Aldan coil over, a single, pair, or a set 13.5 - 15" Even one that need rebuilding. I have a 13.5 & a 15" now. I need a mate to the one I have.
I have QA1 on the front of my 40 and Ride Tech on the rear. I have had to return both for repair, Ride Tech repairs free and quickly, QA1 goes to an authorized rebuilder (independent) and cost $100 and took awhile.
