Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. stillrunners
    stillrunners
    from dallas
    Sorry about that - posting from my phone...
    LAROKE likes this.
  2. LAROKE
    LAROKE
    From the BillyBob Shop log
    June 4th 2020 Filler and block sanding the back bottom of the cab. Three applications of mud and sanding with 36 and 40 grit. I wear a dust mask and goggles but as little as a half hour of these ops and I'm sneezin' and drippin' for a few hours, one of the reasons I think "the new normal" of wearing masks in public is mostly symbolic at best.
    Not enuf defects to mix up another batch so I applied some Bondo brand spot putty I had layin' around and sanded everything again with 80 grit.
    Washed the back bottom with Dawn soap and water, masked and roughed up the door jambs and cab corner bottoms with a Scotchbrite pad and PRE Paint prepped the same, then spray bombed them.
    We're ready now for priming the bare metal patches and rolling the first guide coats. Background music was The Moody Blues Time Traveler box set.
  3. 57 HEAP
    57 HEAP
    I thought I would remove the rubber hose from carb to distributer with a piece of 3/16 brake line.
    So this...….
    becomes this.
  4. topher5150
    topher5150
    My new harmonic balancer showed up. Went through two tools to get that ****** on and the only progress I made with it was using a rubber mallet
    Sent from my moto z4 using The H.A.M.B. mobile app
    chryslerfan55, Lil32 and LAROKE like this.
  5. guthriesmith
    guthriesmith
    Dropped my Fairlane off at a buddies muffler shop for some new mufflers and a tailpipe after trying to drag the exhaust off recently. Planning on mufflers that will gain me some ground clearance. :D Also, cleaned up a couple exhaust manifolds that I will paint and then put on to replace the two broken ones on it now. Yea...it was sounding bad. :oops:
    ABFC4B1C-594F-4959-A58B-A57A2835B72F.jpeg 20318322-DE4F-46F3-82C0-A677263D40CD.jpeg
    chryslerfan55, Lil32, RICH B and 2 others like this.
  6. I went to bed.... get it? Bed? Gonna spend some time with a DA sander today :rolleyes: got the stuff to put a pcv in my 57 also. I'll do that later today. 20200604_110226.jpg
  7. Blues4U
    Blues4U
    from So Cal
    Painting the firewall on the A pickup. I had already done all the sanding and primering, and layed down a coat of shiney black from a Rustoleum rattle can, but ended up with a couple of little runs. Probably nobody would've noticed them, but I knew they were there and threy bugged me, so I sanded them down and tried to hit them with some more of the shiney stuff, and all it did was krinkle up. Damn! I even waited the recommended 48 hours. So yesterday I sanded it all back down again and resprayed it with some primer. Going to sand that down with some 800 today and try the shiney black stuff again, and hope for no runs this time. 20200604_090104_HDR.jpg
  8. LAROKE
    LAROKE
    You have to search far and wide to find worse spray bomb nozzles than Rustoleum. Why they can't have reliable nozzles like Duplicolor I can't fathom.
  9. stillrunners
    stillrunners
    from dallas
    yep...we got the news about it.......
  10. Still in bed :rolleyes: Might spray some baby **** green today, might wait til tmrw ;) did switch my valve covers so i could stick some crankcase ventilation in the beast :D 20200604_160107.jpg 20200604_160221.jpg
  11. saltflats
    saltflats
    from Missouri
    Got started on a pitman arm for a power steering project for a 62 Grumman step van.
  12. Give me some of that pea soup green please :D Nason ful-cryl. 20200604_180437.jpg 20200604_180445.jpg 20200604_180506.jpg
  13. RICH B
    RICH B
    Ran a few wires down thru the drivers side rocker on my '47. Got a start on adding some firewall insulation; but had to use contact cement; seems the 40 some year old 3M aircraft stuff's "peel & stick" was not very sticky anymore.
  14. HOTRODPRIMER
    HOTRODPRIMER
    Cleaned up the Ranch Wagon & got the air working better ( belt was slipping)
    I will be driving the wagon to Greenville tomorrow to be a pallbearer for a fellow Try-City Rod & Custom club member, Andy's wife pleaded with the funeral home to have a procession to the cemetery and they will only allow the pallbearers to follow the he****, It's a shame this Dammed pandemic has affected people even in death.
    I have room in the back to haul the wreath from the club.HRP
  15. banditomerc
    banditomerc
    Starring at my new project....A 1940 MERC!!!!
  16. jimmy six
    jimmy six
    Replaced the auto trans fill tube after I found Larry’s T-Bird had a replacement with dip stick. Mine had been leaking for 7 years and everything I tried failed. Leak is gone. Never could figure it out. A soft copper gasket would have been my last resort before I found the repo.
    chryslerfan55 and RICH B like this.
  17. stillrunners
    stillrunners
    from dallas
    Score ! Found this in some of the stuff I got at the sale.....going to be using it ! 20200605_194200.jpg
    chryslerfan55, RICH B, Lil32 and 2 others like this.
  18. jimmy six
    jimmy six
    Opened a large envelope and found this.... A very pleasant surprise. FBA1EF01-6E20-42F8-B0ED-6F0C9660894B.jpeg
  19. Blues4U
    Blues4U
    from So Cal
    Congrats Jimmy!
    lothiandon1940 likes this.
  20. Blues4U
    Blues4U
    from So Cal
    I got the firewall painted up this morning. Yesterday after work I sanded the primer I had sprayed the day before, but there was a front blowing in and too much wind to try to spray some paint. This morning it was too cold and too wet to paint it, but around 10:00 the temp was up enough and humidity down to <80% so I went ahead and sprayed it and it came out nice. Check 1 more thing off the to-do list. Now I need some chrome hardware to mount the ignition coil. Tomorrows project. That and clean things up again that have gotten dusty from all the sanding. And take it out for a ride. 20200605_181059.jpg
    chryslerfan55, LAROKE, blowby and 6 others like this.
  21. The37Kid
    The37Kid
    Moved some stuff around in the ba*****t and found a quart of paint remover. Brush and the old can with the opened side was right next to it. Hupmobile splash aprons are in bare steel first time since 1911, and the rear well on the Roadster left quarter is also bare. Always nice to see old red Ford primer on A parts. Bob :)
  22. Mike Miller
    Mike Miller
    Cleaned up the mess from doing the engine and set the frame up level on the hoist to start installing the running gear and rebuilding the front and rear suspension for the 56 wagon. I wanted a stay busy project until things open up again and this one sure fit the bill. Things are actually coming together good for what I have on hand to work with, didn't know I had enough stuff stashed to build a whole car out of.
    chryslerfan55, LAROKE and Lil32 like this.
  23. Did some stuff in the shop for my son, then took a look at the ratchet I blew apart in the driveway on Thursday while it was being over-taxed. I picked up the pieces I could find, and was a bit sad. Got the ratchet in a set from my parents when I was 16. It was a Christmas present. Well, I was able to clean it, and re-***emble and it works good now. Made me feel better, than the other day. Parents are gone, that was 46 years I'd had it.
  24. T. Turtle
    T. Turtle
    Continued with the 5sp swap. Box is where it needs to be, clutch seems to work smoothly but more work needed to tie in the cross member. Oh and the driveshaft is being lengthened. A lot more work than I thought it would be. If you'd have asked me again before I started I'd have gone for a toploader + Gear Vendors overdrive...
    chryslerfan55 and impala4speed like this.
  25. alanp561
    alanp561
    Maybe it's Ford's way of getting back at you for putting that GM boat anchor in there;)
    Atwater Mike likes this.
  26. Greg Rogers
    Greg Rogers
    Yep I also have some of the original pieces of a Montgomery Wards Powercraft socket set my parents bought me for Christmas when I was 16. I know what you mean. When you have something that long it becomes special. One funny thing I remember from back then was my friends parents bought him a cheap socket set for Christmas. He and I went to change the starter on his Buick Skylark and the 9/16" socket rounded out immediately when trying to remove the first starter bolt!! Good times....
  27. 62rebel
    62rebel
    Getting to the end of my O/T car's floor pan replacement project. I thought my Falcons could be rusty.........
  28. jimmy six
    jimmy six
    Went to a gathering of like minded folks in Tustin Ca. About 200 cars and more people than that... 73A32AF9-2569-4331-ABE2-3914DE811A19.jpeg
  29. 65pacecar
    65pacecar
    from KY, AZ
    Attended a nice cars and coffee.
    Lil32 likes this.
  30. patrick20
    patrick20
    Here's what I did.
    chryslerfan55 and Blues4U like this.
