Projects Timm builds a model A
Discussion in 'The Hokey Ass Message Board' started by Tim, Mar 8, 2016.
  1. Tim
    Tim
    from KCMO
    **** yes! Thanks dude
  2. Tim
    Tim
    from KCMO
    969DE8C1-0092-4DE9-934C-1944E78D806D.jpeg Austin snagged me these little br*** knick knacks from a train he dismantled. I can’t wait to use them on the A! All sorts of ideas for these :)
    brEad, drdave, chryslerfan55 and 6 others like this.
  3. dumprat
    dumprat
    from b.c.
    Cool! How big are they?
    loudbang and Thor1 like this.
  4. Tim
    Tim
    from KCMO
    I’m not sure @dumprat in thinking they’d be cool to hide a light or switch under, or if they are a little bigger they could be a cool little wire bulkhead/hood where it p***es threw the firewall.
    I’m excited to see what I can come up with for them.
  5. Tim
    Tim
    from KCMO
  6. Tim
    Tim
    from KCMO
    Does it fit? DC034023-5651-4473-A9BA-F56488CC135E.jpeg close enough! 772A783C-48D5-473E-AA2B-2581CA217DA8.jpeg before DA5EED07-4684-405F-B273-0434F15E623A.jpeg 5 gallons of water and a generous amount of citric acid. Didn’t wire brush it, hose it off, or anything before I put it in there. I’ll finish it off upside down in a deep tray.
    figure I’m at a little stand still so I’ve been pulling stuff to soak in acid and clean in the mean time
    patmanta, drdave, loudbang and 4 others like this.
  7. Six Ball
    Six Ball
    from Nevada
    I'm interested in the outcome with this. I am bogged down again over parts cleaning and rust removal.
    loudbang, Thor1 and Stogy like this.
  8. Tim
    Tim
    from KCMO
    @Six Ball worked great on the steering boxes and they were pretty dang gnarly. I’ll keep you posted
  9. Tim
    Tim
    from KCMO
    12 hours 9DFED2ED-E1DA-4F61-90CB-53989CEC7A67.jpeg 24 hours 5358AD29-7C80-4F5F-997B-EAF92CF1CABD.jpeg getting murky and making all sorts of burps and pops
    loudbang, brEad, Thor1 and 3 others like this.
  10. Tim
    Tim
    from KCMO
    Cardboard template.
    1/4 plate part 4B4F8F5A-2FFC-486D-A345-460406533332.jpeg drilled and painted with the silver hammer tone like the rest. Excited to have this one close to being checked off the list 46FA9862-42A7-4660-B947-D7FBE8F447EA.jpeg
    patmanta, loudbang, brEad and 2 others like this.
  11. Six Ball
    Six Ball
    from Nevada
    I really like getting little pieces like this built. It takes the "mockup" aspect out of at least a part of the build and gives some satisfaction.
    loudbang, Tim and Thor1 like this.
  12. Tim
    Tim
    from KCMO
    Absolutely!
    Thor1 and loudbang like this.
  13. Tim
    Tim
    from KCMO
    Pulled it out of the bucket and took it to the drive way. Hopefully these load more or less in order 8374618F-67B2-41F9-BC5E-2CD234B5B41E.jpeg 1B30759D-A991-4D1B-89D5-681184F08B36.jpeg 9B9F4A4D-E00F-4838-BC64-B84C91B83E11.jpeg B1636893-3C07-4418-BD13-1450527E22CA.jpeg CA2EBEFC-6BFA-4DDD-9853-AFD30A9EEEEB.jpeg EE6542EB-FD30-428A-8039-4045E7FF4A9D.jpeg
    brEad, drdave, loudbang and 3 others like this.
  14. Tim
    Tim
    from KCMO
    Then because I had just cut my Jean into shorts haha I used the cut offs with some dawn dish soap to scrub it down. Then i put some soap in the case and just sprayed the **** out of it with a hose for a while.
    then I used various towels to try and soak up any water and left it in the driveway for 5 hours at 93 degrees.
    you can see that it gets a charcoal ish tint to the metal but If you want it gone it comes off fast with a wire brush or similar.
    after a few hours it has a tiny bit of a sand colored spots that I guess are flash rust but it doesn’t bother me at this point. Easy prep if I need it gone.
    i can read ALL the numbers on everything, the gear inside the case now rolls like it’s all brand new.
    Just brought it back in and sat it in a wider shallower tub with some other bits and pieces with the bell side down for round two.
    I just dumped the now yellow/ green liquid out of the blue bucket into it.
    most of the rust/ mud sludge stayed in the bucket I’ll post pics of that later :) 5D73D1D7-76CC-48A4-9087-307CA1426A91.jpeg 26AC9B83-19BA-4595-B997-F7A14F3564FB.jpeg A10E2FFD-EDF5-4862-96A5-56958E83DAA0.jpeg 56CA2955-BCF9-4A85-939E-A07F4B064B62.jpeg 4EDD0EF0-95F6-4F19-9F74-E8B47CE74A33.jpeg 62AA074F-7F2C-448C-A394-4305D6DEF2E4.jpeg A2F013C0-F373-499D-A265-C5E9F76CF45F.jpeg 5D59C1CE-36A9-406F-93F4-9A54E024C03C.jpeg
    brEad, flatout51, drdave and 7 others like this.
  15. Impressive results!
    loudbang, Thor1 and Tim like this.
  16. Inked Monkey
    Inked Monkey
    That's nuts
  17. Tim
    Tim
    from KCMO
    Even that gear spins with no slop or noise!
  18. dumprat
    dumprat
    from b.c.
    Boy! That turned out.
  19. redzula
    redzula
    Awesome work by Mr. citric acid.... That's pretty slick..... Where do you get the acid from?
    That flat on the bellhousing right above the inspection cover is where the VIN should be stamped. Mine matched the frame when I rebuilt my engine/trans a couple years ago.
    Sent from my rotary phone using The H.A.M.B. mobile app
  20. Tim
    Tim
    from KCMO
    Amazon of course lol
    you can also find it at farm stores and health food stores. It’s edible.
    Here are a few photos of it in the new tin with some random bits of other rusty stuff. You can re use the solution until it’s basically sludge. As long as you can see teeny bubbles it’s working. C06F5E04-FF80-4B0F-BC34-AEF9CDA4B22A.jpeg 1B2EF6D3-28F9-4F5D-AC61-0D40195D64DD.jpeg 505FBFC4-4F66-4B18-99F9-15FBF8413BF3.jpeg EA874194-9FD6-49E3-A5B7-F2C84CE24270.jpeg Was trying to get a good look at the green/yellow tint it has now. Also put the block off plate on the intake for a look. Needs the paint touched up a little as it felt over night but over all I’m happy with it. Need some hardware and eventually gasket material and it’s done 97285190-3B8F-45E7-BB79-51A2E36C638D.jpeg
  21. Six Ball
    Six Ball
    from Nevada
    I'm sold, I'll be trying this soon. I still have a few gallons of Evapo Rust to use up but this is so much cheaper and seems to do just as good of a job.
    Thor1, loudbang and Tim like this.
  22. patmanta
    patmanta
    from Woburn, MA
    Wow, I'm sold too. I've used Evaporust a lot too but 5 gallons runs around $100. I might be inclined to mist with WD40 to keep the flash rust down if I'm not painting right away.
    Anybody dipped a block with this stuff yet?
    Edit:
    Found the cheapest by weight bag on Amazon: https://amzn.to/2BDcytA
    And if you want a bucket full: https://amzn.to/2UmXJC4
    Six Ball, Thor1 and loudbang like this.
  23. drdave
    drdave
    Wow! That's amazing! Sadly, I have a couple of engines that I had machined and heads ***embled 20+ years ago before my machinist friend retired. Naturally, I believed I'd be getting right to them to paint them, so I didn't oil them down. We know how this turned out and now I have a couple nicely machined engined with light surface rust. Clearly, this would work on them so far as the flash rust is concerned, wonder if the machining and the hone would be preserved?
  24. Tim
    Tim
    from KCMO
    Yeah I think they would @drdave between this and the steering boxes you can see the machines surfaces perfectly clear.
    Most smooth machined or non porous things come out shiny. Worse case you may have to clean the bores a teeny amount if they get the darker tint to them? But seems like dang near a bottle cleaning brush would do it.
    this if it’s quick thin flash rust this will take it off in less than 12 hours.
    @flatout51 did some brake calipers over night that went from looking like door stops to brand new a while back
  25. dumprat
    dumprat
    from b.c.
    One thing I would mention is that acid on cast iron can do some weird things. I would be very cautious it doesn't make it soft.
    I soaked a set of flathead adjustable lifters in vinegar one time to clean rust off the threads. Overnight the cast iron turned the consistency of chalk. You could scratch them apart with your fingernail.
    Just a thought
    Thor1, Tim, Six Ball and 1 other person like this.
  26. Six Ball
    Six Ball
    from Nevada
    You would have to totally dis***emble the engines, which may be best anyway. A product like Rust Doctor or Rust Mort that changes the rust into a primer or sealed coating may be better on the flash rust.
    Did the citric acid remove dirt & grease too? What is the ratio acid to water?
    Thor1 likes this.
  27. Tim
    Tim
    from KCMO
    Only removes rust. No dirt, oil, paint, plating etc.
    about a half cup of flakes to a gallon of water. I never let it sit for more than a few days.
    did some steering boxes, steering columns and shafts, lots of a small stuff, hardware, license plates. And they are all still rock hard
    Six Ball and Thor1 like this.
  28. Six Ball
    Six Ball
    from Nevada
    It snowed here yesterday, it didn't stick. Now it's warming up. I'll try the pressure washer blaster with the new pump soon but if it doesn't work I'll build a trough that my frame will fit in and give it a soak. I have some heavy plastic and some 8x8 beams.
  29. Tim
    Tim
    from KCMO
    cool man take some before and after photos
  30. Six Ball
    Six Ball
    from Nevada
