Hot Rods Model t door ID
Discussion in 'The Hokey Ass Message Board' started by speedo1, May 29, 2020.
  1. speedo1
    speedo1
    Any ideas? 47” tall by about 24” wide.
    Thanks!
  2. alchemy
    alchemy
    Has the general shape of a 26-27, but no lip on the inner edge of the window opening. Maybe fordors didn't have this lip? And the coupes and tudors had steel inner panels. Otherwise I'd say is about 24-25 fordor.
  3. squirrel
    they made wood doors, then metal doors. This looks like a mid 20s wood door.
  4. fiftyv8
    fiftyv8
    from CO & WA
    I just measured my 26/27 T coupe door and it is all metal firstly and is 29" wide and roughly 48" tall at the center vertically.
    Your door has all the characteristics of a 26/27 door, but it is definitely not likely to fit a Coupe or Tudor of that year.
    It also seems to have a big gl*** area opening.
    Even the latch and sill trim looks much like a 26/27 door items.
    Maybe it was from a 4 door or a special coach build.
    I'd be keen to hear more from any others out there who may know more.
    If no luck post it on the Model T Forum.
    https://www.mtfca.com/phpBB3/viewforum.php?f=2
  5. speedo1
    speedo1
    4A13CE8B-BC83-4A95-B902-3E18FF509A73.jpeg 2B5945BE-E012-45D5-98BE-D7B841E13850.jpeg Ok, found this door: believe it to be a p***enger Fordor front. Any thoughts: 24 1/4 across belt line, 47 1/2 hinge side, 46 5/8 striker side length. Confirmation?
  6. The37Kid
    The37Kid
    Looks like a front door off a 1923-25 Fordor. Note the fender clearance cut on the rear door. Bob
  7. speedo1
    speedo1
    I thought 23-25 would be wood on inside of doors?
  8. Flathead Dave
    Flathead Dave
    from So. Cal.
    ^^^They do.
    This door has the making of the 27-27 door judging by the window hole. But not sure of what year this is or what it came off of.
    Try the Model T Forum www.mtfca.com
  9. speedo1
    speedo1
    Thanks Dave, I did post over there, however, they are definitely much slower to respond than here, lol
  10. Flathead Dave
    Flathead Dave
    from So. Cal.
    Try this one...Model T Club of SoCal
    mtfcsc.com
    lbmtc.com
    I go to a lot of their swap meets and events. Everyone is very friendly in person.
    Had a lot of questions answered from these guys/clubs.
  11. Flathead Dave
    Flathead Dave
    from So. Cal.
    Your second door looks like the front p***enger 1926-27 T Sedan door.
    Found this rear door on ebay...
    1926 1927 MODEL T FORD 4 DOOR SEDAN DRIVER SIDE REAR DOOR 26 JALOPY RAT ROD HOT
